Question about Welding Tools
I broke the part that holds the wire where can I get this replaced at
    Loyalty:
    Visited the website for 30 consecutive days.
  • 372 Answers
At a store that supplies parts for what ever welder you might have.
Posted on Dec 01, 2014
The push in wire connector broke loose. I need to find a replacement part or find out how to remove the existing wires.
In most cases you can take a large pin or needle and release the lock from the wire side. Each wire is pushed into the plastic block and a small tab holds it in place. If you push the pin or needle into the hole with the wire you can release the tab.
Nov 03, 2015 | Cars & Trucks
The piece that holds fuse broke
You can mke one. In stores, they sell little fuse holder with a wire at each end. It should replace it if you don't know how to do it, ask a friend who knows how to fix it. It is easy to fix. Best of luck. Serge Lavallee.
Feb 17, 2014 | Behringer Eurolive B212A Speaker
Spark plug wire failure
Put new one if not catalytic con. will be next.Could cost $500.00+
Jun 19, 2013 | Cars & Trucks
Hood release handle broke off
On some vehicles the hood latch can be released by working from underneath and using a coat hanger with a hook as a tool. It may be necessary to have someone push down on the hood while the coat hanger is being applied to relieve spring tension
Apr 08, 2013 | 2005 Chevrolet Malibu
Replace starter cable
Take the ground wire - and positive wire + off. Get a replacement cable, take the nut off the holds the cable to the starter. Install the new cable on the starter, then install the other end to + of the battery. Finally install ground wire - on the battery. Please rate my answer so I am rewarded points for it.
Feb 01, 2012 | Chevrolet C1500 Cars & Trucks
The knob broke off. How do I fix it?
well if you broke only the knob, then thats an easy fix.. just obtain part # 154535903 - KNOB and replace.
however if you broke the shaft off inside the knob you will need to procure part # 154668901 - CONTROL MODULE
remove power from the dishwasher and remove the screws holding the inner door panel to the door.
once that is removed you should see the control assembly and related wire harness that needs to be disconnected and screws that need to be removed, etc..
hope that helps,
best of luck,
ttfn
Oct 19, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Replacing broken cable on Porter Cable 7800 sander
just have to take off the plastic flexible casing it is screwed to the head. then you can pull the old wire out, if it it broken take out the plastic bellow and the 2 screws that are underneath that. then u can pull the remain of the old[broke shatf wire. To unscrew the casing use a plier and hold the metal piece not the plastic or u will broke it. \ REMENBER THE CASING IS NOT THE VACUUM HOSE IS UNDER IT.
Jul 27, 2009 | Porter Cable 7800 Drywall Sander With Dust...
Drivers Side Electric window 1993 SC400
The motor/regulator comes as an assembly with the wire and clips. You don't need to remove the window, just unbolt it from the regulator, and hold the window up till the new regulator is in, then remount it.
Jun 10, 2009 | 1995 Lexus Sc 400
Welding Tools Logo
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
