Question about LG Audio Players & Recorders
NO AUDIO OR VEDIO ON MY LG DVD RECEIVER
CHECK FUSE,CHECK CABLES,
    Top Expert:
  • LG Master
  • 35,572 Answers
Even though the fuse checks OK, the power supply may have failed.
Posted on Dec 01, 2014
Need help hooking up my new blue ray player to my Hitachi 62 inch older tv
use input cables ,connect to tv;s audio,vedio in to tv ,,from audio vedio out of b r player,,,,,go to source input option in tv with menu & select ur input option
Feb 17, 2015 | Hitachi Televison & Video
No audio after recording from sat. Reciever
Double-check your input cables from the receiver to the LG 389. Do you have the sat. receiver AV out connected to the front AV In on the LG DRT389? Make sure that you haven't mixed up the L and R audio connections on either side. (I've done something similar with RCA cables myself.) Next, try a different set of cables.
If that doesn't work, there may be a problem with the audio jacks on either your receiver or the 389. To check, plug the AV cables from the Sat. Receiver directly into the TV. If you have sound and video, then the input jacks on the recorder may be damaged.
Try using another input. (It looks like some models have the SCART input; you may need to set the input source in the menu under AV2 Decoder.)
The fact that you have audio output on USB and DVD's means that cables/connections between the LG289 and the TV are fine.
I hope this helps. Please add a comment with the details of which AV port you are using on the LG389 for additional assistance.
Aug 31, 2012 | LG DR389 MULTISYSTEM DVD RECORDER FOR...
I installed a HDMI cable and an Optical cable to whatch movies and shows from my LG HD LCD TV, but nothing seems to work. The stereo is also a LG LHB336 system. Which is compatible with the TV. We were...
Hi,Even though you have done some cabling already,for the sake of correct connection I describe all the possible cabling alternatives to you..You can select whichever you want..
TO WATCH DVD ON THE TV:
** Receiver's "AUDIO and VIDEO OUTPUT as " 2xRCA Audio+1x Video " or "Optic Cable OUTPUT or " HDMI Output " of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary cables on your hand )
** AT TV side : you need to connect "Audio+ Video input s " as can either be : 3xRCA jacks or "Optic cable input " or HDMI IN connector of your TV ,
** than just switch to DVD mode on Receiver and play DVD
You can use "HDMI" connections as well but sometimes HDMI creates problem on Audio..
TO LISTEN YOUR TV ON SURROUND SYS.
** AT TV side : you need to connect "Audio Output " as can either be : 2xRCA jacks or "Optic cable output" or HDMI connector of your TV ,
** to Receiver's "TV input "or "AUX input" or "Optic Cable input"
or HDMI of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary
** than just switch to respective SOURCE mode on
Receiver corresponding the connector you have used on the back of Receiver ..
Pls remember.."IN " goes to "OUT" or vice versa..all the times..
There you go..Both Tv and DVD sound are on the
Receiver as SURROUNDING SOUND .By this means ,whatever you watch on the TV will come thru your Receiver's SURROUNDING SOUND speakers as well .
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
Jul 24, 2011 | LG 42LC2D 42 in. LCD HDTV
No TV sound, only DVD and CD players
Check your tv settings may need to change from speaker out to line out.
Check the tv input on the receiver, put the cd or dvd cables into the tv input. If you get audio the receiver is fine. No audio check the receiver settings.
Nov 16, 2009 | Pioneer VSX-54TX Receiver
I cant figure out how to get my playstations 3's audio to play through my koss surround sound
Hook your video source up to the display (TV), and run your audio cables to an input on your surround sound receiver. Note which input the audio cables are hooked up to and set the surround sound receiver to that channel on the front of the receiver. For example, if you hook up the audio inputs to "AUX" in, then make sure you select "AUX" on the front of the receiver. If you hook up the audio input to "DVD" on rear of receiver, make sure you select "DVD" on the front of the receiver. The connections on the rear of the receiver have to match the selection on the front of the receiver. Make sure that the cables are hooked up to "INPUT" on the surround sound receiver. It doesn't matter how the inputs are labeled (DVD, AUX, etc.) they all do the same thing. Check volume and mute controls on receiver as well. I know it sounds trivial, but sometimes it's the little things that get overlooked and cause problems. I hope this helps and good luck.
Oct 28, 2009 | Audio Players & Recorders
Tv built-in dvd player wont play thru surround sound
use your t/v audio out with RCA cables to your reciever input like(vcr in, dvd in, dtv in)
Dec 20, 2008 | Yamaha HTR-5930 Receiver
How to change from tv to dvd mode
the difference between tv and av, is that av has no showers on the screen. if you change to av you will notice a blue screen, connect your yellow on vedio output and white/ red on audio out of tv
note- before connecting to a vedio touch a tip of your vedio cable some lines will show on your screen, if touch your audio tip harming noise will sound on your tv. if this two happens then you know that your cables are okey. hold your channel button on your tv, channel will start runing after all rf channels finish, tv will go to av.
Oct 13, 2008 | Sony DVP-NS50P DVD Player
Have a new sony video/dvd recorder RDR-VX535 - cannot get sound thru the receiver
WHEN RUNNING TV OR DVD THROUGH RECEIVER YOUR AUDIO CABLES NEED TO RUN FROM "AUDIO OUT" ON TV OR DVD TO "AUDIO IN" ON RECEIVER.
Aug 20, 2008 | Onkyo HTR500 Receiver
Trying to connect sony dvd player to hdtv
You will need some cables first. It's really not that difficult once you know what each cable does.
Since you're only connecting from the DVD player to a receiver, this should be simple.
There are 4 solutions depending on what cables you have.
Composite - Yellow, Red, and White ended connectors.
S-Video - Black 4-pin connectors.
Component - Green, Blue, Red and sometimes extra Red, White for audio.
HDMI - heavy cable with a wide/flat connector.
Composite connection - Connect the yellow end to the yellow Video Out of the DVD player and to the DVD Video In on the receiver. Connect the Red audio connector to the Red Audio out of the DVD player, the White connector to the White Audio out of the DVD player, and then connect those to the Red and White Ins for DVD Audio on the Receiver.
S-Video Connection - This is the same as the Composite video connection, but connect the black 4-pin cable into the S-Video out of the DVD player and into the In for DVD on the back of the receiver instead of using the yellow video cable. The S-Video cable is a video only cable and uses the same audio cables (the red and white ended cables) for audio.
Component Connection - On the back of the DVD player, connect the 3 video cables that are Red to Red, Blue to Blue, and Green to Green. These will be labeled Y for Green, Cb/Pb for Blue, and Cr/Pr for Red. Connect these video cables to the inputs of the receiver the same way Y for Green, Cb/Pb for Blue, and Cr/Pr for Red. The audio connection is the same as composite and there should be a place on the DVD player that will tell you what audio is for Component. This is also the same on the back of the receiver.
HDMI Connection - This one is the easiest to connect as your audio and video are in the same cable. Plug in your HDMI cable in the back of the DVD player (there should only be one) and then to the HDMI connection for DVD on the back of the receiver.
Now...once you have your connections made, turn on your DVD player, set your receiver to DVD, and enjoy.
If your receiver does not have video inputs, you will need to run the video lines directly to your TV while the audio lines go to your receiver. This will mean you will need to set the receiver to DVD as well as change the channel of the TV to the input you have the DVD player plugged into.
I hope this helps.
May 12, 2008 | Sony DVP-NS725P DVD Player
71 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
