Question about Hard Computers & Internet
My Question Preview: Problem with Hard Drives having trouble cannot get microfix usb digital microscope to work Problem with Hard Drives having trouble cannot get microfix usb digital microsco
Problem with Hard Drives having trouble cannot get microfix usb digital microscope to work cannot create file c;\program Files(x86)MicroCapture\mv.db". Access is denied
  • mick connolly
    mick connolly Dec 01, 2014
    I have got administrator rights
    Sergeant:
  • 268 Answers
You must have administrator rights to access this folder.
Posted on Dec 01, 2014
Testimonial: "i have administrator rights the problem is when i plug the micro camera in it does not work"
  • mick connolly
    i have administrator rights the problem is when ii plug the micro camera in it does not work
  • Van Allen II
    Van Allen II Dec 01, 2014
    There should be a :, not; after the c in the path, c;\program Files(x86)MicroCapture\mv.db
micromaster
  • 3614 Answers
SOURCE: error copying file or folder
One of the most important yet overlooked elements of PC maintenance is data backup. If you do not perform regular backups, chances are your productivity will eventually suffer from data losses or a failed Windows installation.
All versions of Windows after 3.1 ship with a free backup utility called Microsoft Backup. It is not the best backup program available, but it may be sufficient for your needs. (Backup is better in later versions of Windows. Microsoft recommends Win98/Me users purchase a third-party utility.) If you want more control over your backups, consider purchasing a third-party program.
Backup is part of the System Tools utility. However, Setup does not install it by default in Win98/Me/XP Home. If you cannot locate Backup, visit the Microsoft support site and query for article No. 152561 (Win98), No. 264541 (WinMe), or No. 302894 (WinXP Home).
In Win98/Me, click Start, select Programs, Accessories, System Tools, and click Backup. To create and run a backup, click the Create A New Backup Job radio button and click OK. Follow the prompts to create a full or partial backup. If you want to create a backup set and run it later or run an existing backup set, open Backup and click the Open An Existing Backup Job radio button and click OK. You can now access the main Backup dialog box.
In Win2000/XP, navigate to the System Tools utility and select Backup. Click the Backup Wizard button. If you do not see a Backup Wizard button, click the Welcome tab. In WinXP, the wizard will start automatically if you are in wizard mode. Follow the prompts to create your backup set.
When you reach the last dialog box, Completing The Backup Wizard, you can click the Advanced button to create a backup schedule (this option is not available in Win98/Me). When you reach the When To Back Up dialog box, select the Later radio button and click the Set Schedule button. Perform data backups on a schedule that is appropriate to the importance of your files (once a week is a common timeframe). You should also perform a system backup at least once a month.
If you do not want to use the wizard, or you are working with an existing backup, open Backup and click the Backup tab to access the main Backup dialog box.
Posted on Feb 11, 2008
  • 82 Answers
SOURCE: getting files off an old IBM TravelStar 20 GB Hard Drive
You can buy an adaptor that will connect your hard drive to a pc.
Ribbon cable from your secondary drive on pc goes into the adapator. Adaptor also coonects to laptop harddrive.
You also need to change from being a master driveto be a slave drive . see linkbelow.
http://www.hgst.com/hdd/support/tva/tvajum.htm
You can then copy file to pc a usb memory stick.
Posted on Oct 13, 2008
efs_perpends
  • 1996 Answers
SOURCE: My XP PC won't recognize portable Western Digital hard drives
Not sure how to help without knowing what hardware you're using to read the drives.
But here are a couple of links from WD that may prove helpful...here and here.or here.
I'd look for something similar on the support site for your device.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jun 15, 2009
bob_computer
  • 3153 Answers
SOURCE: WD5000- I can't save files anymore to the disk
A few things to check
1. ensure the drive is connected directly to the computer and not via a HUB
2. ensure you use the original cable that came with it (not one that looks the same)
3. remove as many other usb components as possible
4.check the power supply for the external drive if it has one
5. shut down and restart the computer
At this point you should be able to see and move files around.
If this is not the case and the drive is no longer under warranty you could try the following
remove the drive from its enclosure and mount it in a computer that has a suitable interface SATA or IDE. if you can now use the drive normally then the enclosure is at fault. If the drive cannot be used normally then the drive is at fault. If its the drive then it is either dying or dead.
Also you should ensure your antivirus is totally up to date and that you also have ANTISPYWARE software installed too and that your computer is clean from any nasty stuff.
If this information was useful please click
Posted on Aug 17, 2009
bschilz
  • 2049 Answers
SOURCE: Hitachi SimpleDrive 320GB: Error moving file: Access denied!
The problem may be that your Security settings for the drive are not configured to give you Full Control.
In Explorer, right-click on the Hitachi drive and choose Properties.
Go to the Security tab.
Find the User you are trying to use and click on it.
Under Permissions, click Edit and enable Full Control for that user.
That should give you the ability to do what you need to.
If Windows won't allow you to change the setting, it's because you don't have Administrator priviledges. In that case, log out and log back in as an Administrator and go back and make the changes.
Posted on Nov 04, 2009
Testimonial: "Hi bschilz, have try it out and it worked! No more error messages...Thanks ever so much!"
Cannot get microfix usb digital microscope to work
That's probably a Windows privileges problem; only the administrator can write to the Program Files folder. Log in to the computer as administrator, open the MicroCapture program, find the settings for the file locations, and set up a folder in your (User Name) Documents for the MicroCapture files. Alternatively, modify the permissions for the MicroCapture folder (not recommended; do this only if MicroCapture won't let you use a different location).
Nov 30, 2014 | Computers & Internet
Having trouble cannot get microfix usb digital microscope to work
You need to use "Run As Administrator" when installing the software, to allow the installing-software to write to the 'Program Files (x86)' folder.
Need a qx3 driver for mac
The miXscope software works great. It is $18 from:
miXscope Mac Microscope Software
The free Macam software works on older Macs with OS 10.5 (Leopard) but has trouble with newer versions. Give it a try:
macam USB webcam support for Mac OS
Apr 22, 2014 | Intel Play QX3 Monocular Microscope
How to recover my sd card back to 2gb
If the drive is not detecting at all then the controller chip inside has failed. The best way you can recover this is to find another identical unit and remove the memory chip (it will be the larger of the two) from both drives and solder the one from the faulty drive into the donor, you will need soldering experience and a hot air gun to remove the chips (do not head these up too much, only enough to melt the solder) You will ideally have a electronics microscope to see the small pins that will be soldered. If this sounds like too much work, you could send it off to a data recover company such as ours at Digital Recovery
Dec 21, 2013 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How do you open it
If the USB hard drive can be detected in 'my computer' as a drive letter(like E: drive) but you can't access/open it,you can recover data from USB hard drive with 3rd party data recovery program.
Tenorshare data recovery is a professional data recovery program that can recover data after deeply scanning your hard drive to look for lost data due to drives crash, physical damage,system sabotage, virus attack etc.Download it and scan your USB hard drive for free to preview whether your files can be recovered.You can get it here: http://www.any-data-recovery.com/product/datarecoveryprofessional.htm After you recover your data,you can format it to check out whether it can be fixed.
Aug 27, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Hard disk not detected sometimes
I can think of 3 possible causes to your problem:
1. Faulty cable - try replacing the cable by borrowing a working cable from a friend. If this solves the problem then you need to buy a new cable
2. Lack of power - some USB drives especially those for high capacity drives require extra power aside from that provided by USB. If you do not have a separate power leading to your drive, check if there is a separate power slot and run a cable from it to your outlet/USB slot. Just make sure that the voltage levels are correct.
3. USB Slot - some laptops' USB slots do not produce power enough to drive a hard disk. Other devices may work (e.g. keyboards, mouse) but not hard drives. Try to use another slot in your laptop. If this works, remember to use the same slot next time.
Hope this helps.
NOTE: Please rate our help to keep this free service online
Jan 08, 2010 | Western Digital External USB 2.0 80 GB...
Dropped my1TB EXTERNAL Seagate drive, now not WORKING
Probably nothing. Hard drives are delicate machines seeing as th have microscopic lasers that are held by a tiny little arm between the discs. If it fell hard, so will all your DATA
Dec 19, 2009 | Computers & Internet
When I connect WD 250 GB external harddisk ..I am getting error message" USB device Not recognized due to malfuction"..please guide me my laptop is toshiba and operating system is windows xp
Please trouble shoot by trying the device on another laptop.
If it works on another system, it simply means it is not compatible with yours and you have to get a device that is compatible with your toshiba system.
Good try.
Oct 17, 2009 | Western Digital WD Passport 250GB Portable...
Digital blue time lapse
Depending on the model of your USB, (1.1 or 2.0) it may or may not time out. With a 2.0 speed USB it will not typically tome out until about 30 hours of very high activity use. A 1.1, on the other hand can get to do that a lot. If your USB is a 2.0 get a computer expert to check that it is not malfunctioning. If it is a 1.1, I would suggest getting a USB upgrade.
Mar 26, 2007 | Digital Blue QX5 Microscope
Computers & Internet Logo
48 people viewed this question
Top Hard Computers & Internet Experts
Nyte_Ryder
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hard Computer and Internet Expert? Answer questions, earn points and help others
