Question about Homedics Cool Mist Humidfier - Uhe-oc1 -
My homedic s humidifier is leaking.I turn it on in the evening and next morning I see it in a puddle of water.Happens every time.
Leaking humidifier
  • 14 Answers
Chances are it is just condensation not leakage if it's only wet when its running. Nothing you can do except put a towel under it.
Posted on Dec 01, 2014
How to clean homed is humidifier
Hello, Mary -
This is the link to the PDF document with the Instruction Manual for the Homedics Humidifier model UHE-CM45:
https://www.homedics.com/media/documents/homedics/instructionbooks/UHE-CM45_IB.pdf
Cleaning instructions start on Page 9 of the instructions.
You can download and save the instructions as well as print them, if you wish.
Best wishes.
Jan 08, 2018 | Humidifiers
Sharper image ultrasonic humidifier #EV-HD10B leaking water
clean all the rubber washers. You may have crud preventing a good seal. Where is it leaking from specifically?
Jan 02, 2018 | Sharper Image Humidifiers
Homedics Humidifier UHE-CM45
Check the float that is monitoring the water level. Sometimes lime and calcium build up will restrict the motion of the float. If it's a probe level, check to make sure there is no hard water build up on the probes that will restrict continuity from one probe to the other
Aug 15, 2016 | Humidifiers
New filter, not running and leaking all over
Customer Reviews: Essick Air 821-000 Digital Control ...
www.amazon.com/Essick-Air...Humidifier/.../B0000D...
Amazon.com, Inc.Essick Air 821-000 Digital Control Evaporative Console Humidifier ... Holds 6 gallons and will dump 6 gallons in to the air over a 24 hour period, which ... a pain to fill, eventually leak, or come defective from the factory (holes on seams). ... We left itrunning all night, and barely any water had evaporated by the next morning.
www.amazon.com/821...Humidifier/.../B0000D8EJZ?...
Amazon.com, Inc.Essick Air 821-000 Digital Control Evaporative Console Humidifier ... So although notas dry as the northeast, it gets dry when the temps go down. ..... Had this humidifierfor less than three months and it started leaking all over my hard wood ...
Jan 05, 2016 | Essick Air Humidifiers
I have a Cool Mist Homedics Ultrasonic humidifier, Model UHE-OC1A that has stopped working...I have cleaned it, the small lights go on when turned on, but no mist is coming out ... ???
In the bottom of the humidifier is a little disk that vibrates to turn water to vapor. This gets covered in mineral deposits and won't vibrate properly. They usually suggest something like vinegar to clean it. I found that this didn't work for me. What did work was cleaning it with my Waterpic on the highest setting. It chipped away the deposits and allowed it to work. HOWEVER, once you get it running again, buy the slant fin mineral absorption pads to keep it running. If you have mineral-rich water like me, you'll go through them quickly, but you also won't have white deposits on your walls anymore.
Feb 24, 2015 | Homedics Cool Mist Humidfier - Uhe-oc1 -
Model #HE365A,B Powered Flow-Through Humidifier LEAKING BAD
The Humidifier could be leaking for several reasons. First make sure the water panel is replaced and not full of sediment. Check the drain line make sure the water is flowing freely. And lastly, check the supply line for any cracks.
Oct 15, 2014 | Humidifiers
Honeywell humidifier htt-145 leaking from bottom
If you can locate a crack in the clear plastic tank, there may be a chemical you can buy to "weld" the crack closed. If you aren't sure what plastic it is, you might try sealing the crack with bathroom caulk that is mold resistant. You must locate the source of the leak and patch that.
Mar 08, 2014 | Honeywell QuietCare HCM-630 Humidifier
Water leaking / running from top of humidifier
humidifiers have a drain and if there is water going in it will be coming out the drain. check drain to see if it is clear, check hoses going into top of humidifier for cracks, check filter in humidifier.
Feb 05, 2014 | AutoFlo 250 Humidifier
Aprilaire 700 water never shuts off
the float may be bad or sticking allowing water to run continusly even when unit is off.
Nov 06, 2013 | Aprilaire 700 Humidifier
Homedics Cool Mist Humidfier - Uhe-oc1 - Logo
495 people viewed this question
Top Homedics Humidifiers Experts
Paul Carew
Dennis
Are you a Homedics Humidifier Expert? Answer questions, earn points and help others
