Question about Dodge 1998 Ram 2500
My 1998 doge Cummings 3/4 ton has no running lights when I turn on the head lights on except the head lights all other lights work is it the light switch???
Iv checked all the fuses and couldn't find any problem
    Problem Solver:
  • 15 Answers
Look in owners manual there should be a way to start engine without running lights coming on, like setting your e brake, if thats the case check the switch on e brake.
Posted on Dec 01, 2014
1977 GMC crew cab 3/4 ton V8 turn signal problem.
My friend is a part time mechanic he gets his solutions
from www.reliable-store.com
he gets from their every single detailed info, instructions etc. on all vehicles, and manuals like service, repairs, parts, owner's, operations, maintenance etc.
U can get help from there
there is a girl at chat she can help you
Mar 20, 2018 | GMC Cars & Trucks
My 1998 Porsche Boxster automatic gear console face light doesn't turn on . Why does stay without light?
You probably have a loose wire to the gear console switch, or a bad board somewhere. Check to see that you have voltage going to the lights in the console.
Nov 19, 2013 | 1998 Porsche Boxster
What is firing order in doge ram 1500 1/2 ton 4wd pickup 5.9 liter v8
1-8-4-3-6-5-7-2. I googled your question and found the firing order there hope this helps. I do know on some engines the firing order is on the engine block of that motor.
Jun 12, 2012 | 1998 Dodge Ram 1500 4WD
Dash lights and running light doesnt work
check switch with a voltmeter
Mar 15, 2012 | Cars & Trucks
1998 buick skylark security theft light on,car starts and turns of right away?
Your PassKey Security System is malfunctioning. The most likely cause is a bad ignition lock cylinder. Try this to get it started:
1. Set the parking brake. (This will keep your headlamps from coming on and running your battery down)
2. Turn the key to the "START" position and release it to the "RUN" position. (Do not turn the key to the "OFF" position or you will have to start over.)
3. Leave the key in the RUN position for about 10 minutes until the SECURITY light stops flashing.
4. When the light stops flashing, turn the key to the "START" position again.
This should get the engine started so you can drive the vehicle to get it repaired.
Feb 23, 2011 | 1998 Buick Skylark
I HAVE 2006 DOGE RAM 2500 CUMMINGS THE RADIO DOES NOT WORK ALL THE TIME WHEN I START IT.
i have a 2006 with the same problem but i found that if you clean the battery connections at the barrery all will work fine
Dec 28, 2010 | 2006 Dodge Ram 2500
Brakes Lights dont work on a 2006 Chevy Silverado
I've worked on these the first drove me crazy. its the turn signal switch every thing runs thru these. head lights, turn signal, brakes. except the third brake light. it runs directly from the brake switch. go figuare
Jun 22, 2010 | 2003 Chevrolet Tahoe
Headlights don't work
i check for blown fuse if ok most likely head light switch.
Sep 17, 2009 | 1998 Ford F250 SuperCab
Dodge 1998 Ram 2500 Logo
77 people viewed this question
Top Dodge Audio Players & Recorders Experts
NOEL
NOEL
Are you a Dodge Audio Player and Recorder Expert? Answer questions, earn points and help others
