Question about Vulcan Heating & Cooling
VULCAN oil heater pouring out air - unable turn off, C.1975 model # can't find. Knob top RHS of unit has turning knob with three settings and two red dots, once clicked, not now. Turning this with its
Reduced air by turning swivel, but didn't stop airflow altogether. Tried turning on/off at top RHS knob, still zero. Concerned as unused oil in tank outside affixed to brick exterior of house (?) Cannot locate gas point, is that's how it's lit (?) Problem is just it's got air pouring out which is unstoppable. Fire hazard potential? Unit will never be used now. Installed new, manual probably thrown out. Help please!
    Loyalty:
    Visited the website for 30 consecutive days.
  • 372 Answers
Check your setting for fan and heat, make sure the fan is only on when heating.
Posted on Dec 01, 2014
Buffalo12980
  • 625 Answers
SOURCE: Pilot light lit but no heat
the pilot's millivolt generator may be at fault.  if you have a meter that is capable of measuring a very small DC voltage, connect it up to the very end of the thermocouple and the copper cappillary. the thermocouple has a welded bead at the very end inside that generates a small DC voltage. Same principle of a J-K thermocouple. Iron constintan  - two dissimiller metals where joined together produce a voltage when heated.  the thermocouple actuates a millivolt electromagnet inside the valve to keep the valve pellet open.  no voltage there it won't actuate the electromagnet.
Posted on Oct 15, 2007
  • 41 Answers
SOURCE: Endless Summer Patio Heaters won't stay lit
Hi ColdinSF,
You need to remove the covers from the unit and blow out the gas lines with compressed air. If you can remove the gas lines blow out the lines and what they connect to like the pilot light and main feed line to the burner. Usually they gunk up with use and just need to be blown out with compressed air to clear the lines again. Maybe you have some dirt or foreign object from your gas tank which has clogged the line. Also check the igniter electric lines as well and make sure everything is connected properly. Especially make sure you tighten the gas lines you remove. Hope this helps.
Regards
Bryan
Posted on Dec 22, 2007
  • 234 Answers
SOURCE: Gas wall heater won't light
You need to bled the line longer and when you get lited hold down for a good minute.When the gas gave out ,there could trash in the line.I would take the line off and blow gas through it undtil you can smell it.
Posted on Mar 13, 2009
zonaluver
  • 7 Answers
SOURCE: Torpedo heater wont stay lit.
Do you have the serial number or the manufacture date? There are some design changes and I would need to know the year of manufacture to assist accurately. Usually it is a relay or the thermocouple connection that will affect the unit staying lit.
Posted on Mar 29, 2009
  • 141 Answers
SOURCE: fire sense patio heater won't light...
you prob need a new theromocuple on your pilot or just cleen it with sandpaper this may help
Posted on Apr 14, 2010
Mum's Vulcan oil heater was serviced.Filter changed. Always hasn't burned all the way to the ends it's standard 1 control knob. Is there a oil/air mix adjustment. Can't find online manual anywhere.
Probably needs burner pot cleaned out, common thing to do.
Its a 40 series oil heater, only had single knob, air adjust is automatically set by internal controls.
where abouts are you.
I have some parts and manuals still
Jul 03, 2017 | Vulcan Heating & Cooling
VULCAN oil heater c.1975 UNUSED oil in tank on outside wall. 2 months continuous airflow. Tried turning knob every way, pushing button up/down = ON/OFF (?), unit NEVER USED and will NEVER BE USED.
Not quite sure what is asked, but if you just need to turn off the airflow a breaker or fuse box should be nearby. Flip the breaker and/or remove the fuse. Fuel oil is always dangerous... even a small amount. The lines will still have vapors. Best to remove this unit or flush out the tank and lines and block it off.
Dec 09, 2014 | Heating & Cooling
Hi We recently bought a house that has an 40 series Vulcan oil heater in it. Can anyone tell me how to light it. It has a knob on top with numbers from 1 - 5 (2 being ignite). A lever on the bottom that...
Make sure the tank outside has oil ( Kerosene) in it. Check the fuel tap (under the tank) is turned on. When you press and hold the heat control button, it should ignite after a few minutes. The lever on the bottom is the fan control switch (high speed or low speed fan) Make sure that the unit is plugged into the power. If I remember correctly, a red light appears to say it is powered up on the bottom left hand side.
Jun 19, 2014 | Heating & Cooling
I have a brita faucet filter. And the selector knob is getting harder to turn. If it gets any worse I will need to use a wrench. I wanted to try to lube up the movement if I can open up the casing. How...
I have a Brita faucet filter (model FF-100) that lately has become harder and harder to turn. I toyed with the idea of forcing the unit apart but, instead opted to lube the mechanism directly from the top, where the unit attaches to the faucet.
To this mean, you will have to 1) Detach the unit from the faucet. 2) Remove the filter. 3) Thoroughly wash the unit, inside and out, turning the knob to flush any debris that may be present. 4) Pour some drops of vegetable oil inside the mounting opening, coating the valve stem within. (Oil may pass thru the unfiltered water outlet, so choose an appropriate working space). 5) Turn the water handle (knob) to lube the valve repeatedly, until it loosens. 5.b) Optionally, you could let the oil sit for some time inside the base. 6) Rinse the unit and reinstall it on faucet (without the filter). 7) Turn knob to unfiltered position, and flush with warm/hot water. 8) Do likewise with knob set to filtered, but open faucet only slightly, to avoid over-spraying. 9) Remove base unit from faucet and repeat steps 3-9, as needed. 10) Reinstall unit with filter, as instructed by manual.
Water valves may seize due to mineral deposits. While you may be tempted to use detergents or solvents, be reminded that unless thoroughly rinsed, chemicals may corrode plastics, degrade your filter, or even wind up in your drinking water, so caveat.
Apr 04, 2011 | Microwave Ovens
Vulcan fryer gas control knob will not turn
700 SERIES GAS VALVE MUST BE CHANGED COMES WITH NEW KNOB PRICE OF GAS VALVE IS ABOUT $105.00
Nov 16, 2008 | Vulcan EF3 Deep Fryer
Vulcan space heater lighting instructions
turn the round knob to left "the ignitation" spot, then push down the button to light the pilot.
May 07, 2008 | Ovens
Vulcan oil heater
1. Check electricity is on.
2. Check oil is in the tank and valve turned on.
3. Switch the fan off at the bottom left hand corner.
4. Switch oil knob to No.1.
5. Set Air knob to No.3.
6. Operate re set button (right hand corner of heater under settings dial). Either press in until it clicks or if the pull out version pull out until it clicks.
Wait - ignition should take place in a few minutes and flames will appear on the left of the burner under the radiants.
You should get occasional yellow crests above the pure blue flame just visible below the top row of burner holes under the radiants.
After the red warning light goes out you can adjust to higher settings.
The radiants do not glow on low setting.
You can adjust the heater on to higher settings but this should be done gradually - no more than 2 settings at a time.
Some warnings:
* The unit must be correctly earthed.
* Do not use anything except heater oil.
* Never attempt to re-light the heater when it is hot.
* If the red light does not appear when the oil knob is switched on, immediately turn the oil knob off. Reasons include: Heater is too hot; Electric plug turned off; failure of ignition system.
Good luck - no responsibility taken for the advice (but it is largely copied from my Vulcan heaters instruction manual which I still have (installed in 1967).
Mar 26, 2008 | Heating & Cooling
How do i set the clock ?
I HAVE TRICITY SOVEREIGN4638 COOKER. I NEED TO REPLACE SPRINGS ON TOP OVEN DOOR, HELP. ALSO NEED TO REPLACE LIGHT TUBE ON FRONT PANEL.
PERSON WITH SETTING CLOCK, HOLD ALL BOTTOM ROW OF BUTTONS AND TURN TIMER KNOB ON RIGHT. PLEASE ADVISE
Apr 01, 2007 | Tricity Bendix SE454 Electric Kitchen...
Heating & Cooling Logo
Top Vulcan Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Vulcan Heating and Cooling Expert? Answer questions, earn points and help others
