Question about Frigidaire FGX831FS Washer/Dryer Laundry Center, White, Extra-Large Capacity Wash Tub, 2 Agitate / Spin Speed Combinations, 3-Position Water Level Adjustment, Bleach Dispenser, Heavy-Duty Single Speed 3/4 HP Motor 5.7 Cu. Ft. Super Capacity Drum FGX-831FS FGX83
The drum on my dryer seems to be stuck and is not spinning, the belt is on and seems to have the proper tension. Can someone help me get this dryer running again?
The drum seems to be at tilt, is that normal?
  • Omar Carrillo
    Omar Carrillo Dec 21, 2014
    The dryer doesn't have a that shaft, it seems like the back of the drum has a bearing in the center and supposed to be attached to the back of the dryer, can someone please shed some light
  • Omar Carrillo
    Omar Carrillo Dec 23, 2014
    • This dryer doesn't have that shaft. The back of the drum seems to have a sort of bearing in the center, it's not attached to the back panel. Can you shed some light?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 112 Answers
You need to replace the bearing.
Posted on Dec 01, 2014
    Problem Solver:
  • 12 Answers
Inspect the tumble dryer drum shaft - see image
inspect the dryer belt tensioner - see image listen for sound when electric motor is running
The drum on my dryer seems to be stuck and is not  - 25302111-r0o5diaoq3uxmfwmdgmcujgm-1-0.jpeg 25302111-r0o5diaoq3uxmfwmdgmcujgm-1-2.jpg
Testimonial: "This dryer doesn't have that shaft. The back of the drum seems to have a sort of bearing in the center, it's not attached to the back panel. Can you shed some light?"
  • Omar Carrillo
  • 417 Answers
SOURCE: Zanussi Tumble dryer belt replacement
Yes, that sounds about right.
Posted on Oct 11, 2008
  • 249 Answers
SOURCE: Dryer won't run
power pack, or condensur is faulty that stats the motor fit new one .close says!
Posted on Nov 30, 2008
mikesagenius
  • 24 Answers
SOURCE: frigidaire FER211AS2 dryer drum belt
the washer has to be tipped forward. can access from bottom (and back).
Posted on Jun 03, 2009
  • 1382 Answers
SOURCE: I have a Fridgidaire Model FEQ1442ES that makes a
Hi, Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Also dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Posted on Apr 16, 2010
heatman101
  • 43501 Answers
SOURCE: I have a combination Frigidaire GLGT 1031 with
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Sep 17, 2011
Drum does not spin. Belt appears to be ok
You have a bad tensioner or a bad motor. The tensioner for the belt can drag the motor. However, what you are describing sounds like the motor is shot. But make sure you are getting correct voltage to dryer and nothing is binding the motor.
Mar 03, 2015 | Maytag Dryers
My dryer tries to spin the drum when you push the start button but seems like it's having a hard time. If I spin it by hand it will start and run for about 5 to 10 minutes then shuts off and seems to
I would first check the belt, then check the belt tensioner, and finally the wheels the drum rolls on. You will find a worn belt, or worn or out of adjustment tensioner, or wheels that are worn at their axels. GOOD LUCK FRIEND.
Jan 16, 2015 | Whirlpool Dryers
The dryer drum is not spinning it seems to be stuck, can someone help me get the drum attached properly and working again.
What does it do when running? Is the belt just slipping around the drum?
http://rduappliance.com/washing-machine-and-dryer-repair/
Jan 02, 2015 | Dryers
We have a MMDE9206AYM model dryer that makes a low humming sound but will not start. Last night it also produced a burning smell. I assume either the belt is gone or the motor is overheating although it...
Sounds like drum is locked and motor is running and burned the belt. Try to spin drum by hand, Might check drum ends felt seals, Teflon bearing strips located on the bottom lip of front drum end for wear causing drag. Also check 2 drum support wheels to see if they spin freely, take the belt off motor pulley and spin drum by hand, if easier & motor runs drum is dragging. How is the spring on tensioner, does tensioner pulley spin free? Hope this helps locate the problem.
Feb 13, 2011 | Maytag Dryers
Dryer works but makes high pitch noise
This probally the idler pulley, drum rollers, or a bearing hard to say until you take it apart and take a look. There is a good video on checking and replacing these parts at www.appliancehelponline.com/servicemanual.html
Hope this helps
Mar 21, 2010 | Dryers
Dryer wont spin, I changed the belt it spinned that day, but when I used it the next day it didnt spin.
Possible cause below:
Belt not in tension or not installed properly.
Faulty motor.
Drum is locked.
Other unrelated fault that had shown shortly after replacing the belt.
Regards
Jul 19, 2009 | Kenmore Dryers
Belt and assembly trouble. Please help!!
Yes, there is a tension pulley but I"m at a loss as to how you're burning the belt, if not routed around the tensioner... seems to me you'd have a world of belt slack.
You might check and see if you can freely spin the drum, or if it seems to be locked-up. There may be an obstruction, keeping it from rotating... it shouldn't require so much effort.
Just a suggestion... Good luck.
Mar 05, 2009 | Kenmore 62722 Electric Dryer
Dryer won't spin
low voltage to the motor or a bad motor
Dec 03, 2008 | Dryers
BELT WON'T TURN THE DRUM
there is a tensioner pulley as well as the drum and motor
It hooks into a slot, usually on the floor of the case, and has a spring that pulls it against the belt to tension the belt.
Broken belts have been known to knock the tensioner out of place, it should be sitting on the floor of the case as should its spring.
There is usually ony one slot for it to sit in, self evident if you know to look for it
loop the belt around the drum.
slide the belt down the drum directly over the motor pulley
loop the belt around the motor pulley
pull the tensioner pulley hard to the end of its travel against its spring
wrap the belt around the tensioner pulley
release the tensioner so the spring pulls it against the belt
rotate the drum by hand to ensure the belt is aligned and does not pull offf the pulleys
reassemble case
dry clothes
its easier than it looks seeing a broken belt in the bottom of the case.
fd5c779.jpg tensioner may be on the bottom run pushing up, or on the top run pulling down
Jul 07, 2008 | Zanussi TC7114W Electric Dryer
Frigidaire FGX831FS Washer/Dryer Laundry Center, White, Extra-Large Capacity Wash Tub, 2 Agitate / Spin Speed Combinations, 3-Position Water Level Adjustment, Bleach Dispenser, Heavy-Duty Single Speed 3/4 HP Motor 5.7 Cu. Ft. Super Capacity Drum FGX-831FS FGX83 Logo
197 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
