How do I remove the hinged lid on an AMI MM6 Jukebox?
I have removed the 4 screws on each of the metal brackets containing the two large springs but the hinge pins entered in the wooden top prevent removal without damage to the wood.
SOURCE: CD is stuck in the Numark CDX cd turntable
hello, there should 4 little black screws on the top of the cd tray when it is removed from the deck. two of them are on the rear top in black plastic. the other two are holding the silver plate down as well. remove those four screws. the top should slide off. after that is off, you should be able to see how the disc is being secured. careful not to pry any thing it should all come apart. good luck.
Posted on Jan 16, 2008
djnick989
  • 1067 Answers
SOURCE: PSP slim UND door hing problem
may need smal star tools seaes sells kit 9 bucks t4 t5 t6 t7 t8 to get in it to work ill look online for serv manel but u can brose too online for taking apart a psp slim ok
IrishDruid
  • 2712 Answers
SOURCE: hinge on lid melted
You can contact Rival HERE.
Mailing Address:
Rival
c/o JCS/THG, LLC
13120 Jurupa Avenue
Fontana, CA 92337
Telephone: 1-800-323-9519
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 02, 2008
SOURCE: Wurlitzer OMT CD Jukebox I have two Florescent tubes out
The tubes are standard "twist" fit, turn the tube about a quarter and it should come out. I had a couple of tubes go around a year ago, I got new ones from Ring Lighting of Leeds, you should be able to get them from one of the DIY sheds (B&Q etc)
18" (450mm) 15 watt, model number 61012 £1.60p each, I was told by a" dealer" that they are specially made for Wurlitzer and cost £5.50p each + vat. I sometimes think some dealers work on the bulls**t baffles brains theory.
Good luck, Graham
Posted on Jan 26, 2009
SOURCE: How to replace hinge lid pins
I had an apprentice reply online. Read answer posted Jan 25th and my comment Jan 27th. Thanks.
Posted on Jan 27, 2009
Need step by step on taking top off my whirlpool cabrio wtw 6500
On the back you will see 2 hinges right and left , remove the top 1/4 inch screws, then you should be able to slide the top forward and lift, i would tape the lid or keep a hand on it due to the lid is spring hinged and will fly open . once you get there remove the 2 1/4 inch screws holding lock . remove and replace and just reverse the process .
Feb 17, 2013 | Washing Machines
How do I remove the trunk lid hinges on a 01 ford escort?
you will have to get the boot open first and you will find a hinge at either side Ther should be 2 bolts at each hinge that screw up into the metal bracket. Remove these carefully( Need a mate to hold the lid)
Jan 24, 2013 | Cars & Trucks
Lid on chest freezer will not securely close Model #FCM 7DAA WH Serial #RTI63278 Mfg 81998
Remove lid, squeeze hinge back into shape and refit, adjusting screws in rear of hinge bracket as you do.
May 19, 2012 | GE Freezers
Wd62p replace hinges
First of all remove the door from the machine by unscrewing the screws on the hinge than remove clip at the top of door seal, when it unclips remove metal band, pull front of door seal off of front panel, Pick up metal bracket. Now with the hinge attached to door hold in place and place bracket behind the two holes fit screws and then fit the seal and clip.
Regards
May 05, 2012 | Hotpoint Ultima WD72 Front Load...
Can't find any instructions - can I reverse the door from the left side to the right side?
Hi and welcome to FixYa. I am Kelly. The answer is YES you can reverse the door.
Here is the text of how to reverse the door:
DOOR ASSEMBLY & HINGES
The door assembly is reversible. It contains an inertial vibration damper comprised of a steel plate suspended with springs. The
damper is designed to tune out excessive vibrations generated by the machine during the spin cycle. Replacement inner door liners are
shipped with the vibration damper in place.
REMOVAL
1. Open the door and remove the center screw of each hinge secured to the inner flange of the front panel in the door opening.
2. Grasp the door with both hands and lift the hinge area slightly. Draw the door assembly away from the machine. This will disengage the hinges from the slots in the
front shroud (Figure 5-1). If the hinges bind, press out on the plastic shroud near the hinge toward the cabinet.
Figure 5-1
REVERSAL
1. Repeat the above steps and, remove the corresponding sheet metal spacers on the opposite side.
2. Remove the hinges from the door and relocate them to the other side of the door.
3. Remount the door into the new slots and secure with one screw into each hinge.
4. Mount the sheet metal spacers onto the side where the hinges were previously to cover the hinge slots in the front shroud.
That is the text without the whole service manual pictures.
Thanks for using FixYa.
Kelly
May 21, 2010 | Maytag MAH6700AWW Neptune Front-Load...
I need to replace the boot on my washer. Any ideas?
open door and remove the 4 screws 2 in hinges and 2 on other side . then grasp the two side corners and give it a tug /front sholud come of . tilt out and remove. remove the two l brackets top corners 5/16 screws . this will release top /be sure to remove the dist cover 4 screws on top. lift top . you will fint a spring and wire running around boot . pull togther to relace . remove boot . reverse to install boot mm
Dec 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
My oven door does not close tight
These hinges are now obsolete and you cannot get them anywhere. The poblem with this type of hinge is not with weak springs or anything like that, it is with the pivot pin in the door hinge. Follow these instructions and it will not cost you anything for the repair.
It is best to remove the oven from the housing. Remove both sides of the oven panels, you have to remove the top first, then the sides (remove about 20 screws all together). Support the bottom oven door first by tying a bit of string between the bottom and top oven door hand rails. This will stop the door falling down when you remove the springs. unhook the springs and the door will just slide out. (Use a loop of string attached to the back end of the spring to pull it from its holes.)
Dismantle the door by removing the screws. You will probably find that the the hinge pivot pins have come away from the U shaped hinge bracket. The secret is to make sure that these are fixed firm back into the bracket. What I did was to nip the U hinge bracket in a vice, (or use pliers) so that the pin will now protude slightly each side of the bracket. This allows more surface bearing area so the pin will not pull itself out of the hinge. To further make sure, I glued the ends of the pin with epoxy resin.
Then reassemble.
My door now feels like a new one even though it is 15 years old.
Sep 16, 2009 | Stoves 720EF Electric Double Oven
Electrolux z4494 vacuum cleaner mains cable wont stay out
Opened up case as follows:
- Open lid of bag chamber. Remove lid by gentry prising the hinge arms slightly further apart so the hing unclips from the body.
2 deeply recessed screws now accessible at rear edge of bag chamber - undo.
Prise out large button of on/off switch to reveal another screw - undo
Prise out large button of cable retract to reveal another screw - undo.
Cover now lifts off.
Inside I found the brake wheel had fallen out of its plastic bracket. The plastic bracket is hinged, and moved my pressing one end with the big button, which lifts the wheel away from the cable drum. Gently prised the bracket arms apart and put the brake wheel back in.
Solved it - but don't know why it happened, or whether it is likely to happen again.
Sep 01, 2009 | Electrolux Vacuums
Toaster oven door will not close completely.
This problem is caused by screws being loose or dropping off a limiting bracket on the left side of the oven behind the left outer wall.  This bracket allows the front glass panel to remain OPEN, as required for broiling.
To correct this, first check to see that the two black screws facing forward, behind the left side of the front glass panel are tight.  If not, tighten firmly, but be careful not to overtighten.  If this fails to correct the problem, then follow this procedure.
Purchase 2- #4 x 1/2" SS Phillips Pan Head sheet metal screws at your favorite hardware store.  Cost About $1
  1. Unplug the oven and place on a flat work surface. Place a rubber mat or towel under the oven to prevent scratching.
  2. Remove 2- #4 x 1/4" black phillips flat head screws on the left side of the front glass panel which screw into the black side panel.  These are NOT the screws which hold the bracket, which face forward, but are adjacent to the bracket screws.  Be sure to indentify the proper location of all screws for replacement.
  3. Remove the 4- #4 x 3/8" SS phillips pan head screws at the bottom of the left side of the oven.  Pry the metal tab of the back panel slightly off the bottom of the black side panel.
  4. Remove the 3- #4 x 3/8" SS phillips pan head screws from the back panel which attaches to the left side black panel.
  5. Carefully pry the bottom of the left black side panel up from the bottom of the oven until it is parallel to the top of the oven.  It will seem hard to pry it upward as you are bending two SS tabs holding the black side panel to the SS top.  It will come up easily once you get it started.  When it is parallel to the top, slide the black side panel to the rear to remove it from the two SS tabs.
  6. You should now see the limiting bracket at the front of the oven's left side.  Remove the 2- black Phillips screws holding the bracket.
  7. Slip the limiting bracket from the oven.  Place on a wood block and with a chisel (or large common screw driver) and hammer, strike the screw holes on the bracket firmly once, so as to close the screw holes slightly.
  8. (OPTIONAL)  If available, using a rat tail file (or small flat file), at the crook of the spring lever, carefully increase the indent of the crook ever so slightly.  This will allow the front glass panel to stop more definitely at the open point.
  9. Remount the bracket using the 2- #4 x 1/2" SS Phillips Head sheet metal screws you bought. Tighten firmly, but do not overtighten.  Check the front glass panel movement. It should have a definite stop to allow the panel to stay open approximately 1/2" for broiling and should close fully, easily.
  10. Slide the left black side panel on to the SS tabs.
  11. Pry the left side black panel down until it meet the bottom plate.
  12. Replace the bottom screws.
  13. Replace the 2- #4 x 1/4" black Phillips flat head screws at the left side of the front of the front glass panel which screw into the black side panel.
  14. Replace the back panel screws.
Feb 23, 2009 | Cuisinart TOB-50 Toaster Oven with...
At the back of the washer just below the control panel there are two 8mm metal screws remove them there are 2 clips they will alow you to lift the top up in the front of the washer the top cover has 2 spring type holders if you slide a small screw driver in the opening and push gentle on the spring clips they will release and you can lift the top off the washer there is a screw on each hinge this will remove the old hinge then replace with new ones hope this will help
Jan 24, 2009 | Maytag PAV2300 Top Load Washer
42 people viewed this question
 Grubhead
Grubhead
