I have a sony s-master projection hdtv with surround sound. It wont come on, when u turn it on the button turns green an then flashes 3/4 red lights an the button cuts off.but ut will make a sound when u turn the power button on like a fan or something cuts on then the lights on the power button does what I said an then the lights cut off an nothing els happens.
SOURCE: Sony KF-WE50
my front panel sound is not working.......?
how i can do this.?
Posted on Jan 05, 2008
welcomejee
  • 10594 Answers
SOURCE: TV powers off after 10 seconds of powering on....
Thats great, Please rate solution.
Posted on May 19, 2009
  • 336 Answers
SOURCE: Sony bravia KDF-E50A12U rear projecion tv wont turn on
Hi it sounds like it could be an issue with board that powers the lamp ,it's called the ballast.When you put a new lamp in the ballast has to provide more power ,when it starts to go weak it will not light up.Sometimes you can put your old lamp in and will work fine.Try partstore.com they might have it right there.Hvae a blessed one!
Posted on Mar 02, 2010
SOURCE: I have a Panasonic PT-56LCZ70 LIFI? Projection
Did you ever solve this problem? I have the same problem with mine now and it's only 2 years old. Thanks
Posted on Jul 16, 2010
welcomejee
  • 10594 Answers
SOURCE: Suddenly turned off without warning Sony KDS-50A2000
Symptom shows tv needs lamp replacement as existing lamp is reaching to end of its working life and causing that problem.
If you have not replaced lamp in last 2-3 years, replace it to fix the tv issue. I can explain why tv shuts down itself and turns back on.
I do not agree with info provided about bulged capacitors in power supply so please do not take off back of tv unnecessarily.
Lamp replacement procedure would be written in user manual and let me know if you need to download manual copy.
Thanks.
Posted on Jul 23, 2010
Power light is red and flashing. when we press the power button it sounds like it's trying to power on the light turns to flashing green for a few seconds and then the power cuts off and turns back to...
Flashing red light in Sony tv indicates that tv got some internal problem and went on protection mode to avoid further damage. Now it needs service/ repair.
Blinking red light also has an error code that has info about possible cause of problem, let me know how many times red light is blinking after 3 seconds ling pause and model number of your tv to provide you helpful info.
Thanks.
Feb 23, 2011 | Sony KDS55A2000 55" HDTV
The tv made a pop sound and now it wont turn on ans both green and red buttons are flashing ..please help
I had the same problem guys! This is what I did:
My T.V. wouldn't turn on. The standby light was flashing six times, then four, then seven...I called Sony and they told me to unplug it for a couple of minutes, then try it again...didn't work....BUT, I have found a solution:
Try unpluging your T.V. for 4 hours+, then turn it back on. Worked for me! It's called a "hard reset" by sony. I had my T.V. unplugged for the whole day though.
Aug 11, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Sony wega kp51 turns on for 3 secs than off w/ blinking red light
The flashes are fault codes. It means your system is faulty. If it is intermittent then it is more than likely a dust issue. Buy an air duster, spray out the back and restart. Should be fine
If it continues to play up then it will be a repair job
Dec 08, 2008 | Sony KP-51WS520 51" Rear Projection...
60 inch sony wega tv
Green flashing is normal. Red flashes are error codes. Count the error flashes.
3x - Lamp cover position or cover detect switch bad.
4x - One or more fans failed RPM test
5x - Lamp power supply/ballast failure
6x - Thermal fuse failed (usually)
Oct 16, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
ON/OFF button (red - off and on - green) flashing all the time
it is important to count the number of red flashes, if it is 5 then the lamp ballast board has failed, (part #1-468-798-14) if it is 4 then the optical block fan (# 178706511) is probably to blame, if it is 6 then the thermal fuse has gone bad..(# a1137954a)
Nov 28, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
