Question about Sony Playstation 3 (PS3) Console
My Ps3 freezes during games. shows on Netflix and while loading. goes into shut off mode and go completely out. Have to unplug the back and corrept files to turn off?
Restored database.Restored default settings. wiped everything off and is still doing it
    Master:
  • Sony Master
  • 665 Answers
It's possible your system may be overheating. Use a temp gague or thermometer to monitor how hot the back of your system gets before it freezes.(By the fan) You might have to replace your fan if it is overheating.
Posted on Dec 12, 2014
SOURCE: PS3 playing Oblivion The Elder Scrolls IV and when
I can only give a partial answer to the problem. I had the same issue so i went to the load screen and selected the last saved game like you did, except from there i saved again (NOT AN AUTO SAVE, OR YOU WILL LOOSE YOUR PROGRESS)after moving a few steps. Reset then selected the game i just saved and when it loaded i had a successful load and left the cave with full play capabilities. Out of curiosity, what cave were you in? Was it the weapons delivery job for the fighters guild? my problem is that ive closed 5 gates since then and leveled up 4 times. i realy dont have to save too often since ive learned to duplicate objects like healing potions and invisibility potions! So if anyone figures this out it would save me a ton of work.
Posted on Mar 25, 2009
  • 42 Answers
SOURCE: ps3 freezing and wont load after it freezes
If you press the PS button does it bring up the XMB? If it does that means your bluray laser is dying. They are about $70 on ebay and you can replace them using the guide here: http://progamer.cc/blog/ps3-laser-kem-400a/how-to-replace-a-ps3-bluray-lens-guide.html/ another option is to send to Sony and for $150 (if it's out of warranty) they will replace it.
Posted on Feb 12, 2009
  • 265 Answers
SOURCE: PS3 freeze
hey guys i fixed this...
its over heatings the CPU and GPU
you need to disassemble it... http://www.llamma.com/PS3/repair/PS3_disassembly_tutorial.htm
then you need to replace the thermal compound with artic silver 5 as the stuff sony has put on is very dry and cracked, i have done this 4 7 of my mates PS3'S and they all work fine.
only do this if its out of warrently, if you removin the sticker on it, it shines through void
Posted on Feb 16, 2009
  • 15 Answers
SOURCE: my ps3 wont load games or it freezes when it turns on
PS3 is one of the most amazing gaming device but like other competitor gaming devices (Xbox and Wii) It also has some problems like Freezing up. You may check out the informative Article at ezinearticles Remedy for PS3 Freezing up
Posted on Apr 24, 2009
sacblietzenn
  • 8 Answers
SOURCE: My ps3 freezes at random times.
it has a problem on its system try visiting the website of the ps3 production you might get a answer for the matter .
Posted on May 09, 2009
Ps3 restoring problem
Does it give you an option to start without restore? Another option is to unplug it completely for 30 seconds. Mine sometimes does this too, but shutting it off almost always works
Sep 09, 2012 | Sony Playstation 3 (PS3) Console
Game shut down during play, and it will not restart, I try to start the game and it comes with green and blue light then shuts right back off
This is why a lot of people end up looking for a good PS3 Repair guide.
This enables you to fix the problems from home and if you get a good guide you will not need to be technical in order to complete the fix. It will only take you about 1 hour to complete the fix with a few household items.
The hardest thing is finding a good guide that will actually work.
We have reviewed each problem and given you a link to the best solution below:
PS3 Repair Guide
PS3 Yellow Light Of Death
PS3 Freezing On Games
PS3 Red Screen Of Death
PS3 Not Reading Games
PS3 Red Lights Fix
Hope this helps?
Sep 27, 2011 | Sony Playstation 3 (PS3) Console
When ever i try to play ps3 games on the mitsubishi hdtv 1080, the screen cuts to black with green hatchmarks. The PS3 home screen displays but as soon as i enter the game mode the screen goes black
Good day!
That is usually happens when the TV is not compatible to the PS3 because the graphics of the PS3 is very resolution.
The qualification standards of that TV is not reaching the higher resolution of PS3 even your TV is HDTV.
Thank you very much for using fixYa.
May 02, 2011 | Mitsubishi WS-55613 55" Rear Projection...
Xbox 360 Freezing during netflix and dvd playback
If you are using a HDMI connection, often the connection will be lost between your xbox and your tv. In my case I simply change to another channel or the other HDMI channel and then back and the secure HDMI connection will be restored.
Aug 05, 2009 | Microsoft Xbox 360 Console
PS3 FREEZING
This is due to fulty caps inside.. This will need to be looked at buy a autherized Sony repair technition.. If its under wareenty it will be covered and the unti will be replaced.
May 20, 2009 | Sony Playstation 3 (PS3) Console
Ps3 loads up then loads game then it freezes then ps3 shuts off ?
Mar 21, 2009 | Sony Playstation 3 (PS3) Console
Fallout 3 freezing
Mar 06, 2009 | Sony Playstation 3 (PS3) Console
My PS3 is stuck in set up mode and I can't exit to play Rockband?
shut PS3 off with the back of PS3 switch then turn it back on.
Dec 24, 2008 | Sony Playstation 3 (PS3) Console
My ps3 wont load games or it freezes when it turns on
Aug 31, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
47 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
