Question about DeLonghi Ovens
My DeLonghi 2003 Gas stove has a faulty oven control. The oven will not remain on.
The oven will not keep on. The oven control turns off after about 30 seconds.
  • 2,195 Answers
Sounds like a bad thermocouple. The thermocouple is the part that the pilot heats up to make the flame come on. I replaced mine and now works perfect. Go to a dealer who has repair parts. Mine cost around sixty dollars..
Posted on Dec 01, 2014
How to change lower element in DeLonghi Airstream Convectio Oven
  • How to change lower element in DeLonghi Airstream Convectio Oven??
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Oct 28, 2017 | DeLonghi Ovens
    The self gas ignition stays on and keeps clicking.
    Request manuals and parts lists directly from Flavel.
    Nov 04, 2017 | Stoves Ovens
    My oven wont turn off from the knob it keeps turning
    You didn't say whether you have a gas or electric oven, or oven & stove. I'll assume you have a stove, just to cover all bases.
    First, you should shut down the oven: a gas stove will have a valve on the gas line behind the stove. The valve will either have a red handle or a flat stem that usually has a hole in it. Turn either valve 1/4 turn to shut off gas, use a wrench on the flat stem. An electric stove should be shut off by flipping off the double circuit breaker for it in your electric panel. Do not unplug an electric stove when it is on; this can damage the plug &/or electrocute you.
    Most likely the inside of the knob has stripped out. Look at the knob for a hole that has a setscrew in it: a small allen wrench or screwdriver will loosen the setscrew, most knobs don't have them and will pull off. Be careful to use even pressure on two sides of the knob; if you can't pull it off, use two butter knives or flat screw drivers to pry it up enough to get a grip on it.
    Look at the center stem on the back of the knob, it will likely be cracked or stripped. Some stems have a D-shaped metal insert that strips out inside the plastic stem. If you have one, pull off a burner knob and compare the stems in the back, if they are the same size, put the burner knob on the shaft for the oven control, and use that knob to turn the oven control off.
    If the burner knob won't fit, use your fingers or a pair of pliers (gently) to turn off the oven control shaft. If the shaft stops normally, you can turn the stove back on using either the gas valve or the circuit breaker. If you have a gas stove that doesn't have electric ignition (a clicking noise when you turn on a burner) you may need to re-light the pilots for the burners. Lift the covers off the burners to re-light the pilots.
    If you have succeeded in turning off the oven, you need a new knob -- you can get one at an appliance parts store or maybe a hardware store. If the oven control did not turn off normally, I would leave the oven/stove turned off: the control itself will need to be replaced by a qualified repair person.
    Mar 03, 2013 | Ovens
    Kenmore gas oven model 91136519 from 1992 . The stove top burner work as well as the oven broiler. But the bake mode of the oven will not come on. What could be the problem?
    Faulty temp. control...The variable temperature portion is faulty, but broiler function FULL ON GAS is ok...Replace the Temp control assembly.
    Jul 01, 2010 | Ovens
    We have a maytag gas single oven stove. Where do
    Hi.
    The beeping sound is a warning because the oven is in lock condition. The oven is not faulty, and the code is not 5AB, but SAB.
    SAB means that the oven is in Sabbath mode, and the control board will be locked for 72 hours with SAB on display.
    If power is disconnected a new 72 hours cycle will start.
    Push and hold the Clock button for about 10 seconds, that will reset SAB mode.
    If that does not work leave the oven connected and off for 72 hours. If the oven does not unlock after three days, then the electronic control may be stuck in SAB mode because it is faulty, in that case contact the manufacturer at the number listed on the owners manual.
    Regards.
    Mar 04, 2010 | Ovens
    Oven doesn't turn on.
    the gas flow regulator for the oven is bad and needs replaced.
    Nov 13, 2009 | Ovens
    How do I light the oven on a gas stove
    If this is a newer stove (that does not have a pilot light...and most newer stoves don't), you shouldn't have to light the oven manually (if you think you need to, you have a faulty stove). Manual ignition of a stove is also potentially dangerous as larger amounts of gas in the oven can cause small explosions. Most modern gas stoves use a very hot glowbar to both regulate the amount of gas entering the oven and igniting that gas. If you have a faulty glowbar, it will not allow enough gas to enter the oven and may not be hot enough to ignite the little gas that does enter (that is why you may smell gas). It sound like you may need to replace the glowbar (or visually inspect the glowbar to see if it gets red hot. If it does, it may still be faulty (not drawing enough power). The only way to test this is to use a clamp-on ampmeter and test the current flow through the wires feeding the glowbar. They should read between 3.1 and 3.7 amps. Anything lower means the glowbar should be replace. If you cannot see the glowbar get red hot, you have an electrical problem or a circuit board problem.
    Jul 11, 2009 | Maytag CWG3600A Gas Single Oven
    Blower remains on when oven is turned off
    yes it is normal i have one and it has been doing that sine i brought it i took it a part and there is nout wrong with it so yer its fine
    Jan 05, 2008 | DeLonghi DEBIG24 Gas Single Oven
    Faulty bake or broil element
    The solution to this problem depends on whether the oven is electric or gas. Electric oven. If your electric oven's bake or broil element isn't working properly, either it isn't receiving electric power or the element or the oven control may need to be replaced. In many cases, the wiring to the elements can be burnt or broken. 1) Be sure the controls are set on the proper setting. 2) Be sure the stove is plugged in and/or check the circuit breaker or fuse that serves that circuit. 3) Call an appliance repairperson or replace the element yourself as follows. 4) Unplug the oven and let any hot parts cool. 5) Unscrew the mounting screws that secure the element bracket to the oven and pull out the element far enough to access its terminals. Note which wires are attached to each of the terminals, then disconnect the wires (pull off the wire clips or unscrew the wires). 6) Take the element to a parts dealer, along with your oven's model and serial number, and buy a replacement (preferably the manufacturer's suggested replacement part). 7) Reverse the process to reinstall. Gas oven. When a gas oven doesn't get hot, it generally means that it isn't receiving gas, the gas valve isn't distributing gas to the oven burner, or the ignition system -- either an electronic ignition or pilot light -- isn't working properly. A common problem with ovens that have a pilot light is that the pilot light has gone out. NOTE: Gas ranges younger than 10 years old have a sophisticated fault code system that governs their ignition. Always call an approved warranty service provider to handle problems with these ranges. Here's how to troubleshoot your range: 1) Be sure the controls are set on the proper setting. 2) Be sure the stove is plugged in and/or check the circuit breaker or fuse that serves that circuit. 3) Check the gas valve to be sure the gas supply is turned on (also make sure the house's main gas valve is turned on). 4) On a stove with a pilot light, make sure the pilot light is burning. If it isn't, re-light as discussed HERE, or in your owner's manual. 5) Adjust the pilot flame (older stoves only). 6) Turn off the gas and unplug the stove (or turn off its circuit at the electrical panel). 7) Clean out the oven burner ports, using a stiff wire. 8) Plug in the stove (or turn on its circuit) and turn the gas back on. Re-light the pilot (if it has one). 9) If the oven still doesn't work, call an appliance repairperson.
    Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
    Ovens Logo
    150 people viewed this question
    Top DeLonghi Ovens Experts
    ashburton
    Naftali Haskell
    Level 1 Expert
    Jason Harris
    Jason Harris
    Are you a DeLonghi Oven Expert? Answer questions, earn points and help others
