Question about Hotpoint RGB745 Gas Kitchen Range
I am wondering how I'm supposed to light the pilot on a Hotpoint stove. I think I'm supposed to lift up the cooktop, but I can't get to lift up. It feels like its locked/screwed down somehow but I c
The exact model is RGB745WEA7WW.
    Sergeant:
  • 253 Answers
Hot point has 2 pilot lights on top... light them... then go to oven and light that one... it is a safety feature... no pilot on top kills the pilot in the stove.
.. since gas is heavier then air the company made sure if there was a gas leak on top that it would not be caught by oven and blow up.
Posted on Dec 02, 2014
4 Suggested Answers
appldoctom
  • 311 Answers
SOURCE: Hotpoint RGB524 pilot won't light
sounds like you have a standing pilot system.if so and you have turned up the adjustment screw and no better .you will have to replace the pilot tube assemblie
Posted on Dec 31, 2008
appldoctom
  • 311 Answers
SOURCE: Hotpoint RGB745 - how to lift cooktop panel to clean underneath?
hey thats not a hard one for you.kill the power to your range [breaker ok]under neath the cook top frount where the top of oven door meets the cook top.in there are screews into the cook top .remove and lift up cook top it is hinged in the back .clean ,then put back together.you got it God bless ,tom
Posted on Jan 06, 2009
SOURCE: I can't find the pilot light on my Hotpoint gas
Depends which pilot light you're talking about. There are two for the hobs and (I assume) one for the oven. I can't find the one for the oven, hence why I'm on here looking through forums (a..?)
Cheers.
Posted on Apr 03, 2010
Is there a pilot lite I need to light for my stove ffgf3011lw
Some stoves have pilot lights, some have an electronic igniters. If you hear a click, click, click when you turn on the gas, you have igniters.
Dec 06, 2014 | Frigidaire 30" Freestanding Gas Range -...
Can't seem to access Hotpoint Stove Pilot Light?
Your range uses electronic ignition, not pilot lights. For surface burners the igniter sparks when the gas valve is turned to the "light" position. All burners should spark when any gas valve is in the light position. For the oven the ignitor is also electric but does not spark but rather heats up or glows. What is the problem with your range?
Nov 30, 2014 | Hotpoint RGB745 Gas Kitchen Range
Can't seem to access Hotpoint Stove Pilot Light? Also is there a second pilot light for the oven?
For the last 10 years or more there are no pilot lights on gas ranges. Modern ranges have an electronic igniter on the burners and a different type on the oven.
Right, front flat burner does not light and barely heats. My Hotpoint stove is five years old and gets very little use. What's wrong? Can I fix it? Can you help?
Hello and Welcome to FixYa!
Please provide us with the model details of your unit and What exactly, you are facing. Is the burner properly getting the supply. And is it partially lighting or didn't lighting at all. Is the unit repaired ever since the problem started? Some details of the trouble, you are facing, will help suggesting more precise solutions to the problem,
Feel free to Ask,
Concerned.
Jul 15, 2011 | Hotpoint Kitchen Ranges
I smell gas and my burners wont light - is there a pilot light in these ranges?
The best way to find out if if your stove has a pilot light, is to lift the top panel of the range . The pilot will usually be located between the burners. Typically you will have two pilots. One for the left and one for the right. The pilot light will ignite with a match without having to turn the burner knobs to the "on" position. Good luck
May 20, 2010 | GE Spectra JGBP35 Gas Kitchen Range
No spark to ignite gas on cooktop
Shut off the stove. Then lift up the range top and you will see pilot lights. Remove the cover on the pilot lights. They could be blown out, but usually they are just dirty. Take a pin and poke it through the hole, then carefully scrub the tubes with a brush that go from the range to the pilot light. When your done with that....use a long match and light the pilot light, make sure no gas is on when you do this. No flames will come out, but it doesn't hurt to be extra careful.
This just happened to me so good timing!
Hope this helps
Sep 10, 2009 | GE Profile JGP636 Gas Cooktop
I have a brown brand gas stove and the oven is not coming on stove has no electical cords
hello. i can help. here is the manual for your stove. http://www.brownstoveworksinc.com/pdf/gas_manual.pdf
look on page 17 as it tells you how to light the pilot light.
Jun 05, 2009 | Brown Stove Works 23 in. TL03-3 Gas...
RAnge top that you cannot lift up...pilot light is out
no pilot light if you have a ge JGBP90 GE range ...most newer cooktops do not have a pilot light .. be have a direct igniter...do they click or make a snap sound..
You may not have power to the unit... let me know
Dec 13, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Pilot light
Ok the OVEN pilot light is located in the broiler part of the over (at the bottom) If you open the broiler and get a flashlight you will see the pilot light unit for the over at the rear on the top. What a cheap piece of **** these Galaxy ovens are.
Nov 21, 2007 | Sears 61301 Gas Kitchen Range
Hotpoint RGB745 Gas Kitchen Range Logo
142 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
