Question about Plumbing
Is the stopper supposed to be bottomed out - Plumbing
    Novelist:
    Champion:
  • 227 Answers
If that's what that particular drain needs to close properly, yes.
Posted on Feb 27, 2015
How to install stoppers and side frame posts into the side frame bottom rail for twin wooden daybed model WM6394W
"Push down firmly" can mean judicious application of a hammer and wood block to get engagement.
May 19, 2016 | Furniture
Why doesn't sink stopper stay in the stopper?
You may find that, over time, the rod end has been eaten away and does not extend sufficiently to engage the loop at the bottom of the stopper. Everything works but nothing works!
Nov 26, 2015 | Price Pfister Plumbing
Clogged drain on moen bathroom sink
There should be a stopper valve on the sink's downspout (the first section of drain pipe). You SHOULD be able to loosen the nut holding the stopper valve's lever inside the pipe. Once you remove that nut, you can pull the lever out - that releases the stopper inside the sink, so you should start with the stopper OPEN, and hold it open with a chopstick or pencil or other tool when you remove that lever.
The lever and the bottom of the stopper itself will be wrapped with masses of hair. That's normal. Clean it up and reinsert it, put the nut back on & snug it down, then readjust the stopper.
If that's not enough, you may need to open the trap (the gooseneck-shaped piece of drain pipe under the sink) to clean it out.
Apr 05, 2014 | Moen Tub Drain Assembly, Lift-N-Drain -...
Delta faucet will not hold water
The linkage to the drain stopper has to be adjusted so that the stopper seats when the rod is raised. If the stopper lifts out of the drain, it may be necessary to remove the lifter rod and insert it through the holes in the bottom of the stopper then reinstall. After this, pulling up on the faucet rod will force the stopper to seat rather than drop by gravity. The tradeoff is that you will not be able to remove the stopper without disassembly of the connection
Feb 18, 2013 | Plumbing
Whirlpool stopper
If there is a small loop on the bottom of the stopper, the popup lever is supposed to poke through that. All you need to do is look at the drain tailpiece for the lever sticking out the back, undo the retaining nut to allow the lever to be removed from the drain, drop the stopper down so the loop can be engaged by the actuator rod you just pulled out, retighten the nut, then make the final adjustments for open height with the small metal tab holds the lever to the piece of metal with holes in it that is attached to the drain poppet in the middle of the faucet assembly above It should close completely and then open to drain.
Jan 15, 2012 | Kohler Plumbing
I stopper on a garden tub with a delta faucet. The stopper pushes down and locks to stop water. It takes a few tries pushing it down to get it to stop and hold water. What is the best way to fix it or...
In my part of the country, the type of drain you refer to is commonly called a tip-toe drain because you can use your toes to open and close the drain. Their locking ability diminishes over time and use, and eventually won't lock at all. They cannot be repaired, and must be replaced. You must remove the one you have to get the correct replacement because there are variations in the thread diameter at the bottom of the stopper.
You will need to use pliers large enough to grab around the white plastic underneath the top of the stopper that appears to disappear into the drain. Once you have the white plastic shaft secured with pliers, grab the very top (the chrome part) and twist it counterclockwise to remove it. Once that is off you will see a round piece of brass that looks like the top of a very large screw. IT IS! Using a stantard screw driver, again turn counterclockwise to finish removing the rest of the stopper.
A good hardware store should have a replacement for you. Be sure to match up the thread diameter at the bottom of the stopper.
To reinstall, you can reverse the steps or simply thread the complete assembly into place.
Aug 07, 2010 | Home
How do i remove the battery from my camera exilim ex-z80?
Go to page 12 of manual. you need to hold the stopper down to remove battery. Here is the manual I looked at.
http://support.casio.com/pdf/001/EXZ80_e_na.pdf
Good luck and please rate fixya for the free answer
Apr 08, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
Bathroom sink stopper came unhooked and out, not attached anymore
You will need to get under there and unscrew the popup rod located on the back of the drain. pull out the rod, drop the stopper in there and push the rod through the hole in the bottom of the stopper. screw the nut back on.
Mar 15, 2009 | Home
Woolpool Duet Washer fast clicking
If it does not start the clicking noise is coming from the water distribution lever on top of the soap dispenser assembly. Take the top off. On the left hand side you will see a teardrop shaped piece of plastic with an arm attached at one end an a motor attached to the other. There is a stopper that is supposed to stop it from going too far and it has likely jumped over the stopper. Gently remove the arm from the teardrop and reposition it over the stopper then reattach arm.
Feb 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Plumbing Logo
646 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
