I have a lexmark c534dn that has an issue printing light on the left side of the pages. It seems to be an issue with black prints but color comes out okay. I replaced the black toner and the black photoconductor and get the same results. I tried replacing the other photoconductors and same results. I am starting to think it is the transfer belt assembly but that is too expensive. I bought the printer new for under 200 a couple years ago and only have about 1000 pages use. Any ideas other than the transfer belt? Thanks!
  • 1,915 Answers
That is possible. The transfer belt contains four transfer rollers, one for each toner. However, if the printer is dirty inside then it is also possible that the black scanner is polluted. A damaged contact can cause this issue so I would check all the contacts that cartridges and drums seat against to make sure one is not stuck before going the route of a transfer belt which is likely more than the printer is worth.
Posted on Dec 01, 2014
My Impact s305 printer has full ink cartridges-I even just replaced one a few minutes ago and the color ink won't print out-only the black will. I've already tried to reset factory settings. It...
Lexmark recognizes that some of our inkjet all-in-one customers may be experiencing issues with their print quality. We take our customer user experience very seriously, and we strive to ensure that each time a customer prints using a Lexmark device the page is crisp, clear and up to the highest standards.
However, if your device is displaying a 'printhead error' on the hardware and/or you are suddenly experiencing a print quality issue, please contact the Lexmark Technical Support Center at 1-800-539-6275 or point your browser to http://bit.ly/lFKDzs for online technical assistance.
Aug 10, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
I have a Lexmark C534dn color printer. I recently replaced all of the toner cartridges. Each time I print, the pages come out with black verticle streaks and splotches going down both sides of the paper....
On laser printers, this can be caused by the charge roller or the print head. I would first look at cleaning thoroughly the charge roller (this is the roller that goes in to the Toner cartridge when you close the lid.
Use soapy water and let dry COMPLETELY before reinstalling. Or just replace it (better choice really)
This can also be caused by the print head and the fuser. so if the charge roller doesn't fix the problem, start looking there
Jun 16, 2011 | Lexmark C534dn Laser Printer
Lexmark c534dn is printing on the left side of the page only.
toner is going to empty, for instant solution take out toner cartridge and shake it for some time, then put it back to printer it will resolve your problem for a while but ultimate solution is replacement or re-fill.
Nov 05, 2010 | Lexmark C534dn Laser Printer
My CLP-350 Samsung printer only prints black ink on half the page! While the other colours all print perfectly, the black ink prints strong and clear on the right side of the page but as you approach the...
Here is my solution, hope it will solve your problem.
From your post, I believe your CLP-350N printer has enough black toner. The black cartridge is on the far right side of the printer, so the black toner is harder to go to left side of the roller than right side. Everytime we start the printer, it will move some toner of each color to the roller before it shows ready to print.
Because we always use B&W printing when we start the printer, but less Color printing. The result is there are always enough toner on the 3 color rollers, but the black toner is lean on the black roller. When this gets worse, the left side of the black roller may hardly get any toner at all -- so it only print black on the right side fo paper.
Step by step solution
(CAUTION: Never loss balance while tilting printer! You may drop and damage your printer! Hold the printer firmly all the time! Ask someone to help you if needed!)
Here, front of the printer is where you can access the cartridge, back of the printer is where you connect the power cord and USB cable, left is your left, right is your right.
1.Lift the front to keep the printer tilt to its back at about 45 degree
2.Power on printer while it's tilted back, wait untill green light is on
3.Open the front door, red light will be on, then close the door, printer will start up again,wait untill green light is on
4.Repeat step 3 once again, then put the printer back to level position
5.Lift the right to keep the printer tilt to its left at about 45 degree
6.Open the front door, red light will be on, then close the door, printer will start up again, wait untill green light is on
7.Repeat step 6 once again, then put the printer back to level position
8.Print some test page to see if there is any improvement of black print quality.(Hold the printer button for 3-5 seconds, it will print the test page.)
You may try several times and print several pages each time before you finally cure the problem.
Good luck! And do it safely!
Jan 09, 2010 | Samsung CLP-350N Laser Printer
Lexmark x1270 wont print color even though the cartridge is full.
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Next, try this printer self-test by following the steps given below:
1. Power the printer off.
2. Press and hold the "Paper Feed" button.
3. While still holding the "Paper Feed" button, press and release the "Power" button. Continue holding the "Paper Feed" button.
4. When the printer starts pulling paper, release the "Paper Feed" button. It should print a test page at this point.
5. Power the printer off, as this test is continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know.
Oct 19, 2009 | Lexmark X1270 All-In-One InkJet Printer
Can't print in color
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.  2. Select "Clean and Fix Horizontal streaks."  Click on "Print". This will produce a printed page.
1. Please open the "Solution center" again and go to the "Maintenance" Tab.  2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.  3. Get a damp paper towel.  4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.  5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.  6. Next dab the cartridge on the towel to make sure that the ink is flowing.  7. Snap the cartridges back into the printer.  8. On your computer, select "Old Cartridge install."  9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
May 26, 2009 | Lexmark JetPrinter Z11 InkJet Color...
My printer wont print color!
Hi.
First check if you are using compatible cartridges for the printer. Use the following weblink to check for compatible cartridges for lexmark printers:
http://www.lexmarkstore.com/store/lexmark/DisplayProductFinderPage
if using correct carts and still issue, then you may try the following to clean the cartridges and print contacts:
Remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Snap the cartridges back into the cartridge carrier and check if it prints color.
To clean cartridge nozzles:
Click on "Start," go to "All Programs," and down to the Lexmark. Click on the "Solution Center." Next, click on the "Maintenance" tab. Select "Clean to fix horizontal strips." This will produce a printed page.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean to fix horizontal strips" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution Center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge (or cartridges) from the printer.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean. Also, wipe the contacts inside the printer (on cartridge carrier).
9. Repeat the "Clean to fix horizontal strips" one more time. If this fails to address the problem, the entire procedure may need repeating.
Hope dis helps u...
Apr 24, 2009 | Lexmark X2600 InkJet Printer
k24674
jasbo
jasbo
