Question about HP Envy 4500 Inkjet Multifunction Printer - Color - Plain Paper P
HP envy 4500 is saying cartridges are incompatible? I just got it today.
I've tried to restart the printer. Take the cartridges out and put them back in. None of that is working though.
    Novelist:
    Scholar:
  • HP Expert
  • 181 Answers
The Incompatible Cartridge Message comes about because of several things.
  1. You are using Compatible Cartridges and the chips are reading as Empty - Replace the Cartridges
  2. The Chips on the cartidges are incorrectly fitted to the cartridges (Not contacting the Chip Reader in the printer). - Return them to where you bought them from for replacement.
  3. The Cartridges you have are full but Electrically faulty - Return them to the place you bought them from for replacement.
Posted on Dec 01, 2014
SOURCE: problem of incompatible cartridge occure in my new J 4580
i had the same problem with the hp 4580. i needed to replace the black ink which i did. then the error message appeared "incompatible print cartridge tri color"...chatted with hp customer support, wasted a hour. claimed its a hardware problem need to have it fixed. i asked would i be charge he said yes but the printer was under warranty. he asked other questions...bottom line i left the chat box....bought another hp 4580, used same cartridges, same message...THEN finally i replaced the color cartridge...and BAM! it worked on both printers. solution...replace the color cartridge...cons..if this happens again its a waste of money to keep buying the colored ink...
Posted on Jun 10, 2009
SOURCE: HP photosmart C4480 printer cartridge incompatible error
Well....I solved the problem......bought a new Canon printer!!
I tried everything...unplugging, cleaning everything that was mentioned above. I was onto HP online support several time, but they were absolutely no help at all...they basically told me that the cartridge must be damaged or ink dried up and to buy a new cartridge to see if the error persisted.....I don't think so!!!
I will never by HP again after having issues with the last two I have had. I love my new Canon printer it is EVERYTHING that HP wasnt.
Posted on Jan 16, 2010
Clam_Chowder
  • 59 Answers
SOURCE: incompatible print cartridge - tri color
Here's two possible solutions...you can replace the cartridge as some times they can be prone to electric/electronic problem which renders them useless. You may be able to return the defect cartridge.
Option two is to reset the printer by following these steps:
1)Make sure your cartridges are installed.
2)Unplug the power to the printer and wait about 20 seconds
3)Press and hold the # and 3 keys (while unplugged)
4)Plug the power back in (you should see a reset message on the machine)
5)Release the # and 3 keys and follow the prompts
Posted on Mar 02, 2010
SOURCE: Hp Designjet 500 not recognising ink cartridges.
I've had that problem with unfinished cartridges showing up as empty. I imagine that it could be a bad cartridge as well but I hear and feel the ink when I shake the cartridge. Therefore the ink is there. I also have a problem with some inks. I find the HP inks work perfectly whereas other manufacturers' inks work on and off. I need a solution as well. Right now I have full cartridges that are not picked up by the Designjet sensor. Any idea?
Posted on Oct 20, 2010
SOURCE: my hp photosmart all in
Hy. I have found a different solution for c4480 "incopatible cartrige". it worked for me so i hope it works for you to
Steps:
1. Press X+power at the same time
2. Press BLUE, GREEN, GRAY
3. press BLUE until you see "INFORMATION MENU"
4. press OK
5. Press Blue until you see "CHECKSUM FOR RELOCK DATA INPUT"
6. OK
7. Press X until you exit all menius
8. When promted for aliement cancel it with X.
It should bypass the error
Posted on Dec 15, 2010
Printer says black cartridge is incompatible for this computer. I bought 2 more 61 black cartridges & have the same message. This Envy 4500 uses 61 & that is all that has ever been in it.
Try to see if you have the proper cartridge inserted on the right slots. Might as well check if you bought the right one.
Serials matter make sure to grab those and present them to the store you're trying to purchase to.
Feb 21, 2017 | The Office Equipment & Supplies
Will not except cartridge
Try updating you printer software on HP's website
Oct 20, 2016 | HP Office Equipment & Supplies
When I try to put in the cartridge it pops right back out.
It sounds like you may have a defective clip on this cartridge. I would try to return it to the store for a refund or exchange.
Apr 08, 2016 | HP Envy 4500 e-All-In-One Printer, Copier,...
Directions for inserting ink cartridges
Replacing the Ink Cartridges for Deskjet 6940 and 6980 ...
support.hp.com/us-en/document/c00569593
Selecting the correct print cartridge, and removing and installing print cartridges. ... Damage may occur to the HP Deskjet printer if the print cartridges are not docked ...print cartridges, or continue to the sections below for detailed instructions.
Replacing a Cartridge - HP Deskjet 2540 All-in-One Printer
www8.hp.com/.../printers.../replace-ink...toner/.../replac...
Hewlett?PackardLearn how to replace a cartridge in the HP Deskjet 2540 All-in-One printer.
Replacing a Cartridge - HP Envy 4500 e-All-in-One Printer ...
? 3:56
https://www.youtube.com/watch?v=oJVYTXaI6e4
Jul 11, 2014 - Uploaded by HP Printer Support
The HP Instant Ink program is only available in the following countries - United ... ... Replacing a Cartridge - HP Envy 4500 e-All-in-One Printer ... HP ENVY 4500 WIRELESS SCANNERCOPIER REVIEW - Duration: 13:52.
Jan 16, 2016 | HP Office Equipment & Supplies
Where do you put the ink
It would be best to review your owner's manual that is in PDF format on your install software cd.
May 03, 2015 | HP Envy 4500 e-All-In-One Printer, Copier,...
HP Officejet 4500 Incompatible Black Cartridge
I have an HP officejet 4500. When I replace cartridge the printer reported Incompatible print cartridge. How can I get the printer to accept the cartridge and start printing again? The color cartridge is original to the printer and the black cartridge is the "new" one.
Feb 26, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Hp officejet j4680, incompatible cartridge
It is not necessary to buy another cartridge my friend, you can repair it. let me show you how... just take a towel paper, pour some water on and slide the cartridge slowly on, repeat this action 3 times and then slide the cartridge on another towel paper without water slowly and get the cartridge back in the printer.
good luck
Jul 02, 2009 | HP Officejet J4680 InkJet Printer
Print cartridge problem: tri-color
lestave my j4580 trouble lt says ck blk cartrige
Jun 09, 2009 | HP OfficeJet J4580 All-In-One Laser...
HP Envy 4500 Inkjet Multifunction Printer - Color - Plain Paper P Logo
1,770 people viewed this question
Seeker5211
Seeker5211
