How do i change the filter in my furnace - Heating & Cooling
  • 3,904 Answers
Depending on how hold your furnace is it will be a door you pull off of your furnace to access the filter or the filter will slide in a slot on the side of your furnace. Either way it is simply removing the old one and sliding a new one in.
Posted on Dec 01, 2014
Where is the filter located on my Heil variable speed furnace G8MTLO701412A1 ?
Where the furnace pulls in air to heat is where the filter is.
Jan 05, 2018 | Cars & Trucks
How do i change the filter as the thermostat inducates it needs to be changed, where do i get he filter?
The thermostat is just indicating that your furnace filter needs to be replaced. There is not a filter on the thermostat. Go to your furnace, there should be a door that is concealing the filter or there will be a slot on the side that has the furnace filter in it. Pull it out and the size will be written on it clearly. YOu can get a filter at any hardware store or home improvement store.
Jan 03, 2015 | Honeywell 2 Programmable Thermostats Rth...
Can you tell me what nozzle and filters I need to clean my furnace?
Replace filter with same size currently used (unless filter doesn't fit ) , and use a pleated style filter of the cheaper type . There mar be a wall or ceiling mounted filter on return air vent or a filter inside front of heater .
Oct 02, 2014 | Heating & Cooling
How do I change the filter that my thermostat is telling me needs replacing?
Your air conditioner uses the furnace blower to circulate air. The filter to be changed is the one in the furnace.
Aug 21, 2014 | Heating & Cooling
On the thermostat the "filter"
Thermostats used in homes sometimes have a timer built in which will remind you to change your furnace filter. Most of them can be adjusted or disabled. The thermostat has no way of knowing whether the filter is actually dirty, it just reminds you every so often by flashing "filter" on the display.
It is possible to reset the timer, or adjust how often it appears, or disable it completely. Exactly how to do that depends on the make and model of your thermostat. Often, it is simply a case of holding two buttons at the same time for a few seconds.
As to why the furnace doesn't come on, there can be many reasons. The problem likely is not the "filter" flashing on the display of your thermostat. Try resetting the breakers that service the furnace unit itself. Make sure that the thermostat is set to "heat" and the setting is turned up. If the thermostat uses batteries (most do these days), replace them.
If this doesn't work, the following information will be helpful to get the furnace running again:
Brand
Model number
Age of furnace
Location in home
Brand and model of thermostat
Feb 28, 2011 | Heating & Cooling
How do I locate and change the furnace filter?
Your filter will commonly be on the side of your furnace where the return air comes in, usually it will slide into a filter rack or you might have a small cover on it. When replacing a filter make sure the arrow on the filter is pointing in the direction of airflow, so the arrow should be pointing toward the furnace.
Jan 21, 2011 | Goodman Heating & Cooling
I have an Intertherm furnace that now will not turn on....Its a gas unit..electronic ignition,,, and from what I could read on the furnace..the model number is G2RR050C12...geez..I hope thats...
The filter is in the bottom of the furnace. Turn T-stat off and go to furnace. Unplug furnace. Top door comes off first, pull up on top door then out and down, set aside. Bottom door lifts up and then out. There is ur filter at the bottom. azeddysac@yahoo.com change ur filter then hit me back
Nov 06, 2010 | Intertherm Heating & Cooling
Furnace filter on model gmt070-3a...
look in and around where the blower motor is located. there has to be a filter compartment there. probably near the bottom as it looks like an upflow heater. make sure the filter door is closed. it may have a door interlock switch that cuts the burner out if it is not fully closed.
Feb 01, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
65 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
