The picture will often switch to a green/blue fuzzy out of nowhere and remain that way for a period of time. I noticed that if the DVI cable is disconnected and reconnected it will work again for a while but then will ultimately fail again.
  • 47 Answers
It is likely to be either the main board or the Tconn board. costing between 100 & 200 Euros. They can be bought online,but Tv's are not to be messed with. Proceed with caution.
Posted on Dec 01, 2014
5 Suggested Answers
  • 31 Answers
SOURCE: Picture becomes fuzzy in different areas of the screen
sounds like a splitter problem try replacing splitters
Posted on Mar 24, 2009
  • 304 Answers
SOURCE: Picture goes off after a while
Call 1-800-Samsung to set up a warranty service call. They will repair it in your home if they send a Samsung Field Engineer. You probably have a bad Main bd.
Posted on Jul 17, 2009
SOURCE: fuzzy picture wen connecting macbook to tv
Sounds like bad Earths to me... Is it better if it is OFF, the AC/DC power supply? If so then yes, bad earthing between units and earth.
Posted on Feb 03, 2010
joeguest2
  • 2080 Answers
SOURCE: Unable to get my PlayStation
First make sure your PS3 does not have any video game or movie disks in the console.
Then try hooking up just the HDMI connector to the TV.
Then turn on your TV and switch the TV INPUT MODE SELECTOR to HDMI.
Now place the PS3 in STANDBY by pushing and holding down the POWER button for about 8 seconds, until you hear the machine beep twice.
You should now see an option to view at the highest resolution. Select YES.
Repeat this process 2 or 3 times with the HDMI if necessary.
If you are still unable to get a signal, then switch to the AV cables and repeat the process.
Good luck.
Posted on Jun 20, 2011
Anyone have problems with Panasonic TC-P60ST30 with white fuzzy picture mal-function?
Try going into set up menu and look for a screen degauzing function or try setting the screen temp. to warmer or cooler.
Aug 11, 2017 | Panasonic Viera Plasma TV TC-P60ST30
Y/Pb/Pr outputs are green; needs
There is no calibration for the component video that I know of, check your cables you may have a bad Pr cable or the Pr/Pb ones may be mixed up.
Y (the green one) is for luminance, plug in ONLY this connector and you should see a black and white picture.
Now connect the Pr. You will now see red tones.
Now connect the Pb. And you will see blue tones.
Reverse the Pr and Pb and see what happens.
Oh and make sure you don't accidently have one plugged into a composite video or digital audio port.
Still not looking right?
Go into the input menu of the TV and change the component (or colourstream) input from RGB to Y/Pr/Pb. (most TVs do not have this feature.
Hope this helps!
Jan 24, 2010 | Samsung SIR-TS360 DirecTV DTV Receiver
Mar 24, 2009 | LG 50PX5D 50 in. Plasma HDTV
Green tint to picture when dvi cable is connected
The tv will show correctly in 720p mode. Cable box and PS3 must be set to display in 720p or the green tint will remain. For the PS3 I return it to 1080p when I am about to play a game, blu-rays and dvd's can only play in 720p.
Dec 15, 2008 | Akai PT46DL10 46" HDTV-Ready Television
All (4) video inputs are bad
possible change your AV cable...you can't use the same component cable for the normal AV input...component cable (RGB - RED,GREEN AND BLUE),normal AV cable is RED,WHITE,YELLOW.
GOOD LUCK.
Dec 09, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Hooked up a hdmi/dvi cable
try using the red- blue- green high def connections
Dec 08, 2008 | Hitachi 57F500 57" Rear Projection...
Like seeing double!
You need to replace both convergence ICs they are STK392-110. You can get replacement Ics with free instalation instructions with pictures at the following link
http://servicemanuals.vstore.ca/
Jul 14, 2008 | Toshiba 42H81 42" Rear Projection...
Color screen
If you are hooked up with a DVI cable you need to either use hdmi, component cables or turn off the non hd override...
Jun 15, 2008 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Blue crt shot
The coolant in the blue tube has no doubt congealed to an oatmeal like consistancy. Did you notice things like blue halos around things for some period of times. change the coolant. that should correct the blue. this is a common thing for that model as well as all TVs. Blue and green has this happen, Red seems to not have the same trait.
Mar 20, 2008 | Philips 55PW9363 55" Rear Projection...
Blue tint to picture
cheak projecter mode your in under hdmi mode blue cool settings on hi ? eash input setup is differt use warm colers not cool 1 2 3 so on u know what i mean sum sterio have hard time with hdmi out to dvi might wann use coumpuont out from reciver to 15 pin vga sum projecter in 720 p mode have gard time 1080i so on u relly need dvi out from setrio to dvi more less for monister cable best use compunt cable projecter only 16 millon colers anyays ok not 529 billon like samsung plmasa would be were u would wann use hdmi to get all those colers but coumpunt is more then worthy wiyth projecters output ok
Jan 23, 2008 | Onkyo TX-SR674S 7.1 Channel Up-Converting...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
