How do I clean Thor Front Loader Washing machine particularly the rubber round the door?
Just tried Trimat Washing Machine Cleaner
  • 209 Answers
SOURCE: front loader washing machine = black streaks on clothing
I am a recently retired engineer of 20 years once you have ruled out anything getting inside the machine by accident etc, like something in pockets or greasy overalls, then its likely to be the drum bearings, has the machine started to get noisy on the spin the drum bearings are covered by a rubber seal, this seal gets damaged or worn and water leaks into the bearings themselves washing out the grease back into the drum where the washing is, you could also notice slight water marks on the floor underneath the machine on the floor, take the back off and look for water marks coming from the drum outer casing behind the pulley, these marks will be brown and will originate from a small drain hole, if any of the above change the bearings before any real damage is done, either to the clothes or the machine, as repair can be expensive? sorry, hope i have helped you as to where to look at least,
Posted on Sep 19, 2007
  • 41 Answers
SOURCE: Washing machine rubber door seal replacement
Go to www.Searspartsdirect.com You should be able to find an exploded view and parts list
Posted on Feb 29, 2008
57 varieties
  • 1653 Answers
SOURCE: I have a dirty rubber inner Bosch Maxx 1200 Front Loading Washing
First clean around the rubber with some mould and mildew cleaner for bathrooms - available from most supermarkets.
This is a natural accumulation of waste detergent, fabric softener, fibres and dirt build up that is being attacked by bacteria and eventually decomposes into a sludge / goo and then eventually starts smelling bad as well.
To keep the machine clean of waste build up and to keep any bad odours away:
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
7. Repeat the cleaning procedure monthly
Posted on Oct 02, 2009
  • 177 Answers
SOURCE: miele front loader washing machine W3275- error co...
hi,
this is a tachogenerator fault or the drive motor brushes are faulty. you will need a Miele service tech or a Miele service agent to look at this.
Posted on May 24, 2010
  • 327 Answers
SOURCE: GE Profile front loader washing machine is leaking
Hello, this is usually the door seal, most machine incorporate a one piece combined door seal and outer drum seal(often just called a DOOR GASKET), the door seal are put in on the front panel first in the factory, then the drum assembly is put in and the seal pushed over the outer drum. This means a lot of stripping down has to be done just to replace the drum to the door seal.
Thanks
Posted on Jun 14, 2010
How do i clean Bosch WAE20261AU front loader washing machine
The lint will be in a removable filter and as for cleaning the rubber seal the black grime will most likely be mould. Try a good mould remover.
Apr 27, 2013 | Washing Machines
I have a front loader kenmore and there is a stale smell on my clothes. I have run the machine with vinegar, tried bleach and now have tried tide cleaner for the washer and my clothes still smell.
try to change the rubber around the door opening this will take care on the odor also try using the afrsh washer cleaner and use a double dose 2 tablets
Sep 04, 2011 | Kenmore Elite 45986 Front Load Washer
How do I clean the mould in the rubber door seal of a Bosch front loader.
This video will show you how to change a door seal on this Bosch front loader washing machine
we have all bosch repairs in our channel
Apr 01, 2011 | Bosch Washing Machines
My Bosch washing machine is leaving sludge like marks on my clothes. Ran the machine at 90 degrees with soap but no load. Didn't solve the problem. Any ideas?
Make sure the draw is 100% clean inside the draw compartment to if the draw is all clean next thing to cheak is the rubber door seal make sure it is clean all the way round next thing to cheak is the pump at the front of the machine pull down the cover and undo the the pump cover by tuning anti clock wise water will come out when you cheaked it is 100%clean put it back together if you get stuck read manual if all toughs things are clean or bean cleaned. do a 90 again with washer cleaning detergent with you can buy at the super market hope this helped.
Aug 26, 2009 | Bosch Classixx WFO 2466 Front Load Washer
Require Manual for Thor TWM 800 Washing Machine Front Loader
Where can I find the instructions to my Thor WM800 front loading washing machine?
Aug 22, 2009 | Whirlpool WFW9200S Front Load Washer
Mould on gasket inside door
u need to clean the door seal with a cream cleaner then put the machine on a boil wash with soda crystals in it or but the lime and gunge descaler from espares
Jul 29, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
FRONT LOADER DOOR LOCK WONT OPEN OR JAMMED
On a Bosch wfmc3200uc there is a green plastic string, similar to fishing line, located behind the round panel on the front of the machine. It is attached to the top right of the round black piece. Just give a slight tug this will release the lock.
Oct 05, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
