Question about Comfort Zone Heating & Cooling
Why doesn't the fan on our comfort zone heater turn on when I turn on the power?
I turn on the power, the light comes on and registers 3 C, then after a few minutes, that light goes off and the 5 dots along the panel go on. Nothing happens when I push any of the other buttons-nothing changes. I cleaned the filter. Hope you can help me get this heater working!
  • 4 Answers
You need too hit the temp button increase temp then hit enter or set
Posted on Dec 01, 2014
My Dynex 32" LCD tv seems to turn on and off
The blue light merely indicates that power is getting to your TV. It has internal power supply problems.
Nov 30, 2013 | Dynex 32 in. LCD Flat-Panel HDTV
Top row of number and letters not responding when I punch them in. for example #1 comes up #4, #2 comes up #5,and #3 comes up #6! How do I resolve?
To calibrate your Streetpilot c-Series touch screen, follow these steps:
    1. Begin with the unit turned OFF and unplugged from a power source.
    2. Power the unit ON, continue to hold the Power button for 1 minute.
    3. A screen will display instructing you to Press dot in the lower left corner.
    4. Release the Power button and touch the sequence of dots until your unit displays, Calibration complete.
    5. Your unit should now function normally.
I hope this helps. Please rate my reply. Thank you.
Jun 27, 2011 | Garmin StreetPilot c340 GPS Receiver
TV goes to blank screen after turning it on (about 3 to 4 minutes) but I can still hear it fine. I turn it off and wait a few minutes(5) then turn it back on everything is normal then it goes back to blank...
This tv the LCD inverter board is dead,that why is not sustanning backlight for the LCD screen light to have the picture.Call Polaroid for warrenty repair,this tv under a year old.
Jun 07, 2010 | Polaroid TLA-01511C 15 in. LCD Television
My 20 lg powers up, red light turns green, but no picture comes up, the channel id shows then it goes dark. I can wait up to ten minutes still no picture unless I change the channel a few times then it...
You wont want to hear this.....
Green dots on a LCD screen are burnt out pixels and unfortunately are incurable other than having the TV serviced at a high price. One of the reasons it is a good idea to get a warranty on these types of TVs is primarily due to this very problem....burnt out pixels.
Please rate my help++++Thanks for using FIXYA
Dec 01, 2009 | LG 20LS7DC 20 in. LCD TV
Dear Madam/Sir - I have a Grundig Xentia 26'' LCD TV that is 4-5 yrs/o. Recently, when we turn it on, the picture comes on OK but in a few minutes the screen goes black. If I turn the power off at the wall...
Ur backlight video board,dying.Well require changing keep happening.LCD require more power and floescent lights more heat,not like cathoray tube have radiation,but more glass take heat better.
Nov 25, 2009 | Televison & Video
TV turns off after 3 minutes or goes black
It may be an overheated capacitor in the power supply. You can test these with a capacitor tester
Aug 26, 2009 | Televison & Video
Tv comes on for a few minutes then goes off
If you take off the front bottom panel of the tv wich is easy. Then you will see 6 tuning knobs at the bottom middle of the tv .the top 6 control contrast for the lights dont mess with those. the bottom 3 are the power to each light.red is bottom left if your screen went blue it makes sense that the red is starting to go but if you turn down the power to it left 1/8 turn it should fix it for awhile .Its easy.
Jan 01, 2009 | Sony KP-57WS500 57" Rear Projection...
Vtech,5.8 3-phone w/digital recorder, model DS4122-3 None of the phones work they either say connecting or put back in the charger . these are only 2 months old?
To deregister ALL handsets:
Step 1: Press and hold FIND HANDSET on the main telephone base for 10 seconds.
Step 2: When the IN USE light starts to flash, release the FIND HANDSET button.
Step 3: Press and release FIND HANDSET again. The IN USE light will turn off and in a few seconds, all handsets will be de-registered.
Step 4: All handsets will show NOT REGISTERED.
To register a handset (register 1 handset at a time):
Step 1: Place the handset in the base unit or a charger that is connected to a power outlet. If PRESS FIND HNDST 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and place in base or charger again.
Step 2: On the telephone base, press and hold FIND HANDSET for four seconds. Release FIND HANDSET once the IN USE light comes on.
After a while the handset will emit a series of tones, the newly registered handset will be assigned the lowest extension number not previously assigned to another system handset (1-4) when successfully registered. Repeat Steps 1 and 2 if the handset does not successfully register to the telephone base within two minutes.
REPEAT THE REGISTRATION PROCEDURE FOR EACH SYSTEM HANDSET.
Make sure the handsets are not receiving interference from other appliances, cell phones, etc.
IF deregistering does not work .. you will need to reset the entire system
Step 1: Disconnect the power to the telephone base.
Step 2: Disconnect the handset battery.
Step 3: Wait a few minutes and then reconnect the power to the telephone base.
Step 4: Reconnect the handset battery
Step 5: Wait about one minute for the handset to re-establish a link with the telephone base and then test the phone again.
You will need to set the time and date again after resetting the entire system.
Mar 11, 2008 | Lands Phones
Heating & Cooling Logo
195 people viewed this question
Top Comfort Zone Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
