Question about Pool & Spa
How do i fix my arctic spa is not working, it keeps blowing the breaker when i reset it the panel on the spa flashes 222 for about 10 seconds then gives the temperature then the breaker blows again. i
How do i fix my arctic spa is not working, it keeps blowing the breaker when i reset it the panel on the spa flashes 222 for about 10 seconds then gives the temperature then the breaker blows again. i have topped up the tub with hot water to get it up to 45F for the night to protect it. it is going down to -15C tonight.
    Master:
  • 541 Answers
You have an electrical short
Posted on Dec 01, 2014
SOURCE: I overfilled the Spa and now the breaker keeps blowing.
at the moment it sounds like there msut be some water along the lines inside your electrics, the only thing to do at the moment would be to let it dry out and try either in a few hours or tomorrow. it could be causing a cross between the live and earthing conductors.
Posted on Jan 28, 2009
  • 37 Answers
SOURCE: hot tub blows 50 amp breaker after about two
this could be a bad heater element. easy way to tell is to fill tub all the way to the normal water level turn power off open control box and disconnect wires going to heater be sure not to break leads off when you disconnect so if this is not the problem you can hook back up after disconnecting make sure wires are not touching any thing and turn power on if it stays on you need a new heater element, if not try unplugging things from box one by one until u find the one that allows the breaker to stay on.
Posted on Oct 20, 2009
  • 366 Answers
SOURCE: Reads OH but still cold
you either have a bad temperature sensor (check the wires for damage) or a bad circuit board. I would recommend replacing the temp sensor first. If that doesn't work, pull the board and take it and have it tested.
Posted on Mar 20, 2010
SOURCE: I have a Sundance Spa that has started tripping the breaker
It is unlikely the Breaker is BAD, that just doesn't happen. To trip a breaker there MUST be an Overload, or a Short circuit, that's it. You will have to use a meter an troubleshoot the system. Something is very wrong..please use the links below to troubleshoot and repair. Please Be careful. http://spababes.com/heaterhelp.html
http://www.spadepot.com/spacyclopedia/spa-heater-element.htm
http://www.poolandspa.com/page596.htm
Posted on May 07, 2010
Testimonial: "Looks like this info may save me a service call. Many thanks for the answer and the links."
Ian  Hot Tub
  • 77 Answers
SOURCE: Calcium build up in my Arctic Spa Hot Tub
The worst calcium build-up I have seen on an Acrylic shell was actually caused by incorrect use of chemicals by the owner. The owner was dosing in very large quantities which was the cause of their issues. Little and often is the best way to go when adding any chemicals to a hot tub.
I don't rate Aqua Finesse at all. I have seen cirulation lines partially blocked due to similar products, I wont recommend it to any of my customers or use it myself.
If you were my customer, I'd be running through your chemical routine and the quantities that you add at any one time. It's possible that you are over-dosing and causing the problem to get worse.
Kind Regards,
Ian Kime.
http://hottub.synthasite.com
Posted on May 15, 2010
What would cause both pumps and the light not to work on my hot tub?
Hello, Chances are the GFCI (Ground Fault Circuit Interrupter) outlet that the pumps and lights are plugged in to is blown and needs to be reset via the buttons between the outlets. One button is a test for the outlet and will blow the fuse intentionally to verify the proper operation of the outlet, and the second button is used to reset the outlet to normal operation. If the outlet will not reset or hold (stay on) then the whole outlet needs to be replaced.
Good Luck!
Rich Lilja
Jun 12, 2015 | Pool & Spa
Reset Jandy PS6, still flashing red and green
turn off heater if ok then replace ignitor if not keep removing auxs until stops blowing breaker
Apr 02, 2014 | Jandy Aqualink Pda Ps6 Wireless Handheld...
Caldera olympia highland spa keeps tripping breaker
with power off take heater wires off make sure to mark them so you know which is which if it doesnt blow fuse it is heater element if it still does hook back up then try to disconnect the recirculation pump just keep eliminating things
Mar 02, 2014 | Caldera Spas Highland Series Olympia Model...
Reset pool pump
its called resetting your breaker or gfci
Aug 24, 2013 | Arctic Pool & Spa
Jandy Aquilink control panel keeps tripping circuit breaker
turn off heater if it still happens mark all auxs remove all then try again if it doesnt blow fuse plug 1 in at a time until it does thats whrer your problem is
Aug 16, 2013 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Tiger Spa I have reset the powere at the panel and the spa apperes to go on. I run the pump for a while and then turn the pump off. The power light begins flashing and the pumps will not restart. It...
Have you called your local Watkins dealer for a service call?
I can have you look at a couple of things before you call it in.
Once you turn the system on it will operate without the heater on to purge the system of air. Once that few minutes has gone by the heater will turn on and they system will operate normally.
At what point during this cycle does the system shut down? Does it blow the circuit breaker? Exactly HOW does it shut the pump down?
Rod
US Parts Center
Jan 19, 2013 | Pool & Spa
I have a maax spa, the pump and air lights are flashing, any ideas?
Maax, use a lot of proprietary components calling them is usually best.
But first there are two things which will shut a spa down like this are the main GFCI breaker or the Hi-Limit switch.
Reset or replace.
Jan 15, 2012 | Maax Home
Gfci breaker keeps tripping
sometimes gfi outlets go bad and trip try testing with a heavy draw machine in it or just replace it and see if this fixes the problem
Jun 22, 2009 | Balboa Instruments Duplex Digital Panel 2...
Pool & Spa Logo
74 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
