Question about Pool & Spa
Why I can not turn my PC RoHs]
Cable connection. I move a red botton 115 I connected all the accessories, I connect to the ELECTRICITY, startup screen and NOTHING ON. My CONNECTION is cable and works fine on the other PC. Movi a red button marked 115v y 230v
  • 3,368 Answers
I am not sure what country you are in but in the USA it is 115.
Posted on Dec 10, 2014
4 Suggested Answers
KMusselmann
  • 247 Answers
SOURCE: got a waterway 1.5 hp 1 speed 115/230v, wired 115 need 230
Is there a coverplate where the wires come out of the pump? If so, remove the plate and there should be a wiring diagram inside.
Good Luck
Kurt
Posted on Mar 18, 2009
john224
  • 1378 Answers
SOURCE: switching my hayward pool pump from 230v to 115v
Setting the pump for 115V wont by itself cause the trip. There is either a ground in the circuit or the GFI is bad. You may want an electrician to test any further than this.
Posted on Jul 04, 2009
  • 93 Answers
SOURCE: Going from 230v to 115v on Super Pump
open back you will see the bars to hook to it should show which is the right side 3wire only for 115
Posted on Jul 13, 2009
Modem will not connect to a router
well this one is a combination model and router so is it the case that your computer is not connecting?
take an ethernet cable(usually blue or grey or yellow) and connect directly between computer and modem/router to see if your operating system can 'see' it
report back what you find
might need to turn off router and then connect and re power it again
May 30, 2012 | Arris SURFboard SB5101U DOCSIS 2.0 Cable...
I just purchased a acer h203h and when I hooked it to my computer it says no signa and light turns red.
Please check the video input selected, press Menu botton, the monitor will show you among other information the input selected, if indicates VGA, you must have connected the corresponding cable between your PC and monitor, if it indicates DVI and your computer doesn't have DVI port press the Input botton to select VGA.
Feb 22, 2011 | Computers & Internet
How do i initially install the sbg901 wireless cable modem
Locate the MAC id number on the modem. May be called the HRC mac id. Write this number down.
Connect the modem to an active cable outlet with a coax cable (the type that you would screw into the back of your tv).
Connect your computer to the modem with an Ethernet cable.
Connect the power cord and plug it into a power outlet.
Turn your computer on.
Call your cable provider and choose the options for tech support for internet.
They will need that MAC id number and then they should be able to set it up on your account and allow access to the internet.
Thanks,
Robert
Feb 12, 2011 | Arris SURFboard Gateway SBG901 DOCSIS 20...
Red blinking power botton
Turn off xbox 360 then try unplugging all the cables ( power cable and video cable/hdmi, etc ) then reconnect all, make sure its connected properly. Then turn on again.
Sep 16, 2010 | Microsoft Xbox® 360 Core System Console
I have a gateway desktop computer. Recently moved
Before you actually replace the power supply, check some other things first:
1. Wall socket
2. Power strip/surge protector
3. Power cable
4. On the back of the computer, where the power cable plugs into, is the red switch set to 115? It should be 115.
5. Make sure that the power cable is not connected to a regular extension cord. Power cable must plug directly into a surge protector that is not daisy-chained to another power strip, surge protector, or normal (household) extension cord. Surge protector must be directly plugged into wall socket.
If none of the above solve the problem, open up the case and ensure that all power connections are secure. Also check ALL other components' connections. Any loose connections can cause problems for you.
If everything is secure and the problem persists, replace the power supply.
Nov 27, 2009 | Office Equipment & Supplies
My power switch won't turn on and a green light on the back of the computer is blinking when the red switch is on the 115 and stops when on the 225. What do you think is wrong?
First off, the red switch is for 155 or 220 volts and should not be adjusted or moved from its position.
Now, disconnect the unit from its power source and allow to set for 3 minutes.
Re-install your power connection and do not push the power switch.
Look in the rear of the unit at the power supply and see if you have a green light.
If so, push power and have fun.
If not, you will need to most likely replace the power supply.
Good luck..
Nov 24, 2009 | HP Compaq Presario SR1303wm PC Desktop
Not recognized by cable modem
Turn everything off for 2 minutes, cable modem, router and pc.
Turn on modem and wait 2 minutes for the modem to sync to TW.
Turn on router after 2 mins and wait until the router syncs with the modem.
Turn on PC
It sounds like your router lost its connection to the cable modem, which happens from time to time. TW will not help with your router. I worked for a cable co and the router and modem losing sync was the at least 70% of the calls. FYI cable doesn't use DSL,just the phone co.
May 19, 2009 | Zoom X6 Adsl Modem/router Rohs...
Can't connect to an external monitor
It sounds like a faulty videocard which is probly built into the mainboard and would require a replacement main board which is expensive!!
Mar 22, 2009 | Toshiba Satellite Pro U400-S1001X Notebook
Pool & Spa Logo
32 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
