Question about Autometer 2007 FORD F-550 SUPER DUTY Auto Meter 5796 Phantom Gauges
How do you remove a lower ac compressor on a Ford 6l diesel with duel air
My unit has two ac compressors the lower one is seized but I cannot find the mounting bolts to remove it can you help
  • 4 Answers
I believe the bolts are from the side on the auxiliary compressor
Posted on Dec 01, 2014
Testimonial: "Thanks for your reply but The bolts seem to hidden which is why I cannot locate them.ive looked everywhere I can see but no luck."
How do you get ac compressor out without taking engine out 2006 buick rainier
COMPRESSOR REPLACEMENT
REMOVAL PROCEDURE
  1. Recover the refrigerant Refer to Refrigerant Recovery and Recharging.
  2. Remove the washer solvent container.
  3. Remove the air cleaner resonator outlet duct.
  4. Remove the cooling fan and shroud.
  5. Remove the accessory drive belt from the A/C compressor.
  1. Remove the compressor hose assembly nut from the compressor.
  2. Remove the compressor hose assembly from the compressor.
IMPORTANT: Remove and discard the sealing washers.
  1. Remove the upper A/C compressor mounting bracket bolts.
  2. Remove the lower coolant hose.
  3. Raise and support the vehicle. Refer to Vehicle Lifting.
  4. Disconnect the A/C compressor electrical connector.
  5. Remove the lower A/C compressor mounting bracket bolts (3).
  6. Lower the vehicle.
  7. Reposition the compressor and mounting bracket to access the remaining compressor to bracket bolts.
  8. Remove the upper A/C compressor mounting bolts (4).
  9. Remove the A/C compressor.
  10. Remove the A/C compressor bracket.
Aug 25, 2013 | Air Conditioning and Heat for Buick...
AC pump seized up need to know how to remove it. 1997e350 van triton V8
There should be four mounting bolts, and the fittings for the hoses on the back.
Sep 23, 2012 | Ford Cars & Trucks
Engine dies as soon as I turn on the air or heat.
If by heat you mean defrost, it could be a seized AC compressor or compressor clutch, since the AC compressor is also engaged when in defrost mode to remove moisture from the air.
Try turning the flat, round plate on the front of the AC compressor by hand (WITH THE ENGINE OFF!!) If turns with only a little resistance, the compressor is most likely NOT your problem. If it not turnable by hand, then your compressor is seized up will most likely need replaced.
Sep 15, 2011 | 2005 GMC Envoy
Seized ac compressor, can I bypass with ashorter belt, with out removing ac compressor
If the compressor itself has failed, you can unplug the clutch and leave the belts as they are. If it is the pulley bearing that failed, replace it, it does not cost all that much.
Jul 08, 2011 | 2002 Ford Taurus
A/C pulley bearing seized
Is it seizing with the AC on? Or Off? Or both? If it is seizing even with the AC is on and off then this is an internal issue with the compressor, replace the compressor. If it is only doing it while turned on and is still blowing cold air then replace the clutch pulley.
Mar 18, 2011 | Ford E-Series Cars & Trucks
My engine stalls out when running air conditioner
I agree that it's probably seizing up and here's a video I made on how to change the compressor. You also need to change the accumulator and orifice tube when you change the compressor. If the compressor came apart and threw chunks or metal shavings into the system, it's recommended to flush the system but that didn't happen on mine, so I don't show how to do that.
Jul 23, 2010 | 2003 Ford Focus
AC Unit is not working
if you got high volt to the outdoor machine....make sure the thermostrat is in fact on.open the control box cover to the a/c.a round or oval soda pop lookin can thing should be visually noticeable.is it blown up.thecan top will be bulged.if it is the capacitor is defective.duel capacitors control phase shift for both motors...the outdoor fan and the compressor.a big black relay with the wires comming from the outdoor fuse box should be noticeable.this is the high volt contactor, is the contactor pulled in?beets the **** out of you???grab a screw driver by the insulated handle, not the metal part of the screw driver.manually push it in.did the fan start to go???if so bad contactor or no signal from t'stat to turn machine on.if not no high volt to machine(breaker tripped or failed) or fan motor seized leading to compressor O.L.
Aug 03, 2009 | Goodman CKL60AR60 Air Conditioner
AC compressor has short cycle. Constant on/off every 2 seconds.
have you checked the compressor oil it may be seizing up
Mar 18, 2009 | 2002 Ford Explorer Sport Trac
Belt tensioner
lower right hand side on front of engine just above the a/c compressor it is held in place by 2 10mm bolts it is a duel pulley tensioner with 1 smooth pulley and 1 grooved.
Aug 30, 2008 | 2004 Ford Excursion
Autometer 2007 FORD F-550 SUPER DUTY Auto Meter 5796 Phantom Gauges Logo
83 people viewed this question
Top Autometer Science & Laboratory Experts
William McMath
Tom Chichester
Are you an Autometer Science and Laboratory Expert? Answer questions, earn points and help others
