Question about ASUS Computers & Internet
My asus transformer pad won't power up tried resetting but still won't power up
Tried to reset by holding power and volume down buttons down for 12seconds still will not power up
  • 380 Answers
You may have a bad charger. try another power supply.
Posted on Dec 04, 2014
3 Suggested Answers
tennison
  • 13 Answers
SOURCE: osd lockout and automaticv volume decreases on hpw1097 compaq com
Change the front control panel switch set.
this is the major problem
available in market
Thnks
TENNISON.J
tennison_2006@rediffmil.com
+919901642228
Posted on Aug 29, 2009
budmrtn
  • 11361 Answers
SOURCE: I have an LG-1934S. The
To find out where the problem is, you will have to try this monitor with another PC or try another monitor with this PC first to narrow down the problem.
Please post back after what you find out so we can help you further.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Jun 24, 2011
ASUS ZENPAD 102300 C PROBLEMBS ALWAYS After cahrging. It wants a reset everytime
Have you checked for firmware updates? You can try to do a hard reset which can force OS errors to clear up.
First method:
  1. In order to switch off the device, hold down the Power button for a short while.
  2. In the next step press and hold Volume Up + Power key at the same time for a few seconds.
  3. You can release held keys when you see menu on your screen.
  4. Then press Volume Down to select option "Factory Reset", and press Power button to confirm.
  5. Success! The hard reset has just been performed.
Second method:
  1. Turn on the device by using the Power button.
  2. Afterwards go to Settings and then to Backup & Reset.
  3. Tap Factory Data Reset and select Reset Device.
  4. If it's necessary enter the safety code and choose Erase Everything
  5. Select OK to confirm the whole operation.
  6. Well done! After a while your tablet should be ready to use.
Third method:
  1. At the beginning press the Power key to turn off your device.
  2. Afterwards press and hold Volume Up + Power simultaneously for about 5 seconds.
  3. you can release held keys when you see menu on your screen.
  4. Then press Volume Down to select option "Recovery", and press Power button to confirm.
  5. Press Volume Down to choose "wipe data/factory reset", and then push the Power button to confirm.
  6. Select "Yes--delete all user data". Use Volume Down button to scroll and Power key to select.
  7. To restart the tablet, select "reboot system now".
  8. Success! The hard reset is done!
A Hard Reset will erase all of your data
Feb 16, 2017 | ASUS Computers & Internet
ASUS ZENPAD 102300C AFTER CHARGING GOES BACK TO RESET
First method:
Second method:
Third method:
How do i reset my asus transformer tablet tf101 i have a blank screen will not turn on
Perform a soft or hard reset on your Asus Eee Pad Transformer Android tablet if it is not functioning correctly. Here's how.
Soft Reset
You would want to soft reset the device in the event that it has become frozen or unresponsive. To do so, press and hold the Power button on the top-left side of the device for about 10 seconds until the device powers off.
Hard Reset
A hard reset (also known as a factory reset) will clear all data and settings from the memory of the device and set it back to factory default settings. You can perform hard reset on the Asus Eee Pad using the Android OS menus or the hardware buttons.
Method 1 1. Power the Eee Pad off.
2. Press and hold the Volume Down button on the left side of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
The Asus Eee Pad will complete the hard reset process and reboot into a factory default state.
Method 2 1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
4. Select Erase tablet.
5. Select Erase everything.
Dec 31, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
My ASUS Transformer TF101 won't turn on. Please help!
Press and hold the reset button for 40 seconds and then press again.
Jun 12, 2017 | ASUS TF101 USB Kit for Transfomer Tablet
Why will my Asus transformer tf101 not boot up can it be fixed ?
Three possible solutions, from mild to drastic--hope one of them can help.
1) In my experience, the battery can drop below a threshold voltage quite suddenly and cause the boot-up to freeze, or not start at all. Before you do anything else, be sure it's *fully* charged by leaving the tablet switched off and plugged into the charger for at least 12 hours. Then try starting it normally. If it still doesn't start up,
2) Try holding the power button down for a long press, at least 10-15 seconds. Sometimes this is enough to kick it into action. If not, you could try the nuclear option--
3) --a hard reset, which could be achieved by pressing a straightened paper clip into a small hole (*not* the headphone socket), or by holding down the power button and pressing the volume-up or volume-down button and then following on-screen instructions (check your manual). Note that this will erase all your user data and you should back up everything first, but if you can't boot I don't see how you could accomplish this.
Aug 11, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
My nexus 7 wont go past multicoloured x.. cant switch on/off. tried hard reset and nothing works
Important:Plug your device into power outlet
Step 1: Power off Nexus 7
Step 2: Power on while holding Volume Down/Up
(enter BootLoader)
Step 3: Press Volume Up to toggle to "Recovery Mode"then press power to select
Step 4: Hold The Power Button and tap Volume Up when you see "No Command"
Step 5: Press & hold Power Button & Volume Up Button Again
Step 6: Toggle with vol down and vol up / power at wipe data (all data) & reboot
Nov 20, 2013 | ASUS Google Nexus 7 8GB Tablet Unlocked...
Too many pattern attempts
You'll need to do a factory reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
This will reset you device to factory settings, however anything on your SD card will still remain.
At this point you will need to start fresh as if you just bought the device -- register with your email address, etc.
Nov 14, 2013 | ASUS Eee Pad Transformer TF101A1 Tablet...
My ASUS Transformer will not power on
1. Make sure it is charged. If the battery is dead you may need to leave it plugged in for a few minutes before it will turn on.
2. Hold the power button down for at least 10 seconds. This may bring it back to life if it didn't shut down properly.
3. Make sure no other buttons are stuck down (volume up or down). If another button is stuck down the power button won't work.
Apr 16, 2013 | ASUS Eee Pad Transformer TF101A1 Tablet...
My asus transformer tf300 won't turn on
It is possible you got into APX mode (for transferring files with the device not in the OS using NVFlash. Great if you bricked a device). This mode is Hold VOL UP and tap POWER. In this case, you can try to use the Reset Hole on the left side of the Asus TF300 (between the microHDMI and microSD card). Try it for 3-5 seconds. Another thing you could do is hold the power button for 30 seconds, release, hold it for 3 seconds and see if it boots.
The last thing you could do is hold VOL DOWN and POWER for about 12-15 seconds until some small text appears in the top left.
Dec 11, 2012 | ASUS Transformer Tf300t Tablet
Computers & Internet Logo
71 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
