Question about Singer Sewing Machines
I have been using a singer 6233 model ,bought in the eighties. it has not given me problems until recently . The problem is that the feed teeth does not move when the presser foot is brought down. it
No problem with the presser foot and feed sysem prior to this.
  • Singer Master
  • 1,860 Answers
Check to make sure the sewing machine is not in the darn position, if it is in the position for sewing, then the feed dogs may need a adjustment or may need replacing, having the machine checked would be a good idea
Posted on Dec 02, 2014
    Master:
  • 550 Answers
Look to see of the bottom meck is moving . It could be the spool clogged op in bottom
Posted on Dec 01, 2014
Testimonial: "I have in fact located the problem after opening the underside of the machine. The gear driving the shaft has become brittle and worn out. I am sending the machine for replacement of the worn out gear. Anyway,thank you for suggestion."
  • 27 Answers
SOURCE: Model 6230- presser foot lifter won't move presser foot
That's the problem seized up use a penetrating oil from the top and work it up and down and it should free up
Posted on Jan 14, 2009
  • 174 Answers
SOURCE: just bought a used model singer 6233 need to know
Should be on the right side in a recessed portion just above the bottom of the machine. You can see it here without paying for the manual: http://www.sewusa.com/Sewing_Machine_Manuals/Singer_Manuals/Singer_1000&UP/6233_Instruction_Manual.htm
Posted on Mar 17, 2010
The Singer 6233 was one of the models that briefly were made using air-powered foot controls. So you aren't looking for a traditional electrical connection. Instead, your pedal cord's female end will connect onto a black male nipple, that sticks out on the right side of the machine (the side with the handwheel). Just push it on until it feels snug.
Posted on Jun 01, 2010
  • 1788 Answers
SOURCE: I am trying to quilt
Try putting tearaway stabilizer or tissue paper under your material and see if it helps.
Posted on Sep 14, 2010
SOURCE: The Presser Bar on my Singer 66 does not move up or down when I use the Presser Bar Lever. It seems to be stuck solid and therefore it will not lower onto the feed dogs to enable me to sew. The Presse
it's possible that the presser bar could be bent or damaged, the only way to know what is exactly wrong would be to take it to a sewing machine repair shop
Posted on Mar 21, 2012
Even on the raised setting, the feed dogs won't move the thinnest summer weight fabric. Does anyone know how to fix this problem on the Singer Model #7426?
Could be the presser foot is not applying enough pressure to the feed dogs. Check your owner manual for instructions on increasing the presser foot pressure. Could also be that the feed dog height needs to be adjusted or their teeth are worn (do not run the machine without fabric between the presser foot and feed dogs).
Aug 22, 2017 | Singer Sewing Machines
Singer touch tronic 2000 feed dog will not advance fabric
Confirm the feed dogs are raised. Make sure the feed dog teeth, area under the needle plate and the bobbin area are clean of any debris, thread, or buildup. Some machines also have a presser foot pressure adjustment that increases the pressure the presser foot applies to the feed dogs. The feed dogs could be worn (never run the sewing machine without fabric between the presser foot & feed dogs).
https://www.manualslib.com/manual/508740/Singer-Athena-2000.html
Or, the machine has not had a thorough cleaning and oiling recently and the feed dogs are sticking from old oil.
Wheel on right side that controls the needle up and down is very tight...
Jul 30, 2017 | Singer Sewing Machines
Hi there. I have a singer 507 machine which was sewing fine until I changed thread in bobbin and now the feeder teeth are not moving to feed thE fabric thru, not sure what I may have done - Help!
the bobbin has nothing to do with the feed teeth
however it is possible that at some point you moved the forward /reverse knob lever to middle where the teeth will not move
Jan 03, 2017 | Singer Sewing Machines
Singer 9015
check feed dogs are clean with no build up of lint and have sharp points on teeth
Feb 19, 2014 | Singer Sewing Machines
Can not locate feed dog switch for model6233
the question is under the singer sewing machine category, so I look up a manual for a singer sewing machine model 6233, the feed dog information should be in there. http://www.singerco.com/uploads/download/1314_6233.pdf
Jan 25, 2014 | Singer Sewing Machines
Singer Sewing Machine model #2638 Does not feed fabric
Here is a link to page 22 of the manual. It shows you where to flip the lever to raise the feed dogs. If your feed dogs are not grabbing fabric your feed dogs are lowered.
https://www.manualslib.com/manual/1050311/Singer-2638.html?page=23#manual
Sep 20, 2012 | Sewing Machines
Hi, have tried to use buttonhole feature on singer 4423. Dog feed teeth have dropped - won't come back up and the material isn't feeding though. Any help greatly appreciated.
Re: Reverse feed dogs on Singer 4423 Remove extension table so you can see switch on BACK of machine @ left side. Flip switch to raise feed dogs up. If machine actually sewing in reverse - check n Buttonhole adjustment. Reset it (located bottom right side machine) Jimmy
Apr 04, 2012 | Singer 4423 Sewing Machine
Just bought a used model singer 6233 need to know where foot pedal plugs in
May 10, 2010 | Sewing Machines
I have a Singer Stylist 543. The feed is not
If you have taken the needle plate off recently make sure you have put it one correctly, failing that you need to get underneath the teeth by taking the machine bottom off and you will see a large screw that you can adjust
Mar 09, 2010 | Sewing Machines
Model 6233 Singer material will not feed needle goes up and down
Is the feed dog pushed to the up position? How about selecting a stitch length? I have a feeling watching the dvd and instruction manual will do wonders for you, If you lost your manual, go online to www.singerco.com and download one for free,
Apr 22, 2008 | Singer 3116 Simple
Sewing Machines Logo
70 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
