Question about Onkyo TX-SR506 Receiver
How do I fix my receiver if it is shorting out
Receiver keeps shorting out and goes to stand by mode what do I do?
  • Official Brand Answer
  • 333 Answers
Please contact our Parts & Services Dept at the number listed below during normal business hours Monday-Friday 9am-5pm EST ; or via email at parts@us.onkyo.com. They can be contacted at 201-785-2600, option # 4 for Parts & Services as they can further assist you regarding warranty and service issues. You will need to speak with the Parts & Services/ Warranty department for any servicing options or resolutions available for your issue.
Posted on Apr 17, 2015
    Habit-Forming:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 166 Answers
Units going into protect due to fault - try turning unit on without speakers if unit is ok check speakers
Posted on Dec 01, 2014
5 Suggested Answers
tech48
  • 624 Answers
SOURCE: Onkyo HT-5500 Receiver goes into
This sounds like it has a microprocessor problem. Try unplugging it from the wall and leave it overnight. That will give the microprocessor a chance to reset and then try it again. If it continues to do the same thing, you need it serviced by a professional technician. I am sad to say, there are no easy fixes for a microprocessor problem.
Onkyo receivers are very good quality and are normally worth getting repaired. If it were junk I would tell you to just buy a new one. But even the very best equipment can fail. I have been repairing audio equipment for nearly 18 years and have never seen any brand that did not have some type of failures at some time or another. Onkyo's may not be the most expensive receivers, but they are some of the best engineered receivers I have worked on.
I hope this helps you decide what you are going to do, and hopefully after the micro is reset, it will work good again.
Let me know if you need any more help.
Dave
Posted on Jul 18, 2008
  • 4234 Answers
SOURCE: receiver keeps turning on and off also the standby mode blinks
The receiver is going into "protect" mode. This means that a problem has been detected and the unit shut down to prevent further damage. Without seeing the unit and taking some internal measurements, it is difficult to provide a complete solution. Typically, the output transistors fail which can cause this. There are other possibilities too. I would suggest that you get a detailed repair estimate from a local shop. With that information, we may be able to walk you through the actual repair.
Dan
Posted on Oct 15, 2009
  • 4234 Answers
SOURCE: Receiver goes to stand by when turned on. All
This is most likely a "protect" mode. A problem has been detected and the unit shuts down to prevent further damage. The most common cause of this are defective output transistors. Plan on a parts cost of $25-$40 for this repair.
Dan
Posted on Jun 15, 2010
  • 444 Answers
SOURCE: receiver desplay on my onkyo tx-sr 876 receiver keeps flashing and goes of arter it has been on for a while
Internal problem with amp, Might have been damaged buy a power (Surge)
Posted on Nov 03, 2012
My receiver is shorting out and goes to stand by mode
units going into protection due to fault in unit or speakers
Nov 30, 2014 | Onkyo TX-SR506 Receiver
AVR 270 Receiver turns itself off immediately
Disconnect all speakers from Zone 1 and see if it stays on. If it does, you have a short on a speaker (probably cable). If not, you might have a blown output transistor on Zone 1. I have a DENON that I am fixing that does this, but only when I turn up volume. Creepy. Good luck !
Jan 22, 2014 | Harman Kardon Audio Players & Recorders
While watching satellite tv, receiver will work fine for a good while (an hour or more), then you begin hearing what sounds like static in the right front channel, followed shortly after by the receiver...
Sometimes equipment gets too hot and starts glitching. Try an improve cooling and air circulation. Often standing the thing on one end so it's tall will help keep it cool. See if it goes for longer with better cooling.
Oct 29, 2013 | Denon AVR-1911 Receiver
I touched speaker wire from the receiver to hot wires on my subwoofer and everything shut down, now the receiver will not power on. When I push the on button I get a click noise, but if I keep trying to...
When the speaker wires were shorted it would have damaged the output and so there is a short in the output circuit thereby the amplifier goes into the protect mode. So remove the power and the speakers, reset and test again without the speakers. If the amp goes to the protect mode then you need to have assistance to check the boards within for a short. sometimes it is difficult to probe for a voltage check and so will need jigs to test.
Check the output drivers for short using a multimter, check for the rail voltage to the outputs or there can be a power issue.
Oct 07, 2011 | Yamaha RX-V550 Receiver
The receiver will be on for a while 5mins.or so, then it will make this loud sound as it goes into protector mode...what is this and how do I fix this. I have it connected to the TV, DVD Player, CD, VHS...
you have speaker wires that are shorting out. unhook all the wires and ohm them out. Find out which one is shorting. I've had this problem before. It's fine until you turn it up, Then the receiver turns off and goes into protect mode. It's just a short in the wiring,.
Dec 08, 2010 | Sony STR-DE835 Receiver
Protect appears on display on kenwood kdc 3034
Disconnect all the speaker wires at the receiver and turn it back on. If itdoesn't go into protect mode, your receiver is ok.
Reconnect the speakers one at a time being sure to turn the receiver off each time you connect a speaker and turn the receiver on until your receiver goes into protection mode again.
When it goes into protect mode again, the last speaker you connected has a problem. Trace the speaker's wire to the speaker looking for cuts or shorts along the way.
If you have a multimeter, switch itto ohms and check the speaker for a dead short, if you show a dead short you have a blownspeaker. Hope this helps.
--Matt
Oct 07, 2009 | Kenwood Car Audio & Video
Is in protect mode
I don't have and I'm not familiar with this particular receiver model, but common sense tells me that your receiver is trying to alert you to the fact that you may have shorted speaker wires, and it has gone into protect mode, to prevent itself from blowing up.
Please check your wires at the back, or best yet, if your receiver has a test mode on the remote control, use it. It tests your speaker connections for shorts, for wrong polarity, etc. If this receiver has surround sound, and all speakers are connected, it goes round and round creating some white noise from all speakers as it goes, until you press the Test button again.
Should one or more be connected improperly, or the wires be shorted, it will display a message telling you so.
Aug 21, 2009 | Sony STR-DE485 Receiver
I can not control the mute or volume with the remote through the Sat mode. It only works through the aux mode. It is connected to a Onkyo receiver.
Dish remotes are set up to operat between SAT and TV mode simultaneously to control these features on a stand alone TV once you introduce the receiver you lose that ability as it is a seperate piece of equipment. You could try entering the code for the receiver to the TV button but I personally have never had any sucess with that approach. In short you are stuck using the remote as you are currently or are left with purchasing a universal remote. Thanks for using Fix Ya,
May 06, 2009 | DISH Network 311 DTV Receiver
Power shuts off after 2 or 3 sec.
please remove all speaker from receiver-volume down and test if the receiver shut down it needs to fix in service center-if not insert speaker one by one until you find the bad one-change its cable first and then change speaker itself.
Nov 29, 2007 | Marantz SR-5200 Receiver
Stand By Mode
same here ,men , i start the tearing apart hehehe, and i think it can be one the little chip located behind the control panel so i remove the white ribbon, the one looking like an ide connector for a hard drive, and guess what it turns on, but when you connect the ribbon just goes back to stand by mode, maybe requires a flash on one of the little chips, same thing happen to a lap top that i use to have, just shorted 2 of the pins and start working normally, im gonna find more info but there sems to be nothing about this amp, high five from mexico men
Jan 20, 2007 | Philips FR965DHT Receiver
Onkyo TX-SR506 Receiver Logo
112 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
