<!-- from fixya rte -->My volume and channel not moving - Televison & Video
    New Friend:
  • 23 Answers
I presume that systems used to work OK and you are using the remote. Try the bottons on the TV itself. If they function OK than your problem is the remote. If no funtions work, replace batteries. If only volume and channel are failing than the remote button pads may be dirty. Repair of the remote is dicey but the risk is low. You may need to replace remote.
Posted on Nov 30, 2014
Testimonial: "The remote is not working but the knows are not working on the TV only the on and menu knows works the volume and channel knows not working"
Extreme differences on overdrive channel
Please, take it to a tech in your area, or look for a good one to ship it to. An 2007 amp is not old at all.
Jul 24, 2017 | Marshall Mg100dfx 100-Watt Combo Guitar...
Wires to main speaker are, Yellow & Blue witch one is the positive ?. Also I am getting distortion from the clean channel even at low volume, the speaker is Peavey 1230 model 8 ohms.
Yellow should be the positive. Try plugging in and reversing. The louder of the two is the one in phase and the correct wiring. If the speaker is pushing out when playing , it is in phase and correct also.
The distortion problem could be a speaker going out. It may not be totally blown, but may be verging.
Holding your hand out as wide as you can push against the speaker lightly. If there is a rubbing or scratching sound, the speaker could be damaged.If it moves freely, and there is no scratching its okay.
Another possibility is the clean channel may have a channel volume set to high. Make sure the clean channel volume is set lower than the master volume otherwise you can get distortion on that channel too.
Good Luck.
Feb 21, 2011 | Peavey Bandit 112 Guitar Amplifier With...
Losing one channel, comes back if you move the
Ideally your volume control potentiometer should be replaced.
You may get a temporary repair by carefully spraying switch cleaner into the control and giving it some "exercise" however, this will only delay the inevitable.
May 13, 2010 | NAD C370 2-Channel Amplifier
Original remote lost. have universal remote. cannot program TV
On the right hand side of this television there are panel buttons. It appears that your son in law knocked the tv out of the correct input. Press the input button in order to cycle through the 5 inputs. Typically pressing the input button on the side panel of a television and pressing it again and again and again will make it change inputs. Universally the buttons on the tv panel function as follows: Channel up moves the cursor up. Channel down moves the cursor down. Volume + moves the cursor right. Volume - moves the cursor left.
Hope this helps
Apr 28, 2010 | JVC LT-42E478 42 in. LCD Television
Losing one channel, comes back if you move the volume switch around then goes again ?
That must be a dirty volume control (potmeter).
Or there's a lose contact on the PCB which is soldered to your volume control (potmeter).
regards,
Gerard
Mar 22, 2010 | NAD C370 2-Channel Amplifier
I am trying to get channels above 13. I do not
Try bringing up the menu by holding both volume buttons down at the same time (or use menu button on remote if you have it). Go into CH SET using the channel and volume buttons on the front of set (or use the SET + and - and the ENTER buttons on remote). Go to the TV CATV line and move the arrow to CATV. Let menu time out. This will put tv into cable mode. Hope this helps.
Mar 12, 2009 | Durabrand DU1901 TV
Samsung DLP 42" Volume Problem
you might want to get a tech to come and check the service menu and see if some of the audio settings have moved or are miss adjusted as per the mfg. settings
Jun 05, 2008 | Samsung DLP HL-P5663W 56" TV
Loss of volume on left channel
Marantz SR 5200/6200 lost audio or crackling on left or right channel except in mode s-direct is now fixed !
The root cause is a defective inegrated circuit on DSP board (the one with digital inputs). To fix it change the chip CS4391 by a new one or better by the improved version CS4392. On my device a capacitor was cut close to this IC : replace one 1uF after changing the IC. For any question search me with my callsing "F5RCT"; i have a spare IC for the one who is able to change it !
I'm amateur radio and engineer
Oct 15, 2007 | Marantz SR-5200 Receiver
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
