Question about KitchenAid KSM150PS Artisan Series Stand Mixer
I can't get the dough attachment off my Kitchenaid stand mixer. I have tried oil, filling up the bowl with soapy water and letting it stand overnight, pouring teapot after teapot of boiling water ove
I can't get the dough attachment off my Kitchenaid stand mixer. I have tried oil, filling up the bowl with soapy water and letting it stand overnight, pouring teapot after teapot of boiling water over the attachment opening... The beater won't budge, not a tiny bit. Could there be another explanation? Can I unscrew something to get to the root of the problem?
  • KitchenAid Master
  • 1,231 Answers
Hi Georgette
You need to encourage movement between the beater and the silver shaft it locks on to. There is nothing that you can unscrew to make it easier. Get a can of CRC and try & get it around the silver shaft at the top of the beater plus you should be able to get a bit in that side slot where the beater engages with that driving pin. Rock (twist) the beater side to side and slowly the grip will loosen and you will be able to encourage it off. Once you have it off you will need to clean out the CRC and polish up that silver shaft. Next is the more difficult part, you need to polish up that hole in the beater. What you are trying to do is remove the build up of flour in the hole so that it is pretty much shiny in there again without being significantly bigger than it was originally. I use a rat tail (round) file to do this job, you are just removing the darker build up in there. When done a good wash and dry and it will be like new again. Keep the hole clean of flour and it may not happen again.
Posted on Dec 01, 2014
  • KitchenAid Expert
  • 168 Answers
Looking at the dough hook where it attaches to the mixer'shaft, you will see that there is a slot where the shaft's pin secures the
dough hook. Normally, the dough hook is lifted and turned counter-clockwise to bring that pin in line with the vertical slot in the dough hook whereupon the dough hook slides down and off.
If this cannot be done, take the mixer to a good repair shop.
  • John Fink
    John Fink Dec 01, 2014
  • 10 Answers
SOURCE: oil coming out of mixer above bowl
Don't open up the "works" part of your mixer if it is still under warranty!!!! If the policy hasn't changed, you'll void the warranty by doing that.
KitchenAid has one of the best user forums of any company as far as I'm concerned. The participants are great and the monitors are exceptional (some of the best problem solvers you are likely to run across). You may find your experience already has a thread, if not, post it. I checked in and they seem to have added a video library that has some of the topics I've seen posted at this site. Tell them "mnme" sent you. (LOL)
http://www.kitchenaidconversations.com/
Posted on Feb 09, 2008
SOURCE: kitchenAid stand mixer is leaking alot of oil
ok, there are 4 skrews holding the body together on its white underside( or what ever color you have.) after you get those there are like 9 or 10 little skrews under a shiny rig that goes around the shaft that does all the work in the bowl. pull the ring off and take out those skrews. after that... well i have to find out for myself how to fix the oil leak! good luck and if you find out let me know! BTW here is a link to the service manual.
http://store.mendingshed.com/k45map.html
Posted on Dec 29, 2008
ricardok45
  • 135 Answers
SOURCE: KitchenAid 600, Stand Mixer -
Hi. Stop using your mixer. If your mixer is still covered by warranty, call Kitchenaid Customer Service, they are very good with warranty repairs.
If your mixer is out of warranty, remove the silver band that surrounds the top of mixer. Remove the top cover. At the front of the mixer, locate the transmission housing which is now exposed. Examine this housing carefully for cracks. If you find cracks anywhere in this housing, you have found the under-engineered plastic transmission housing. Kitchenaid's replacement housing is made of metal. Your plastic housing has no business being in a mixer that is marketed as being able to mix bread dough. It cannot!
If you're confident that you can make the repairs yourself, go to the Kitchenaid website and download the parts drawings. Remove the Trans. housing, remove the worm gear shaft assembly which is driven by the motor.. Remove and save as much grease as necessary to thoroughly inspect the worm gear. Inspect the worm shaft bearings. Look for cracks, or missing pieces on the bearings. Look for crunched cogs on all gears. Be prepared to wait at least a month for your parts to arrive after you order them. The replacement grease should be Shell Darina 2, or Chevron FM ALC EP 2.
If you're not confident about repairing this yourself, call Kitchenaid and determine the nearest "approved" repair shop.
You may be able to pressure Kitchenaid to pay for the damaged parts in your mixer. They are still installing these plastic Trans. housing on new mixers. Insist on a metal cover when replacing. Apparently, Kitchenaid feels no shame in their manufacturing process, and will not issue a recall notice for these housings. They are substandard at best.
If you found this solution helpful, please rate it. Good luck! ricardok45.
Posted on Feb 13, 2009
hslincoln
  • 235 Answers
SOURCE: There is a tiny bit of oil coming out of the metal
Hi KENNY8203, Merry Christmas and Happy New Year! To answer your main question, if the amount of oil you found leaking was small and if your mixer otherwise works normally with the missing oil, no, you really don’t need to be concerned. While the leaking oil may be disconcerting your mixer is not ‘broken’; just clean the agitator shaft with detergent and hot water.
Your KA mixer’s internal gears are factory packed with enough grease to last a 'lifetime', whatever that means? Depending on the age of your mixer, where it’s been stored and how long it's been idle and/or how heavily it’s been used; these factors all will eventually cause the grease’s base oil to separate from its additives, with the resultant oil seeping from openings beyond the gasket and generally following the path of least resistance down to the lowest point, i.e., the agitator shaft. Gravity can be very insidious. Now, with all that being said it is still safe to use your mixer, although you may want to consider replacing the transmission gear grease at some point in the future.
When you finally decide to replace your mixer’s grease, continue reading below:
The inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number, in this case K45SSW, and then select the file K45SSWH0.pdf (341.41 KB) under Parts List (1). (Definitely check to see it this matches your mixer).
Turn to pages 4 & 5 titled ‘Case, Gearing & Planetary Unit, which provides an exploded view for the disassembly and reassembly of your mixer, along with all the parts. Once apart you can check for any other unseemly wear and tear on the gears, etc. It can be messy but gratifying.
Besides grease you might consider replacing the gasket, and “O”-ring too. You should use a food-grade grease that you can order online (although I’ve seen automotive bearing grease used too – your call). Do not reuse any original grease as it may contain contaminants.
Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com. You should search for ‘food grade grease’. Prices can vary widely between vendors, so do your comparison shopping.
Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer. The mixers displayed in the links are different KA models, but the principles are the same.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer yourself. It can be messy but quite gratifying to diagnose and repair your mixer yourself.
If you feel future repairs are beyond your capability, then I would seek out a local small appliance repair shop in your area. KA Customer Care can give you names of local KA authorized repair shops in your area, but you can also do an online search to supplement what KA may provide you. Call to explain your circumstances and find out their hourly rate and get an estimate of what they think it would cost to repair your mixer. Also, always obtain three or more estimates – do some comparison shopping.
Good Luck. I hope this helps. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
Posted on Dec 31, 2009
  • 4 Answers
SOURCE: kitchenaid mixer makes a lot of noise. The beater
Hi - I've been searching for general info on KitchenAid stand mixers and ran across this so I'm throwing my $.02 in... Since KA stand mixer bases are essentially made of cast metal parts, there is a very slim chance that there is a lateral misalignment (side-side) unless it got dropped...eek! Sounds like a head height adjustment issue. Check out this from KitchenAid Conversations:
http://forum.kitchenaid.com/forums/topic.asp?TOPIC_ID=3032
Good luck.
DZII
Posted on Jan 03, 2010
Testimonial: "Thank you for your post. I will check out the suggestionsl"
How can I adjust bowl depth?
KitchenAid K5SS Heavy Duty Commercial Stand Mixer ...
www.fixya.com/...kitchenaid...k5ss_heavy_duty/adjust_beater_height
KitchenAid K5SS Heavy Duty Commercial Stand Mixer, adjust beater height related issues. Get free ... Beater hits bowl beater height adjustment screw does not fix problem ... beater ... ...adjust beater depth-it is scraping the bottom of the bowl.
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Adjust
www.fixya.com/search/p105880-kitchenaid...k5ss_heavy_duty/adjust
KitchenAid K5SS Heavy Duty Commercial Stand Mixer, adjust related issues. Get free help ... How can I adjust beater to bowl clearance on my Kitchenaid mixer? I have a kitchen ... How do I adjust the depth of the dough hook. how do I adjust ...
How To Adjust the Bowl Height of Your Stand Mixer ' The ...
www.thekitchn.com/how-to-adjust-the-...
Apartment Therapy's The KitchnFeb 10, 2011 - In the world of stand mixers, there's two different types. ... It's easier than you think and will make your appliance last longer and food taste better! ... If yourbowl height is too high, you'll hear the adjustment needing to be made before you ... I have a different issue with my KitchenAid Artisan mixer (tilt head).
Dec 25, 2015 | KitchenAid K5SS Heavy Duty Commercial...
I have the KitchenAid 5 Qt HD Professional stand mixer. When I securely attached the bowl to the bowl support arms (I hear the bowl click to the back) and use it to knead bread (the flour amount well...
hello step ..... yes. You may have to adjust the height of the bowl a wee bit as it sounds like the dough hook is hitting the side of the bowl..
It tells the steps in your manual.
Easy to do.
If you don't have the manual you can download it for free here http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD
Joe
Mar 12, 2011 | KitchenAid K5AWH Stand Mixer
My KitchenAid mixer clicks when I mix bread dough and any other thick batters. How do i fix it?
Make sure your dough hook isn't bent.... or your bowl doesn't have a dent in it.... and make sure the bowl is properly seated and secure.
Aug 29, 2010 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid Household stand mixer. Model no.
it is hard to tell you exactly what it could be, but a common problem is after a while the transmission gasket does deteriorate and will begin to leak oil.the gasket is part number4162324. the rattling noise inside your unit is most likely cause by a chipped gear inside, this can happen when the unit is put under heavy loads, such as dough. this problem could get worse as there may be fragments inside that will damage it more.hope this helps
Thanks
Oct 04, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Kitchenaid mixer 45ss
I dont know much about them but If you cannot get it repaired I do have a lift bowl stand mixer that I bought without the bowl or attachments that I would sell for $80.00 Or I will buy your attachments. Thanks, Mark.
Mar 23, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Pops out of lock under a heavy load
Hi Susan. There is no worse feeling than the feeling you get when you find that you've been seperated from your hard-earned money by a company that markets a product with glowing phrases of what their product can do...And then doesn't deliver on it's promises. Kitchenaid mixers can make short work of bread dough NOT! My Kitchenaid HD Pro (475 watts) self destructed after only 30 uses of making my Sourdough Bread. The problem? A cheap piece of plastic that takes the stresses of two important shafts in the mixer. Cheap, shoddy parts in a mixer you paid top dollar for. Kitchenaid shows no shame in doing so.
What is happening with your mixer as it tries to mix your dough is that the head unit is thrust back and forth and side to side (bucking). Eventually hinges become loose and sloppy. Kitchenaid's behaviour is legal and beyond reproach, so make your next mixer purchase an informed one.
Goto www.consumeraffairs.com and do a search for your Kitchenaid model. You'll notice that you're not alone in your mixer troubles.
I solved my mixer problems by buying a used Hobart 20qt. Commercial mixer (A200) and rebuilt it. When mixing heavy dough you should only use about 60% of the bowl capacity. less, if your mixer is agonizing with the amount of food in the bowl..
You will be able to replace the thumb screw. Be prepared to wait for at least a month for the part to arrive once ordered.
If this solution has assisted you, please rate it. Good luck! ricardok45
Mar 08, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Sorry but this is not possible on this model (can not be adjusted) And just to let you know it is normal for the dough hook to sit higher then the other attachments!
Please rate this response and help us keep this area free!
Thank You!
Jan 21, 2009 | KitchenAid K45SS Classic Stand Mixer
KitchenAid wobbles when mixing
The "wobbling" sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
Also, leaking of oil in a stand mixer is not necessarily indicative of a large problem.
Kitchenaid stand mixers are overpacked with oil to last the lifetime of the motor. If the motor sits idle for some time (is not used), the oil may begin to drip from the gears and settle. Oil leakage may primarily be seen from around the beater shaft or planetary action.
A stand mixer can lose up to a 1/4 cup of oil before it needs to be serviced.
It is recommended to run the mixer on speed 10 for 2 minutes in order to redistribute oil back into the motor. In order to prevent future occurences, this is recommended to be done every 3 weeks if mixer is not being used.
Dec 24, 2008 | KitchenAid K45SS Classic Stand Mixer
Attachments do not reach the bottom of bowl when mixing
http://www.kitchenaid.com/custserv/faq.jsp?sectionId=222#troubleshooting
This is the FAQ from the Kitchen Aid website. It explains very well how to make the necessary adjustments under the question: My flat beater, wire whip and dough hook are scraping against the bottom of the bowl when I use my mixer. How can I fix this?
Dec 21, 2008 | KitchenAid K45SS Classic Stand Mixer
KitchenAid KSM150PS Artisan Series Stand Mixer Logo
119 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
