Question about Toshiba 40E200U 40-Inch 1080p LCD HDTV
How do I turn of the tv speakers on this model?
Checking the menu items related to sound.
    Top Expert:
  • Toshiba Master
  • 74,468 Answers
There should be option to stop the output from its internal speaker/s; provided there is "audio out" socket/s at the back of the TV. If there is no "Audio Out" sockets at the TV; this option will not be there at its audio menu.
Electro help
Posted on Dec 01, 2014
TV has no sound
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 30, 2016 | LG 46LD550 46 in. LCD TV
Tv sound not working, even with soundbar.
Is the sound muted or switched off in the menu. Try resetting the set to factory settings.
What make and model is it?
ELECTREPAIRUSA@ELECTREPAIRUSA or you can contact us at that address as we repair/renovate all items electronic and electrical old and new.
Apr 14, 2016 | Audio Players & Recorders
There is no sound on tv
Hi Barend, I hope I can help you with your question. I'm assuming the TV is new to you, so I think I can point you to where you can check this on your TV. Turn on the "menu" section of your TV for TV settings. In the list of items you can change, there should be an "audio" section. Open that section. You should see a list of items. One of those items should be "TV speakers", with the option of turning them "on" or "off". If it says "off", in that section, switch it to "TV speakers on". Close the menu and check if your audio is now working.
if there is still no audio, check back in the audio section of the menu and look for "Analog Audio Out". It should be set to "variable", which means you're controlling the volume with the TV. Since I don't know your exact TV model, these are some basic areas to check. Please write the make and model of your TV in the comments section, and I'll check back in on this shortly and let me know if I have helped with anything so far and I'll help you more once I know the make and model.
Feb 04, 2016 | Televison & Video
Panasonic Model TH-50PH10UKA. Hooked up to surround sound and works well. When I connect to a second input do not get any sound, how do I turn TV speakers on or Off.
Found in menu setting of tv.are you using RCA or hdmi or optical output as these need to be set in mode setting on soundboard and tv menu settings.
Jan 03, 2015 | Panasonic Televison & Video
No sound from tv speakers
Have you checked to make sure you don't have anything plugged into an audio out port? Or have the speakers turned off in the system menu? I'd start there before pulling the TV apart and manually checking the speakers.
Jul 13, 2014 | LG 42LC2D 42 in. LCD HDTV
My Sanyo tv was working fine and yesterday when I turned it on the volume was gone. I have tried going through the menu options to see if for some reason tv speakers were turned off but everything seems to...
The trouble is the speaker, try to check the speaker resistance, the common value of the speaker is 4 Ohms or 8 Ohms, when checking the speaker you should remove the terminal that connects the speaker so that the speaker will only be read by the tester. Using a digital tester to be exact.
May 31, 2011 | Sanyo Televison & Video
No sound is coming from the tv speakers. the tv
This TV has a function in the menu to turn off the speakers. Be sure that the setting is on.
Mar 03, 2010 | Sony KP-53XBR45 53" Rear Projection...
Connect Bose System to Panansonic TV
in the tv setup menu there should be an item that will allow you to change the volume from variable to fixed on the output of the tv
Dec 07, 2009 | Panasonic Audio Players & Recorders
No sound from tV speakers
check your speaker, use a battery 1.5vdc tap it to speaker wire if the speaker is ok you can hear a click sound as the wire touches the battery + & - .
Sep 10, 2009 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
NO SOUND
you can try checking in the menu. this tv has an option in the menu can you can turn off the speakers. in some tv's it sort of hidden. go into the audio part of the menu, if you do not see it, go down to the last item in the menu screen & keep pressing down. sometimes they have more options to show that just doesn't fit on the first screen. good luck.
Jan 17, 2007 | GE 27GT271 TV
Toshiba 40E200U 40-Inch 1080p LCD HDTV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
