managed to remove via the filter opening, the only way. very tricky when working in situ.managed to remove via the filter opening, the only way. very tricky when working in situ.
To remove the control panel on a Citroen C4 2016, you'll need to follow a series of steps. Please note that working on the electrical components of a vehicle can be complex, and it's important to exercise caution and disconnect the car's battery before attempting any removal. It's recommended to consult the vehicle's service manual or seek professional assistance if you're not familiar with car electronics. Here's a general guideline:
1. Disconnect the Battery:
Before working on any electrical components, disconnect the car's battery to prevent any accidental electrical shorts.
2. Remove the Trim Panels:
The control panel is typically located behind the dashboard trim panels. To access it, you'll need to remove these panels. Carefully use a panel removal tool or a flat-head screwdriver to pry off the trim panel. Be gentle to avoid damaging the clips or the panel itself.
3. Unclip the Control Panel:
Once you have access to the control panel, you'll need to unclip it from the dashboard. The control panel may be held in place by clips, screws, or a combination of both. Carefully remove any screws or clips holding it in place.
4. Disconnect Wiring Harness:
After unclipping the control panel, there will be a wiring harness connected to it. Carefully disconnect the wiring harness by pressing down on any locking tabs and pulling it out. Be cautious while doing this, as improper handling may damage the wiring or connectors.
5. Remove the Control Panel:
With the trim panel removed and the wiring disconnected, you should now be able to remove the control panel from its mounting location. Gently slide it out.
6. Installation:
To reinstall the control panel, follow the steps in reverse order. Reconnect the wiring harness, secure the control panel in its mounting location, and reattach the trim panels.
7. Reconnect the Battery:
Once you've completed the installation, reconnect the car's battery.
8. Test:
To replace the spring on your Whirlpool washer SM8525492-B, you may need to remove the upper control panel. Here are some steps you can follow to do this: 1. Unplug the washer from the electrical outlet to ensure your safety. 2. Remove the end caps on each side of the control panel. These end caps are located at the top of the washer and can be removed by pulling them off. 3. Once the end caps are removed, use a screwdriver to remove the screws that hold the control panel in place. There should be two screws, one on each side of the control panel. 4. Once the screws are removed, slide the control panel forward to release it from the clips that hold it in place. 5. Tilt the control panel back and rest it against the wall. Be careful not to damage any of the wires or connections that are attached to the control panel. 6. You should now have access to the springs on the washer. Replace the spring as necessary, and then reattach the control panel by reversing the steps above.
If you are still having trouble removing the control panel, it may be helpful to consult the washer's manual or contact a professional for assistance.
UP under left side of the instrument panel ! Remove left end access panel instrument panel .
Important: The access panel is removed in order to visually see the electrical connectors and the location of the transfer case control module. It will also be easier to see the mounting and alignment slots for the transfer case control module mounting bracket.
Remove insulator panel left side .
Remove the 2 screws that retain the insulator panel to the instrument panel (IP).
Release the insulator panel retaining clip from the IP substrate.
Lower the insulator panel.
Remove the 2 data link connector (DLC) retaining screws.
Remove the DLC from the insulator panel.
Remove the courtesy lamp from the insulator panel. Refer to Instrument Panel Courtesy Lamp Bulb Replacement in Lighting Systems.
Remove the splice pack from the insulator panel.
Remove the hazard and turn signal flasher from the insulator panel. Refer to Hazard and Turn Signal Flasher Replacement in Lighting Systems.
Remove the insulator panel from the IP.
Remove the transfer case control module (1) and mounting bracket from the instrument panel mag beam.
Disconnect the three electrical connectors from the transfer case control module.
Remove the transfer case control module from the mounting bracket.
why do you want to remove the control panel? much more info is needed... you can gt to it by starting from the back and removing the screws from the top. push the top panel backwards and remove it from the cabinet. then you can access the front panel. it will have 2 screws holding it to the front. remove them and then lift the control panel up and off the front.
The control panel for the heater and A/C must be removed. Suggest you get Chilton's manual from the library. It will take you through step by step with pictures. To summarize: 1) Remove trim panel covering radio and heater controls. 2) Remove radio. 3) Disconnect the two heater control cables from the control panel. The trick to removing the cables is to compress the "claw" spring holding the cable by pressing a screwdriver from the underside of the control panel to release each cable.4) Remove control panel. Take to a workbench. From the backside of the control panel at the top, notice two large holes through which you can access the V2 Toshiba bulb holders. Turn them a quarter turn to remove them and the bulbs. The bulb is a common #74 bulb.
Unplug the microwave from the wall outlet prior to disassembling.
Open the microwave door. Remove the screws securing the grill above the door opening to the microwave. Remove the grill.
Remove the screw located at the top of the control panel, which is now visible with the grill removed.
Lift the control panel up to release the tabs securing it in place. Move it away from the microwave.
Look at the rear of the control panel to any disconnected wires that may have caused the control panel to stop functioning. If wires are disconnected, reconnect them, reassemble the microwave and determine if the problem is still occurring. If the problem still occurs, replace the control panel.
Transfer the wires from the old control panel to the new control panel.
Move the panel back against the microwave's control panel housing. Slide it down to lock it into position.
Install the screw at the top of the control panel.
Replace the grill on the top of the microwave. Secure it using the screws that were removed.
what is the issue? May not be the blend door motor. Big job.
The climate control assembly has three control knobs (18519):
The airflow control or function selector knob controls vacuum and electrical applications.
The temperature control knob, attached to the potentiometer, controls the position of the A/C electronic door actuator motor (19E616) mounted on heater air plenum chamber (18471).
The blower motor control knob, attached to the heater blower motor switch (18578), provides four speeds of blower motor operation.
A/C Electronic Door Actuator Motor
Removal
Disconnect battery ground cable (14301). Refer to Section 14-01 .
Remove instrument panel (04320). Refer to Section 01-12 .
Instrument Panel
Removal
Position wheels straight ahead.
Raise vehicle on hoist. Refer to Section 00-02 .
Remove RF wheel and tire assembly. Refer to Section 04-04 .
Remove retaining nut in radiator coolant recovery reservoir area.
Remove bolt retaining front fender apron (16054) to front fender (16005).
Position front fender splash shield out of the way.
Lower vehicle.
Tag and remove wiring connectors.
Remove retaining screw in parking brake control (2780). Remove parking brake control.
problem is usually the resistor, but switch may be going bad too. The resistor is next to the blower motor, above the passenger's feet. You may have to take the glove box out to get to it. See picture below. Also, please see my tip athttp://www.fixya.com/cars/r6234839-doesn_t_heater_or_air_conditioner_blow for additional diagnostic info. Please get back to me if you have any questions. REMOVAL & INSTALLATION, Climate Control Panel
Remove the center console trim fascia.
Remove the radio to allow access to reach behind the control panel.
Remove the control panel attaching screws.
Remove the center console bracket, if necessary, to allow for easier removal.
Separate the control panel from the trim panel.
Unplug the harness connectors and vacuum lines from the control panel.
To install:
Plug in the harness connectors and vacuum lines from the control panel.
Install the control panel into the trim panel.
Install the center console bracket, if removed.
Install the control panel attaching screws. Do not overtighten them, as they are screwed into plastic.
Install the radio.
Install the center console trim fascia.
Operate the climate controls and check for proper operation.
Control Panel
1. Remove power from unit.
2. Remove burner switch control knobs.
3. Open oven door and remove screws securing control
panel.
4. Remove screws located on the right and left sides of
the control panel.
5. Grasp control panel on the far left and right sides and
gently pull the control panel out and down.
NOTE: Gently pull control panel out and down.
6. Remove infinite switch control knobs, infinite
switches, indicator lights, rocker switches, and
electronic control/clock (as necessary) and transfer to
7. Reverse procedure to reinstall control panel.
Electronic Control
1. Remove control panel, see “Control Panel”
procedure, steps 1 through 5.
2. Remove screws securing electronic control bracket to
control panel.
3. Label and disconnect terminal wiring from electronic
control.
4. Reverse procedure to reinstall electronic control.try that
Not easy. Briefly, in addition to the screws you mention, the cooker side panels need to be removed to give access to removal of the control panel side clamps. Then the indicator lamps have to be disconnected, and timer etc. buttons have to be pulled out to allow removal of the the control panel. Then the main control unit (timer etc.) needs to be unscrewed from behind the control panel.
Replacement is reversal of above.
managed the removal via the filters. very tricky when working in situ
