Question about Cell Phones
How to replace a washer motor on a dishwasher
Only starting now
  • 1 more comment
  • rcbeltz Dec 01, 2014
    Hi Christo , I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Dishwasher make, model and approximate date of purchase. Note: replacement of the motor and associated pump is not difficult once you have the right components on hand. Look forward to your response so I can provide additional help. RCB
  • Christo
    Christo Dec 01, 2014
    It is a LG model LD1415T! and it is about 6 years old
  • Christo
    Sorry model 1415T1
    Scholar:
  • 85 Answers
Here's a link to the LG site so that you can download a service manual (in PDF format). This should help you determine the steps involved in removing and replacing the motor as well as helping you to identify and order a new, replacement motor: http://my-downloads.net/download/?pi=www.manualslib.com&gclid=CPKq0-zQo8ICFcXm7AodbV4Abg Good Luck
Posted on Dec 01, 2014
Water leaking on floor? How to fix
Depending on how old the unit is will depend on where to look for the leak. You have an incoming water line, a motor (with an impeller) and a discharge hose. First look at the hoses, motor assembly and areas under the washer tub for tell tale signs of leaking. Look for staining, usually a line like white powder will lead you to the leak. If none is found, start with the incoming line; first look at the valve that feeds the dishwasher, see if that is leaking. if it is, it will have to be replaced. Look at the feed hose to the dishwasher and see if it is brittle and cracked, if it is, replace it.Look at the discharge hose for brittleness and cracking as well, also check the connections to insure they are tight. If the hoses are found to be in good shape then look at the motor. There is a gasket that is in between the motor housing and the washer, see if it is leaking if so, replace it. You will have to remove the dishwasher to access the motor so be prepared to spend some time to complete this. Good luck and I hope it is just a hose issue.
Oct 20, 2014 | KitchenAid Dishwashers
Frigidaire dishwasher leaks from motor
This is caused by the cheap bearing's in the motor. Even after I have replaced my $200.00 motor assembly it still leaks. put a small flat dish under it as the leak should be small and when the dishwasher starts making a loud noise the bearings are gone and I do not recommend replacing motor as it is half the price of washer itself. I myself will never buy a fridgidaire again. However if you do replace the motor assembly it is very easy and there is a video on youtube showing you how. good luck
Mar 25, 2014 | Frigidaire FDB700BFC Built-in Dishwasher
Kenmore Dishwasher Model 665.16009400 starts and stops quickly
If your Question has not been answered yet you better replace it with a new dish washer from Sears. Its almost Black Friday.......
Feb 28, 2014 | Dishwashers
Water leaking under the dishwasher
I have Kitchenaid model number (KUDE70FVSS2) and thought it was great (so quiet) until recently when I had to remove it for unrelated reason. That's when I noticed leaking (slow drip) when running. Laying on back (to prevent water going everywhere) isolated problem to the motor (diverter motor) and with a little internet research discovered that the factory had installed the washer (between the motor and the sump) upside down! Washer has deep groove which should face downward so that it covers part of the motor housing and seals completely. Well as result washer had been leaking (slowly) for a while, and on top of floor damage, motor connectors corroded into nothing. Motor actually seems fine and (be warned) replacing wouldn't fix the problem. Now trying to figure out how to reconnect wiring to motor without having to buy whole new wiring assembly. While motor replacement is fairly easy (two screws and two wire connectors), replacing entire wiring assembly involves door disassembly, lots of connectors and it's twice the price of the motor. Grrrr so mad at manufacturer now since this seems like intentional obsolesce.
efac4cf2-0542-4eb2-bb73-eadaf192d266.png e9aafc3a-da97-45ca-83e3-bd424971ad46.png 6deca94c-b9a9-4f73-89b3-da843200872c.png 4bcdf922-94a3-4853-bca5-e89d20798320.png
May 09, 2011 | KitchenAid KUDE70FVSS Builtin Dishwasher
The washer cycle stopped without warning, i thought the timer or the timer motor but it is not the timer works fine and so is the motor. but the timer motor runs til the washer motor starts than is the...
Confirm that the lid switch a common failure is working. A distinct click is usually heard when lid is closed. Temporarily by-pass to confirm and diagnose this type of problem. Confirm tab is in place on the lid.
Jun 28, 2017 | Jackson JPX-300L Dishwasher
Dish washer will not start. Program shows that there is power, but it will not start. Door is securely shut. the other day I took the trap apart and saw about 1C of standing water below the silver...
Hi..
If dish washer wont start check this
  • Check for a blown fuse or tripped circuit breaker
  • Check that the dishwasher is plugged in securely
    or
  • Inspect the wiring connection to the dishwasher for burns or breaks.
  • Check the door latch
  • Test the door switch
  • Test the timer motor
  • Test the selector switch
  • Test the motor start relay
  • Test the motor
Check also this
  • Unjam the motor
  • Unjam the pump
  • Test the motor
  • Check the drive belt
Good luck !!!
Regards
PCmania
Jul 11, 2009 | Bosch 24 in. SHU66C05 Stainless Steel...
Washer fills, but cycle doesn't start
This is motor failuer. replace asap. the smell is the motors copper windings heating up the internals of the motor Housing.
Jun 02, 2009 | GE 24 in. GSD4030Z Built-in Dishwasher
My kenmore elite dishwasher will not start.
Thanks to another post, i found how to clear this code, by alternating between the High temp dry and air dry buttons the dishwasher went into diagonostics, then cleared. I found then that the washer would fill but not wash then it would drain. I found the motor was almost seized, I am replacing. The 7 flashes must be a code for the motor going on overload.
Oct 08, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Wont start
It sounds as if your motor may have locked. Remove the lower service plate, visually inspect the motor and housing. Try to start the washer, while looking at the motor. If there is no motor movement, Turn off washer, and try to free the impellor. More than likely it is stuck and needs a little help turning
Jul 18, 2008 | GE Nautilus 24" Built-in Dishwasher
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
