Question about HP Office Equipment & Supplies
Error 48:00 HP Designjet Z3100 44inch
After a carriage belt replacement error 48:00 occurs every time printer is turned on. In Diagnostic Tests, In scan-axis test, Report reads PRS test: - Reading PRS Position - Position unknown- Moving PRS position to HIGH position - Moving PRS position to low position 48:00 error-restart printer.... I have replaced the carriage rear bushing, then replaced the Solenoid, then the trailing cable and then the PrintMech but printer still reports Error 48:00. HP have said this can't happen. Printer was in perfect working order up to belt change. Please help.
  • John Rush
    John Rush Dec 01, 2014
    HI Mark. Thanks for your answer.
  • HP Master
  • 1,915 Answers
Make sure that when you reinstalled the service station that it is seated properly or it will bind when the printer engages
Posted on Dec 01, 2014
02.1.10 error plotter t610 and solution
The error code 02.1:10 means the plotter has a communications problem between the main logic board and the carriage PCA. The possible parts at fault are: The Carriage PCA, Trailing Cable, or the Main Logic Board, all available here: Designjet T610 Parts
You can watch this video to see how to remove the covers Designjet T610 Belt Replacement How To Video
The service manual is here: Designjet T1100-T610 service_manual
Sep 18, 2013 | HP Designjet T610 InkJet Printer
T1100 unable to detect media edge. replaced line sensor, carriage PCA. Cannot calibrate line sensor. Panel reads calibrate sensor to black but does not print pattern and says "return error: 2".
I have seen this error occur when the carriage does not move smoothly left to right...are the shafts properly lubricated and the carriage belt in good shape (not frayed or teeth missing)?
Also there are special paper considerations for the calibration to work...Bright White Inkjet Paper is recommended., not just plain paper.
Sep 05, 2013 | HP Designjet T1100ps Printer
Hp designjet 1050c check printhead path (1) but the carriage barely moves?
Either the belt pulley is broken, or installed incorrectly, or the belt was installed backwards.
Dec 26, 2012 | HP DesignJet 1050c plus InkJet Printer
79:03 error code t770
my ploter problrm t610 printer ready but carriage left side stucking and error showing on display 79:04 than replaced 3 no print head but not tready ploter why? i have replaced tralling cable .timing belt; formatter card , encoder strip , carriage block with carriage pcb but same problem .pls shuotout my issu.
Feb 11, 2012 | HP DESIGNJET T770 Printer
HP designjet t1100ps error 21:13
This is a service station error indicating that the printer could not move the pirnthead mechanism over the service station. First check to see if there is anything in the carriage path such as a piece of paper blocking the carriage. If there is not then it is likely a bad service station that will require replacement. Always try powering pirnter off then on to see if it was temporary error.
Mar 21, 2011 | HP Designjet T1100ps Printer
On my HP 1050C Designjet I am getting the error 'Check printhead path Type 2. Then it says to switch off.
Hello. The "Check Print Head Path" error is usually a worn out carriage belt on printers more than 5 years old. Open the top cover and examine the area under the belt and look for debris that looks like pencil erasure crumbs. Other possible problems could be the tube system catching on something as the carriage moves, the encoder strip being very dirty or extreme friction between the carriage bushings and the rails they move on. If the belt needs to be replaced, a replacement kit can be purchased at: http://www.lpscomputer.com/c-790-hp-designjet-belt-replacement-kits.aspx
Hope this helps.
Bob
Jan 26, 2011 | HP DesignJet 1050c plus InkJet Printer
Need instructions to replace carriage belt for hp designjet 500, specifically how to remove and replace on the carriage assembly
When you order the belt from hp it will come with the instructions, if not email me and I will send it to you.
Jul 12, 2010 | HP DesignJet 500 InkJet Printer
HP 500ps showing error is System error 86:01
System Error: 86:01
Problem Description: Carriage-Axis shutdown.
If this error code appeared but was NOT caused by a paper jam, then try the following:
* Too much friction in the Slider Rod. lubricate the Slider Rod.
* The Carriage is bumping into the Service Station. If the carriage
is stuck at the right hand side of the Printer and cannot be moved
out to the center of the Print Platen it is because the Service
Station cannot uncap the Printheads. In this case replace the
Service Station/Aerosol Fan Assembly
Apr 16, 2010 | HP DesignJet 500ps InkJet Printer
DESIGNJET 755cm ERROR MESSAGE: TURN OFF PLOTTER CHECK PAPER PATH. THERE IS NO OBVIOUS BLOCKAGE TO PAPER PATH
If there is no obvious obstruction in the print head path, the most likely problem is a worn carriage belt. Open the front lid and check for rubber crumbs under the carriage belt. If there are crumbs, the belt is disintegrating and needs to be replaced.
The service manual can be downloaded from: www.lpscomputer.com/ec/manuals.htm and the parts are available at: http://www.lpscomputer.com/c-736-designjet-1050c-belt.aspx
Oct 10, 2009 | HP DesignJet 1050c InkJet Printer
There's an error appears. It was error number 86
86.01 can be a couple of issues pertaining to the movement of the carriage assembly.
1. Too much friction in the Slider Rod. Lubricate the slider rod.
2. The Carriage is bumping into the Service Station. If the carriage
Service Station/Aerosol Fan Assembly.
3. Check the carriage belt for wear. Check the carriage path for debris. If the belt is worn, replace the belt. Also, clean the teeth on the carriage drive motor, the debris from the belt will accumulate on the teeth.
Sep 28, 2009 | HP DesignJet 500ps (42 in.) InkJet Printer
420 people viewed this question
Seeker5211
Seeker5211
