Question about Samsung Refrigerators
My Samsung refrigerator, mdl RS25H111SR will not allow me to get ice nor water
When trying to get ice or water a symbol appears resembling a lock.How do I get water/ice
    Sergeant:
  • 308 Answers
Hold down the child lock button for 3 seconds it will unlock the panel
Posted on Dec 02, 2014
Our refrigerator worked after dumping out ice filling up the container and in order to dislodge ice jammed at the mouth of it, but nothing can tell you about this, it was just a deadlock where the 3 seconds solution was not working at all, in the meantime temperature was on the rise, all great now.
Posted on Dec 07, 2014
SOURCE: Samsung Ice Maker on Mdl RB215LASH
There is a simple solution but maybe not for the long run.
There is a black rubber button on the front of the underside of the icemaker. It is a reset switch. I was told by Samsung support that this is a common problem if the icemaker has been off for a while.
Mine wouldn't work out of the box and several resets later it is still not making ice consistently. It has been 2 weeks and it has yet to fill the bin. We haven't used ANY ice from the maker. If the best it can manage between resets is a few trays... I think its time for a return to the store.
I hope you have better luck.
Posted on Oct 13, 2007
ice maker fill line frozen up
Posted on Apr 07, 2008
TJBENGR
  • 121 Answers
It is quite possible the water line near the ice-maker is frozen. I would try a warm hair drier to thaw it out.
Posted on Apr 21, 2008
bestdarngood
  • 3037 Answers
SOURCE: side by side refrigerator icemaker
I would first try replacing the solenoid valve which lets the water in. Also, how are the ice cube arms aligned? They should be vertical
Posted on Jul 04, 2008
SOURCE: Ice and Water Dispenser not working on KSCS25FKSS01 KIT.AIDE MODEL
This is a known manufacturing defect. The problem is that the wire that some of the wires that run between the door and the rest of the refrigerator have broken and, believe it or not, the only solution is to replace the entire freezer door. Whirlpool is covering the cost under a hidden warranty...call them and describe the problem.
Posted on Jul 20, 2008
GE Profile Model PSS26LGSC Ice maker not working
Did the ice buildup appear to resemble the water overfilling the top of the ice maker? The only thing that I believe that may work is removing the ice maker, clean the excess ice buildup.dry and reinstall the ice maker and see it works. If the ice is above the normal level the ice can cause the motor that pushes the ice out of its slots to strain more than the gears or motor can handle stripping the gear or damaging the motor beyond repair, When harvest takes place the first thing that happens is a heater below the ice maker warms the cubes a little just enough to allow them to slide out of their slots and fall into the ice bin. The ice make for your model does not have replaceable parts and if bad or damaged it is less expensive and time consuming to by a new ice maker. If the water fills above the top of the ice maker it is usually the fault of the water control valve not closing all the way once it fills the ice maker after each harvest. Did water refill the ice maker when you cleaned it? Did the water overfill after you cleaned out the ice maker? What I am asking is water over filling ice maker again after you cleaned out the excess ice? If the water continues to flow from the WR57X10032 Water Inlet Valve
Apr 07, 2013 | GE Refrigerators
Water has stopped flowing to the ice maker but is ok to the door fountain. hoses appear to be ok.
sounds like you ice maker is shut off. There should be a switch next to ice maker to turn back on. Also look for a lock out feature for the ice maker. It could also be a sticking water solenoid to allow water to enter tray.
Dec 04, 2010 | Kenmore 57029 Side by Side Refrigerator
Ice maker does not make ice.
JOEHUNT TRY THE WATER VALVE ON THE BACK OF THE REFRIG BEHIND PANEL MAKE THE ICE MAKER GO THROU A HARVEST OR JUST WAIT TO HEAR IF IT GOES THOU A HARVEST THEN YOU CAN SEE IF (1) YOUR ICE MAKER IS ACTUALLY WORKING OR YOU NEED A WATER INLET VALVE ITS 1 OF THE 2 MOST LIKELY THE VALVE
Apr 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Apr 21, 2008 | Samsung RB215LASH
Water filter indicator light
On my samsung I needed to press the ice timer and ice mode together for 3 seconds.
Sep 30, 2007 | Samsung RS2630SH Side by Side Refrigerator
the electric motor for the ice-maker is not turning...why? try disassembling and power motor with 115VAC cord from wall plug...be careful-ensure frig unplugged...using alligator clips...does it turn...can you hear it...it should turn VERY slowly.
May 27, 2007 | Samsung RS2534 Side by Side Refrigerator
RS2556SH Side by Side - Icemaker not filling; fill tube not iced over!?
press the reset button (black) on the bottom of the icemaker, the system will go through a cycle, and water will pour into the tray.
Oct 23, 2006 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
234 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
