Question about Pioneer Audio Players & Recorders
My pioneer receiver powers on but the volume doesn't work. Why is that??
Model # is Pioneer VSX 822
    Scholar:
  • 82 Answers
Does this receiver function as only a tuner or does it have speaker outputs? If it has speaker outputs, then there might be switches for turning them on and/or if 5.1 surround sound, sometimes there is a bridge on the back so extra amplification can be added and if that bridge is missing, the tuner signals are sent on to the internal amplifier. On one of mine, that bridge was a 2 wires bent to fit into RCA jacks on the rear of the unit.
Posted on Dec 01, 2014
  • 979 Answers
SOURCE: pioneer vsx-d307
You have a flashing "mute" on the display?...accordianman
Posted on Nov 26, 2007
Clockguy2
SOURCE: PIONEER VSX-D411 RECEIVER
Here's a link to the owners manual:
http://www.manualnguide.com/manual-get/6009/
Posted on May 16, 2009
  • 30 Answers
SOURCE: Pioneer VSX-D411 receiver "Amp Error" message
Unfortunatelly your receiver has failed. The front panel is telling you one of the power modules is probably bad. Not an DIY type of repair. These parts are near $40.00, plus cost of replacing.
Look at options to replace your trusted receiver with a new one.
Good luck
Posted on Aug 02, 2009
  • 4 Answers
SOURCE: Pioneer VSX-816
With the receiver off, press ENTER + ADVANCED SURROUND keys continuously for 2 sec. and it will tell you the fault it encountered. Even if it has a short, it will still protect the speakers; however, it is still a good idea to disconnect all speakers before doing this.
Posted on Aug 12, 2009
  • 35 Answers
SOURCE: Pioneer Amp VSX-D409 Volume
I have a VSX D508 Looks just like the VSX D409. Had the same prob with the volume control when I bought it. I first tried the cleaner. Better than what it was but didn't compleatly solve the problem and before long it was getting worse again.
It does have a rotary encoder instead of the traditional varible restance volume control. I finally broke down and removed it from the board and lightly sanded the contacts with fine sandpaper.
This involves removing the whole face from the main board and chassis. Not that bad, a couple screws and some ribbon jumpers and latches and it's off.
Next carefully pull the volume control straight off the shaft, remove the nut under it and lay it face down on a soft surface. Remove the screws that hold the circuit board to the face and slowley seperate the too, you'll have to release some latches also to sepperate them.
If you replace the volume control with a new one or clean the old one you have to go this far because it's soldered to the front side of the board. Yes, it has to be de-soldered from the board.
This control was not designed to be dissassembled but I was able to carefully open it and remove the shaft to totaly expose the contacts for a complete even couple of passes with the sandpaper.
I did have to use some 5-minute opoxy when I put it back together because I couldnt get the metal tabs to close as tightly as they were before it was opened.
I soldered in the volume control, put it back together and it's worked perfectly ever since. I don't know how much pioneer wants for a new one but I can tell you they wanted $69 plus shipping for a new remote for my receiver. And with this style of volume control you might be at their mercy as far as finding one from another source that fits.
Posted on Apr 03, 2010
Whats the problem?
It's a safety , possibly your volume is cranked up too high or you could have something hooked up wrong
Feb 18, 2015 | Pioneer VSX-822-K
Pioneer VSX-60 Volume Decrease each 2 min
it's a somewhat common problem with that model. It needs a new cpu board.
Apr 21, 2014 | Pioneer Elite VSX-60 7.2 Channel Network...
Pioneer vsx 822 k shuts down when i turn up the volume
Could be caused by a bad speaker, try disconneting speakers and see if it still happens.
Jan 10, 2014 | Pioneer Vsx-822-k 5.1-channel 3d-ready...
Pioneer VSX-822-k Subwoofer problem
Go to manual setup, selct the subwoofer and set it to Pus.
Jul 29, 2012 | Pioneer Vsx-822-k 5.1-channel 3d-ready...
My pioneer pl-200 doesn't play loud enough through my pioneer vsx-521-k receiver
The PL-200 has no pre amp and your VSX-521 has no phono input. You need an RIAA preamp.
Jul 11, 2017 | Pioneer Vsx-521-k 5.1 Channel A/v Home...
Pioneer vsx-d810s only dvd 7.1 input works and static on all other inputs
Try resetting the receiver the Pioneer Web site should have the reset procedure for your model if that doesn't work time to send to the shop.
Oct 03, 2011 | Pioneer VSX-D810S Receiver
How to connect a kenwood ka- 9100 to a pioneer vsx-d608
You don't say, what role the Kenwood is supposed to play but I'll assume you want to slave the Kenwood (and its speakers) to the Pioneer.
The VSX-D608 doesn't have multi-channel pre-outs so you wouldn't have local control of the volume at the Pioneer.
http://www.auctiva.com/hostedimages/showimage.aspx?gid=108365&ppid=1122&image=404270323&images=404269872,404269931,404269984,404270049,404270137,404270323&formats=0,0,0,0,0,0&format=0
The KA could be a subwoofer amp as the Pioneer has a pre-out for that.
Outs to Ins. "Power In" on the KA would be for an external volume-controlled source. Otherwise, use one of its non-Phono inputs.
http://tubehacker.com/sale_item.php?item_id=31
May 29, 2011 | Kenwood Audio Players & Recorders
113 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
