Question about Husqvarna Garden
Why won't my line trimmer switch off when I press the STOP button? I have to keep pressing it before it will eventually stop. Rather dangerous problem, as well as being a general nuisance. Is this e
Continuously pressing the stop switch and also rotating the trimmer to try and starve the motor of petrol (to prevent gravity feed from the tank.
    Master:
  • 550 Answers
Obviously the switch is faulty
Posted on Dec 01, 2014
  • 4 Answers
SOURCE: 18v cordless string trimmer will not stop feeding line
Some of the trimmers recommend a certain size line, if you have one of these that let line out as needed, the speed at which the trimmer cuts will let out line as needed. If you have too small of line the drag for the friction let-out you will spoll all the line out. Make sure the line is the right size, They come in alot of sizes, anywhere from .060" to .125" line thickness so make sure you have the right size line!
Posted on Aug 07, 2008
panilling9
  • 284 Answers
SOURCE: Troy Bilt 4-cycle trimmer won't stop!
Take the switch so it is accessable
take the two wires and touch them together or hook them together bypassing the switch
does it shut off or it should not have spark?
if so you have a bad grounding problem if it does not shut off,if it does your switch is still bad
2 wires one tied to ign. module and other to a metal ground all the switch does is dead short. the igniton to shut down the spark and in turn kills the engine.
Be sure your grounding is tight and clean and all wires are intact and making good contact to their designated areas (no broken wires)
hope this helps some for you
Posted on Jun 13, 2009
  • 47 Answers
SOURCE: motor works fine, but trimmer will not rotate
Have an assistant start and hold the trimmer. At idle, there should still be a little drag on the clutches to make the shaft spin on that split shaft trimmer with the accessory head removed. No need to rev it or do anything fancy, but teamwork will make it safer.
Now forget about the engine and clutches - does the accessory head spin freely when turned by hand (removed from engine still!) and with a clear rotation of the shaft end visible inside the connector socket? Is the shaft end square with sharply defines angles, or rounded off? Does swapping in a different accessory function normally and as expected?
Sometimes the nub end of the shaft wears. Worse, the socket on the engine side has eaten itself to pieces. Worse, worse yet, clutches in the engine side that engage the accessory shaft are worn and there is simply no transmission of power. Good luck, hopefully this info will set your boots in the right direction!
Posted on May 09, 2010
2strokeJim
  • 577 Answers
SOURCE: Engine wont stop running when you press red stop
sounds like a bad switch or brokenwire
Posted on May 03, 2011
  • 6468 Answers
SOURCE: Ryobi 975R head won't stop turning.
sounds like the idde is to high
Posted on Aug 10, 2012
Power button on GWL15 has issues
You will need to get a new tac switch installed into the display board
and put some clear packing tape over the crack on the decal to stop water getting in again and wetting the new switch.
Dec 06, 2012 | Fisher Paykel EcoSmart GWL15
Aug 06, 2012 | Garden
Kia sorrento wipers won't stop
I had the wipers won't shut off, or turned on by themselves on my 2005 Kia Sorento. It about drove me nuts. I came across my solution by pressing every button I could find, eventually finding out what the mystery button to the right of the hazard button on the dash was for. (It's to defrost the front wipers by the way) You can investigate further if you'd like but it's not necessary if this works for you.
I simply pressed the button on, waited a moment and turned it back off. It stopped the wipers. They came back on about three more times over next few days and I repeated the process each time. It's been about three weeks since the last time I did it and I haven't had any more problems. This sound crazy or quirky I know and I don't pretend to understand it, but it's working for me. It beats the heck out of paying over $300 dollars plus labour for a new wiper switch . I priced them. Good luck.
Jul 17, 2012 | Kia Cars & Trucks
Canon MP700 Multifunction printer displays message "Wrong cartridge"
1. With the printer powered off but connected to a power source, press the Power button while
pressing and holding the Stop/ Reset button.
2. When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3. When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4. When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in. (orange and green, starting with orange.)
Mar 24, 2012 | Canon MultiPASS MP700 All-In-One InkJet...
How can i reset my canon mp500?
Hello and welcome to FixYa!
The manual reset Method for CANON MP500 is given below, Follow every step carefully
Press and hold STOP/RESET button.
Press and hold POWER button.
Release STOP/RESET button without releasing power button.
Click STOP/RESET two times and then release power button.
Now your printer enter into service mode. Now
  1. Prepare paper on the paper tray
  2. Press Stop/reset button for 1 times and then press power button, await till printer finished print.
  3. Press Stop/reset button for 2 times and then press power button, await till printer finished print again.
  4. Press Stop/reset button for 3 times then press power button to reset EEPROM.
  5. Press Stop/reset button for 4 times then press power button to reset Waste Ink Counter.
  6. Switch off the printer. if printer doesn't turn off, press button power until printer off.
You have done it
If any Further assistance required, I am here to help,
Your token of appreciation in the form of Rating as FOUR THUMBS (given below to this solution) will be esteemed.
THANKS and Keep Visiting FixYa
Mar 31, 2011 | Canon Pixma MP500 All-In-One InkJet...
Whilst cutting my hedge, inadvertently, I allowed my trimmer to run out of fuel. I refilled it and when I tried to start it, the engine spluttered then stopped and I have been unable, susequently, to start...
The fuel line probably has become air locked .Keep pressing the primer bulb if the trimmer has one and also repeatedly try to pull start the machine with the choke on. Eventually the air should be flushed from the line.
Sep 16, 2010 | Ryobi Garden
My homelite trimmer string keeps getting stuck and when i tap it to release more string it doesn't the spring in it doesn't spring at all. I constantly have to stop take it apart pull enough string to edge...
It's sticking pretty good. Try what I do: Pull the head off and clean it out pretty good. Also clean where the spool attaches to the trimmer. Before you reassemble it, give it a shot of powdered graphite (I get mine at the hardware store. It's for locks). Reassemble the spool onto the trimmer. Bump it on the ground several times to distribute the graphite within the head. Now, press the head in and pull on the trimmer line. It should dispense a little line and stop, just like when the machine is in operation. If it works, you're done! If it doesn't work, you will need to replace the spool. They are available at the major hardware stores. Even if you have to replace the spool, the graphite trick is a good one. It'll keep the head dispensing line smoothly. I add the graphite probably every 7th or 8th time I rewind the spool.
Best regards, --W/D--
Aug 09, 2009 | Homelite Garden
Garden Logo
61 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
