Question about Cobra 29lx Cb Radio W/clock 29 Lx Lcd
<!-- from fixya rte -->My cb keeps saying antenna warning - Cobra 29lx Cb Radio W/clock 29 Lx Lcd
    Sergeant:
  • 268 Answers
The swr is too high. You may have a coax damaged or a bad antenna. Do not operate the radio on transmit until this is resolved or it may damage the radio.
Posted on Dec 01, 2014
3 Suggested Answers
freetek
  • 5568 Answers
SOURCE: red antenna warning indicator light stays on
The red light is a warning of antenna mismatch; when you hold the antenna, you are changing the match between the CB's output amplifier and the antenna. Try it with a different antenna or pick up a 'test light' (or test load) for CBs from an electronics dealer, I've also seen them with CB accessories at truck stops. If the test light fires off and the red light on the CB is dark, the antenna you have is junk.
Posted on Aug 01, 2010
SOURCE: 29 lx le new 200
The "Antenna Warning" came up on my radio too, a new Cobra 29LX, but I found another bunch of people having the same problem. This alert that you are seeing is only supposed to basically come up on that screen if there antenna is not connected. There is a simple adjustment inside the radio. The component is a little potentiometer that has to be turned with a little tiny screw driver. You can do this yourself, just look for the PDF file online that explains and shows you how to do it in a few seconds.
Here you can finds the link to the PDF file right here.
http://www.thetruckersreport.com/truckingindustryforum/cb-radio-forum/147114-i-need-some-help-antenna-warning-5.html
This is an easy adjustment. I fixed my false warning in a few seconds.
Posted on Jun 17, 2012
When I hit the mic key, it says antenna warning on the radio display. Why?
antennae damaged or faulty, or not tuned with a SWR meter. Also corroded connector, or damaged wiring to the antennae.
Sep 05, 2015 | Radio Communications
My keeps saying antenna warning anybody else had this problem?
you had better check you match on your antenna before you do serious damage
Oct 02, 2014 | Radio Communications
Bought a new cobra Every time mike is keyed it reads antenna warning Radio will transmit short distance and will on receive short distance Very short Cobra 29 L X B T LCD CB radio
The antenna warning is the key, the swr on the antenna/feedline is very high. check antenna connections, coax and connectors for damage
Apr 10, 2014 | Radio Communications
CB Antenna Warning Light
Sounds like bad SWR. Check antenna ground. If mag mount, make sure mag and whe you put it is very clean. Check antenna where whip comes in to coil or base. Check pl259 with vom for continuity, open or shorts. This will probably solve the problem. DO NOT TRANSMIT WITH HIGH SWR. YOU CAN BURN OUT POWER TRANSISTOR. HOPE IT HELPS.
Tom
Oct 20, 2012 | Cobra 29 Lx Full-featured Cb Radio
Cb antenna warning
If your readings are below 0.5 with a dipole that is a excellent swr reading, most fall in the area of 2.0 or higher, you will not harm your RF output transistor, if you are getting antenna warnings see if you can recalibrate it.
May 04, 2012 | Cobra 29lx Cb Radio W/clock 29 Lx Lcd
29 lx le new 200 wilson antenna new coax and radio .we set the swr with a good meter at 1.2 and the radio says 3 or so and the message on the radio says cb antenna warning.and we doudle check the swr with...
what kind of meter? I would go by what is in the radio unless you are using an analyzer.
You may also be getting common mode current. take 6 to 8 inches of coax and make a tight coil about the same size as a spray paint can. Hold it together with electrical tape.
Use the meter in the LX LE to set the SWR then check with the other meter.
Nov 16, 2010 | Cobra 29 NW CB Radio
Red antenna warning indicator light stays on
Aug 01, 2010 | Cobra 29 LTD CB Radio
My antanna light keeps lighting up. ive checked all conections and even put tin foil between all the conections from my cable threw my spring and my antanna
cobra 29 red light is normal but if you have two red lights that means that your swr is to high. take all that stuff you put on the antenna connection,get rid of the spring and adjust your antenna using an external swr meter. Get the swrs down around 1.5 and the second red light ,which is the AWI or antenna warning indicator,will also go out.
Jun 14, 2010 | Cobra 29 LTD CB Radio
Cobra 29 LTD Bluetooth
You got your radio peaked? Most likely, however, the pot for the antenna warning indicator is VR6. I always check that after peaking a radio.
Jul 28, 2009 | Cobra 29 LTD CB Radio
ANT lite coming on for the first time when you key up and will it hurt radio
The type of coax and antenna should not matter in this case. What that light is telling you is your SWR is above a safe working level. You need to tune your antenna using an external SWR/power meter. It may also mean that there could be a bad ground or a bad connector. You probably just need to tune it up. Anything below a 2.0 SWR is acceptable.
Jul 07, 2009 | Cobra 29 LTD CB Radio
Cobra 29lx Cb Radio W/clock 29 Lx Lcd Logo
132 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
