Question about Proform Exercise & Fitness
When turning my Treadmill on it will speed up and then come to a complied Stop
Pro form XP 650 I unplugged it tried to hold the Start and Stop Button together down
  • 14 Answers
SOURCE: Pro-Form Sport 1000 treadmill does not stop inclining
Do a Calibration on the treadmill. Take out the safety key. With 2 fingers, hold down the stop button and the speed up or spped plus button. keep holding them down as you insert the safety key, then let go of both.
Press the stop button 1 time, you should see all 0's in the windows, or EP 2P or something weird like that.
Press the Incline up button and then wait. If the incline go up until it stalls then down until it stalls the stops at the bottom, the you are recalibrated, take out the safery key and put it back in to see if all is well. If the incline takes off up again without touching a button, the you have wiring problems or control problems. Call service company to get it repaired.
Posted on Apr 29, 2009
SOURCE: I have a Sears Pro Form 730si. The treadmill
I believe E4 on ths 730si means that the speed of the motor the sensor is detecting is greater than the set speed. E2 would be the opposite. I believe there is a way to calibrate the speed. Look at the smaller motor controller board.
Posted on Aug 21, 2009
SOURCE: I plugged in my Pro-Form 730cs treadmill and it won't start.
My i FIT treadmill won't turn on. Is there a reset button somewhere?
Posted on Apr 26, 2010
bwinton
  • 83 Answers
SOURCE: treadmill seems to slip while running,
To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns.
Posted on Apr 30, 2010
maxtreadmill
  • 832 Answers
SOURCE: describe how to unfold a treadmill, pro form ex
Hold the upper end of the treadmill with your right hand on the back end of the unit. Using your left hand, pull the lock knob to the left and hold it. Pivot the treadmill down until the frame is past the pin on the lock knob. Note: You may need to push the handrail to the side slightly. 2. Move in front of the back end and hold the treadmill firmly with both hands, and lower the treadmill to the floor. CAUTION: To decrease the possibility of injury, bend your legs and keep your back straight
Posted on May 31, 2010
My preform treadmill isn't starting, how do I fix this problem?
If it tries to run for a second or two and stops it will probably be the speed sensor. It is a small magnetic switch that is activated by a magnet on a flywheel that drives the belt. The control board looks for this signal to set the speed of the belt, without the signal the belt will stop. A competent DIYer could probably find and fix it but make sure the machine is unplugged from the wall before attempting any work.
Oct 05, 2014 | Proform Nordic Track Treadmill Pro Form...
Pro-form 980, regardless what button I hit the speed goes to 12
1) test the speed sensor, for open or faulty, see the adjustment. Clean if and tight the connector very well
2) tight the ribbon cable for keypads , and clean it
3) replace batteries,and clean the contacts baterries very well
4) adjust the Reed swtich, test for open or faulty, clean it and tigh the connector very well see the diagram
5) Run the software calibration for troubleshooting, diagnose, and fix it.
Jan 22, 2013 | Proform 980 CS Treadmill
I hae a Pro Form 540 Iteracive Trainer treadmill. When the key is inserted, the treadmill cuts on but the control panel doesn't seem to work when you touch start. I waited and cut it off and went...
I will advice you try re-calibrate your treadmill, follow the procedure below to re-calibrate it,
Step 1 Stand on the side rails of the treadmill for safety purposes. Remove the safety key. Step 2 Press and hold the two incline buttons. The incline buttons are blue and on the left side of the display. Hold the up and down button simultaneously. Release the buttons when the display reads "Calibration."
Step 3 Press the green start button located either above or below the large, red stop button (depending on your model). Stay on the side rails as the treadmill belt begins to move. Both the speed and incline should go through their full range from lowest to highest, and then back down again.
Step 4 Repeat the process if the display does not read "Calibration Successful."
Aug 08, 2011 | Sport & Outdoor - Others
Screen states Lube Belt , do not have user Manual , Where are lubrication points and what type "lube" can I use ?
hi,
It is necessary to lubricate your treadmill running deck every six months or 150 miles to maintain optimal performance. Once the treadmill reaches 150 miles, the console will display the message "LUBE" or "LUBE BELT". The treadmill will not operate while the message is showing. Hold Stop for 5 seconds to suspend message for 5 miles. Your treadmill came with a bottle of lubricant which can be used for two applications. If you need lubricant, contact Horizon Fitness. Only use lubricant provided by Horizon Fitness.
• Turn off the treadmill with the on/off switch, then unplug the power
cord at the wall outlet.
• Loosen both the rear roller bolts. (For best results, place two removable
marks on both sides of the frame and note roller position). Once the
belt is loosened, take the bottle of lubricant and apply it to the entire
top surface of the running deck. Tighten both rear roller bolts
(matching up the marks for proper position) to original position. After
you have applied lubricant, plug in the power cord, insert the safety
key, start the treadmill and walk on the belt for two minutes to spread
the lubricant.
• Lubricate the air shocks with Teflon based spray.
• Once lubrication is complete, reset the console by pressing and holding 'STOP' and Speed '+' buttons for 5 seconds.
ok
Dec 26, 2010 | Horizon T91 Treadmill
My Reebok S 9.80 will turn on but when I push any button on the console it just beeps and does not respond. What does that mean?
yes - had to recalibrate it. Plug it in, remove the key, hold down speed + and the stop button on the console, while holding them down replace the key. release the buttons, then press stop once. then press and hold speed + until speed reaches max. unit should run and speed up to max. console should display max speed (s9.80 should read 11.8 to 12.5). It took me a couple of tries to get running but now it is OK. If after several tries the unit does not run then the console will probably need to be replaced ($410) - so get a new treadmill ! If unit does run then it may still beep. Problem is with the IFit card. You can get rid of the beeping by opening the console (unplug the treadmill first) and removing the cable that connects the IFit card to the mother board. Of course the IFit will not work but it will not be beeping at you. good luck
Nov 21, 2010 | Reebok T 980 Treadmill
My Pro-form 980 CS will not start. I plug the key
Press the Stop and the Speed Up keys down while inserting the safety key. This should get you into calibration mode. Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test. If you cannot get into calibration or if the EPROM test fails then the upper console will have to be replaced.
If you get pass to this point then proceed with the calibrating the incline and speed.
Press either incline key and the incline will calibrate automatically.
Be careful the treadmill will run at full speed in the next mode DO NOT STAND ON THE WALKING BELT.Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window).
If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled
The max speed potentiometer is a small square with a mobile center and is located in one corner of the board and is labeled MAX SPD. It is near the harness that carries the speed signal labeled H,W,L. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments.
It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure.
After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing. Press the Stop key once and remove the safety key.
Jun 12, 2010 | Proform 980 CS Treadmill
Describe how to unfold a treadmill, pro form ex
May 31, 2010 | Proform Exercise & Fitness
Ifit treadmill will not incline but everything else works, how do I fix the incline
You may need to calibrate the incline. Do this with the following procedure.
Safety key out
press the stop and speed up buttons at the same time while inserting the safety key. (you are now in diagnostics)
press the stop button one time only.
now press the incline up button (incline motor should start moving up)
incline will go up to the top and then all the way to the bottom. when it gets done you can remove the key. Reinsert the key and you should be operating normally.
Good luck Tim
Nov 23, 2009 | Proform Quick Burn Pro Treadmill with 12...
Apr 27, 2009 | Proform Sport 1000 Folding Treadmill...
Exercise & Fitness Logo
59 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
