Question about Hotpoint RGB745 Gas Kitchen Range
Can't seem to access Hotpoint Stove Pilot Light?
I am wondering how I'm supposed to light the pilot on a Hotpoint stove. I think I'm supposed to lift up the cooktop, but I can't get to lift up. It feels like its locked/screwed down somehow but I can't tell where it would be. The exact model is RGB745WEA7WW.
    Habit-Forming:
  • 17 Answers
See above also stove must be plugged into electricty for the ignitor to work.
Posted on Dec 05, 2014
  • 26 Answers
Your range uses electronic ignition, not pilot lights. For surface burners the igniter sparks when the gas valve is turned to the "light" position. All burners should spark when any gas valve is in the light position. For the oven the ignitor is also electric but does not spark but rather heats up or glows. What is the problem with your range?
Posted on Dec 01, 2014
  • Leland Dodd
    Leland Dodd Dec 02, 2014
    Thanks for the info. The burners were not igniting. It turns out that the gas line leading to the stove needed to be tightened. Works perfectly now.
gwshaw71
  • 83 Answers
SOURCE: ge xl44 I think pilot not lit. no more snap - snap and does not light
relace spark module if no snap snap from all burners.If one is just bad replace ignitor.
Posted on Dec 08, 2007
  • 619 Answers
SOURCE: Oven Pilot
open at the back cover , unscrew bulb /bring sample to appliance center , screw the bulb ,test oven then ok.
Posted on Jan 05, 2008
appldoctom
  • 311 Answers
SOURCE: Hotpoint RGB524 pilot won't light
sounds like you have a standing pilot system.if so and you have turned up the adjustment screw and no better .you will have to replace the pilot tube assemblie
Posted on Dec 31, 2008
SOURCE: Hotpoint electric stove (older model push button) quit working
Did this solve the problem I have the same problem
The surface burner light goes on but the burners only get
slightly warm
Posted on Nov 12, 2009
SOURCE: I can't find the pilot light on my Hotpoint gas
Depends which pilot light you're talking about. There are two for the hobs and (I assume) one for the oven. I can't find the one for the oven, hence why I'm on here looking through forums (a..?)
Cheers.
Posted on Apr 03, 2010
Hot point has 2 pilot lights on top... light them... then go to oven and light that one... it is a safety feature... no pilot on top kills the pilot in the stove.
.. since gas is heavier then air the company made sure if there was a gas leak on top that it would not be caught by oven and blow up.
Nov 30, 2014 | Hotpoint RGB745 Gas Kitchen Range
Can't seem to access Hotpoint Stove Pilot Light? Also is there a second pilot light for the oven?
For the last 10 years or more there are no pilot lights on gas ranges. Modern ranges have an electronic igniter on the burners and a different type on the oven.
Right, front flat burner does not light and barely heats. My Hotpoint stove is five years old and gets very little use. What's wrong? Can I fix it? Can you help?
Hello and Welcome to FixYa!
Please provide us with the model details of your unit and What exactly, you are facing. Is the burner properly getting the supply. And is it partially lighting or didn't lighting at all. Is the unit repaired ever since the problem started? Some details of the trouble, you are facing, will help suggesting more precise solutions to the problem,
Feel free to Ask,
Concerned.
Jul 15, 2011 | Hotpoint Kitchen Ranges
I smell gas and my burners wont light - is there a pilot light in these ranges?
The best way to find out if if your stove has a pilot light, is to lift the top panel of the range . The pilot will usually be located between the burners. Typically you will have two pilots. One for the left and one for the right. The pilot light will ignite with a match without having to turn the burner knobs to the "on" position. Good luck
May 20, 2010 | GE Spectra JGBP35 Gas Kitchen Range
My gas was recently shut off for repairs from the gas company, now its back on and i dont know how to get my oven or stove back on
Ok you did not mention if your oven or stive had pilot lights or igniters. Given you asked the question how too turn it back on I have to assume it does not have electronic igniters. You need to light the pilot lights. There are 2 in top that are between each of the 2 burner sets. If you can not gain access to the pilot light by lifting the top of the stove up you can use a fire starter type lighter and re-light them. Sometimes they will self light if you just use a match on the burners.
As for the oven you can gain access 2 ways to the pilot light. One is to unlatch and remove the oven lower inside panel. The pilot light will be near the burner head. Just light it. The other is to remove the broiler drawer and reach way back in there to light the pilot light.
Again if you have igniter ignition all you have to do is turn on a burner or the oven. Good Luck.
Jan 22, 2010 | Ovens
Getting to the Pilot
Your model JGBP28DED2WH uses spark ignition on the stove top burners, and a glow bar ignitor, part number WB2X9154 for the oven and broiler. To get to the bake ignitor if oven will not light: Take the racks out of the oven. Remove oven floor by removing two screws at back of oven floor and lifting floor. Remove the square metal flame spreader to get to the burner / ignitor assembly. (note: The ignitor may still glow when you try it, but usually is still the problem)
Feb 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Dec 31, 2008 | Hotpoint RGB524 Gas Kitchen Range
Pilot light
Ok the OVEN pilot light is located in the broiler part of the over (at the bottom) If you open the broiler and get a flashlight you will see the pilot light unit for the over at the rear on the top. What a cheap piece of **** these Galaxy ovens are.
Nov 21, 2007 | Sears 61301 Gas Kitchen Range
Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Aug 14, 2007 | Tappan TGF363 Gas Kitchen Range
Hotpoint RGB745 Gas Kitchen Range Logo
151 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
