Question about HEWLETT-PACKARD CP5225dn Laser Printer
HP Printer, CP5225, Error message, Right door open,
Un install the software printer driver and re install this is a software problems now i solve this problem
  • HEWLETT-PACKARD Master
  • 1,915 Answers
Recommended action
  1. Close the door.
  2. Use the right-door switch (SP15) test in the manual sensor test to verify that the switch is properly functioning. If the switch fails the test, replace the switch.
  3. Check the sensor flag on the right door assembly. If it is damaged, replace the door assembly.
  4. If the product has been recently serviced:
    1. Check the connector (J708) on the 24V interlock switch and the connector (J181) on the DC controller PCA.
    2. Reseat the formater board and retest.
    3. Reseat the ICB and retest.
Posted on Dec 01, 2014
2 Suggested Answers
gopakumarg43
  • 74198 Answers
SOURCE: COLOR LASERJET PRINTER CP5225
What is the problem you faces with this printer? Provide more details, please. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Nov 18, 2014
HP CP5225 giving error message "Re-install image transfer belt" belt is brand new, fixing properly, repeatedly same message appears.
Did you have the printer powered off before you installed the belt? If not the fuse has blown and the message will be on until you replace the belt again.
Feb 13, 2017 | HEWLETT-PACKARD CP5225dn Laser Printer
right door is a right side of paper try
check if there is paper jam in this try
Nov 30, 2014 | HP Office Equipment & Supplies
What is the reason for showing the message " right door is open" and how it can be solved
Could be a driver issue, look here for newest driver, and be sure to pick the correct one, win7/8 32/64 bit. http://h20566.www2.hp.com/portal/site/hpsc/public/psi/home/?sp4ts.oid=3974355
Good luck, post more info if this doesn't solve your problem.
Laulund
Jan 28, 2014 | HEWLETT-PACKARD Color LaserJet CP5225...
HP Printer, CP5225, Error message, Right door open, door is shut but will not reset error?
This sounds to be a sensor issue. Try:
Reconnect the connector (J708) of the 24V interlock switch and the connector(J121X) on the DC controller PCA.
Also, try to check the sensor flag of the right door. If it is damaged,replace the right door sensor unit.
The sensor worked for me.
Aug 19, 2013 | HEWLETT-PACKARD Color LaserJet CP5225...
Hardware Error 03130031 2f52
Turn off the printer and open the printer back door. Use a spot light and give look inside properly. Make sure there no paper. Some time small part of the paper creates the problem. So you can do one thing after open the back door, top side etc make the printer upside down etc. So if anything inside that's will come out. After cleaning again connect it with PC and turn on. Now give a look. If you face same problem then Un-install the printer driver and software from the PC. Then restart the PC and Printer both. Now connect the Printer with PC via USB and install again the driver & software. Then try to print and let me know the result.
Aug 09, 2012 | Canon Office Equipment & Supplies
Paper jam feed manual and paper goes through 3/4 of the way
Aug 09, 2012 | Dell 1600n All-In-One Laser Printer
Error Message 37,004.40:194943
Aug 09, 2012 | Xerox Phaser 8400 Laser Printer
F380 printer will not SCAN - keeps giving error message
Do you have original CD with you? if not down load the full feature drivers from hp web site. Un install the drivers, re-install once again..verify your driver CD supports the OS what you are using?..
Feb 03, 2012 | HP DeskJet F380 All-In-One Printer
I cannot install my Hp F4135 all-in-one printer. The message is : Cannot install this hardware There was a problem installing this hardware HP Deskjet F4100 series An error occurred during the...
Did you plug in the printer to your computer before you installed the drivers?
If yes unplug the printer, un-install the printer drivers, restart your computer, install the drivers, then plug in your printer when prompted.
Are you running Vista as your operating system?
If yes you may have to go to the internet to find the Vista drivers.
Dec 06, 2008 | Office Equipment & Supplies
HEWLETT-PACKARD CP5225dn Laser Printer Logo
135 people viewed this question
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Victorman
Victorman
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
