Question about Building Materials
My garage door starts down then goes back and the motor light flashes 10 times. The owner's manual only refers up to 6 flashes.
Cleaned the eyes. I can close it by holding down the wall door control button.
    Master:
  • 966 Answers
Richard, what is the make of your GD Opener unit? However, make sure the antena wire on the unit is turned up. 2. sometimes direct sun on the sensors prevent operation from the remote. 3.adjust sensors on both sides making sure the green or red lights are on.4. check the remote battery ensuring red light works when you press the remote button. 5. finally, has on vacation switch on the unit has not been switched on. GL
Posted on Dec 01, 2014
rulds2008
  • 3866 Answers
SOURCE: Problem with Sears Garage Door Opener
The motors is cought on something check the motor if it moves inches it will move a yard the question is the motor is it getting power? if so is it stuck on its own drive chain? Check these things you be glad you did.
Posted on May 25, 2009
lobsterman72
  • 91 Answers
SOURCE: Door will only close when held down
That normally happens when the sensors aren't aligned. Both sensors have led lights on them the yellow/orange one will stay on all the time the green one will go out if it cant see the other sensor. Possibly theres a wire that's broken or the other sensor is really out of alignment. Check every inch of wiring from the sensor to the opener, remove wire nuts if present and check the connections. The wires that are used are small, solid and can break easily. Also see if there's a staple that's too tight, move the wire abit where it's stapled and look for damage.
Posted on Jun 27, 2008
  • 11 Answers
SOURCE: Chamberplain Garage Door Opener problem
IF U HAVE TWO EYE,SENSORS ON EACH SIDE OF THE DOOR SEE IF SOMETHING IS BLOCKING THE EYES OR SOETHING IS COVERING THEM, OR THEY ARE OUT OF ALIGNMENT, ONE SHOULD SHOW GREEN, AND ONE RED EYE, GOOD LOCK
Posted on Jan 25, 2009
  • 3197 Answers
SOURCE: Sear garage door wall mount contol light keeps blinking
Hold the button with the lock icon in for 3 seconds. This should toggle the unit off vacation mode and your remotes will work.
Posted on Jun 01, 2009
swolfinor
  • 504 Answers
SOURCE: The garage door will only go down if I hold the
HOLDING DOWN THE WALL BUTTON OVERRIDES THE SAFETY EYES.
WHEN HOLDING IT DOWN MAKES THE DOOR CLOSE PROPERLY THE PROBLEM IS IN THE SAFETY EYES.
ARE BOTH LEDS ON? - CHECK FOR A LOOSE OR BROKEN WIRE.
ARE THE EYES WIRED CORRECTLY?
ARE THEY AIMED AT EACH OTHER?
Posted on Jul 18, 2010
The door is going down within about two inches of the floor and then goes back up. It has been doing this occasionally for the past few weeks, but now it will not stay down. The light flashes 10 times each...
Anytime the light flashes 10 times when the door reverses to the open position it is a door sensor problem. Make sure the small light on each sensor is lit and not flickering. Tweak them a little. If you cannot get both lights to come on you have bad sensors.
Sep 16, 2011 | Sears Craftsman LiftMaster Chamberlain...
I follow all your tips, but even due the garage door does not close because the sensors at the bootom of the rails are not align. I check high, eye dust, power, sensor ligths. But i do not find the way to...
If the main light on the motor unit flashes 10 times when the door reverses it is a door sensor problem. If not it could be the RPM sensor that is causing your problem. This is a small circuit board just in front of the motor. Try increasing the down force first. This is a control on the rear of the motor unit.
Jan 10, 2011 | Sears Craftsman LiftMaster Chamberlain...
Chain removed or on - eyes aligned and both eye lights on - button starts cyclemotor runs short while and then reverese - no limits have been reached - even removed the ''middle limit arm'' and still...
If the main light flashes 10 times when the door reverses it is a door sensor problem. Make sure neither light on the sensors is flickering ever so slightly. Sometimes hard to see. If the main light doesn't flash 10 times then it is probably the RPM sensor board. This is a small printed circuit board just in front of the motor. It's job is to reverse the door when it runs into something on the way down but it will give this problem when it goes bad.
Feb 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door goes part way down; goes up before getting a 1/4 way down
If the main light flashes 10 times when the door reverses it is a sensor problem. If the door starts down and then reverses but the main light does not flash it is most likely the RPM sensor which is a small printed circuit board just in front of the motor.
Sep 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
3.75 craftman garage door goes down a foot then immediately reverses back up
If when it does this your main light flashes 10 times it is the door sensors. Make sure they are aligned properly. If the main light doesn't flash 10 times then you most likely have a bad RPM sensor board. It is a small printed circuit board just in front of the motor.
Jun 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
5 blinking lights
The code for 5 flashes is RPM sensor or motor overload. Did you remember to put the black plastic interrupter cup on the end of the motor shaft? Also check the small quick disconnect on the RPM sensor printed circuit board. Make sure it is connected securely.
May 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Pressing remotes the door won't go u[
It sounds like you have the lock enguaged. When it is flashing it locks out all remote access. Hold the lock button for 3 seconds. The green light should go solid. On the issue of closing, it is most likely a safety eye issue. Hold down the wall button. If it closes it is the safety eyes. Holding the button overrides the safety eyes. Make sure that thelight on both eyes are both lit.
Jan 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
Motor moves 5 in" and reverses and light blinks 5 times
In the manual it says if you can hold the wall button down & door closes. You have a short in the wiring to the reciever eye. Try substituting some new bell wire in its place, or test the wires for continuity.
Jan 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
GARAGE DOOR OPENS BUT WILL NOT CLOSE AUTOMATICALLY
is bulb on motor flashing 10 times. then you have electric eye problem. otherwise, sounds like you need to increase down force a hair. adjustement is on logic board, right knob.
Jan 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
85 people viewed this question
Top Building Materials Experts
hpgwva
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
