Question about Kenmore Dryers
Clothes are melting in my dryer
Just changed fuse the dryer streets but overheated again and will not start again don't know if the tub is turning
  • Kenmore Master
  • 744 Answers
Hello Thelma;
My name is Peter. I am a retired field service appliance technician.
Good for you changing the fuse. More and more women are becoming handy with repairs.
Unfortunately, the fuse blew because of another problem.
You may have a high temperature limit switch problem. You may have a time cycle problem.
This is a hard question to answer since you did not provide a model number for me to see what dryer you have.
Please submit your question with the model number. Open the dryer door the model number is on a label inside the door.
Posted on Dec 01, 2014
aborcass
  • 2651 Answers
SOURCE: Dryer tub won't turn
hear the motor running, just not spinnig drum? if so you problably eiteh threw the belt off pully it broke all together. theres 2 screws holding the front panel on apprx 10 in. up and 2in. in, slightly pointed upwards. rmeove them and the front panl comes off, i believ the top might just tip back at that pint in which case youll see the belt wrapped around the drum. ro where it should be wrapped around anyway. new belt num Y312959.if needed, youll need to reach beltto motor pulley from behind unit through a small acsess hole. be carefull not rip bag bael is in because it shows placemnet of tension pulley and correct direction to wrap belt in.anything past that, im thinkin 18 yrs has been a good run, go for new
Posted on Mar 01, 2008
hunter19_46m
  • 7482 Answers
SOURCE: It seems I need to
Hi debbie carls...
Your probably right, it could be the thermal fuse/thermistor/thermostat.
I will supply you with what you need to know, but you have to decide if it is too difficult for you to do.
I use this info below for when the dryers are not heating, some of it will apply to your situation.
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please take time to rate me
Posted on May 28, 2011
heatman101
  • 43501 Answers
SOURCE: dryer tub makes noise as it turns. 2000 model
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Aug 05, 2011
oldTech2332
  • 2341 Answers
SOURCE: Maytag Performa dryer blows fuse
their are two possiblities causing that
1) while cleaning the lint from the motor a wire accidently got pulled of of the motor switch
2) to me the buzzing when start button is pushed and may or may not start,the motor is bad
When trying the trick to start the motor by hand the door switch also must be pressed in
Gene
Testimonial: "Thanks for the resonse Gene! "
hunter19_46m
  • 7482 Answers
SOURCE: Dryer cuts out and appears to be overheating. It
Hi bknight...
Check and clean if necessary your vent hose.
If you vent hose "seems" to be clean then,try running the dryer with the vent hose off and see if the dryer is not running hot anymore.
Make sure your lint screen is in place and has no tears or holes in it and is still firmly attached to the frame.
If you are running too hot you are not moving enough air thru the system.
It could be that the fan blade is plugged up.
The problem could be a large lint ball build up in the center of the fan or a sock,thin pants,a pen,etc. that has gotten into the fan by falling down the hole where the lint screen is normally inserted.
You have to find the air restriction to solve the problem.
It also can be a loose or worn out blower wheel/fan.
Please take time to rate me.
Posted on Sep 05, 2011
Dryer won't start
Either one or 2 things happened. The move cause the lint to shift around inside the dryer and it overheated blowing the fuse. OR the new apartment's vent is blocked and caused the dryer to overheat. All maytag dryers are not the same but they all have a non resetable fuse mounted on the blower housing. When the temp exceeds 350f it melts and kills power to the motor. If the motor is not running the heat does not get power. The motor must be turning to make the cent switch power up the heater. Dryer manuals
Dryer videos
Sep 03, 2012 | Maytag Dryers
My Inglis dryer is overheating. How do I troubleshoot this problem? Thanks...
did you remove the metal duct to the left of the t-stat and thermal fuse?usually this gets filled with lint and will take out either the thermal fuse or the high limit,pull it off and clean it,also if the vent line is long,you can stick a leaf blower into the end of it and blow it out.most problems i find in dryers is from lint buildup.
Dec 06, 2011 | Whirlpool Inglis IP8200 Dryer
A rattle sound when it is running. Also, spinning the tub in off mode manually: a slight spin will produce a sound like a pully or wheel that continues to run after the tub stops
You must have a maytag/crosley/admiral/monkey wards type dryer. They all are notorious for making that sound. That is a worn out blower wheel. 53-0106
Look close at the photo, see the flat? Yours is worn out and letting the blower flop all around. It will take twice as long to dry the clothes and possibly blow the fuse if you continue to allow this. The air flow is greatly reduced and makes for an overheating on top of the dryer and can melt or warp the filter. I have some repair photos HERE
Jan 26, 2010 | Dryers
I just got a malber 1000 washer/dryer. Can it be used as a dryer only?
NO THIS UNIT USES CONDENSED DRYING AND WILL WET THE CLOTHES BEFORE IT EVEN TURNS ON THE HEATER. BASICALLY YOUR COMBO USES STEAM CIRCULATION THRU YOUR CLOTHES. AS THE SMALL WATER PARTICLES IN THE STEAM MOVE THRU YOUR CLOTHES IT COMBINES WITH SMALL WATER PARTICALS IN THE CLOTHES(THINK OF 2 WATER DROPS COMBINING ON YOUR WINDSHEILD AND HOW THEY ABSORB TOGETHER) WHICH RISE TO THE TOP OF THE TUB AND COLLECT INTO WATER AGAIN. THEY THEN ROLL DOWN THE SIDES OF THE TUB AND COLLECT AGAIN AT THE BOTTOM TO BE PUMPED OUT. BEFORE THIS PROCESS EVEN STARTS THE UNIT WILL ACTUALLY ADD WATER TO GENERATE THE STEAM. MOST PEOPLE FIND THAT IF THEY WANT TO JUST FRESHEN UP SOMETHING, IT WILL END UP DRENCHING WET IN THE FIRST FEW MINUTES.
Jan 18, 2010 | Malber WD1000 Front Load Washer/Dryer
Kenmore dryer - put in new thermostat, had to jump fuse because couldn't get one today. Put a few clothes in dryer & it ran fine.After about 10 minutes I noticed dryer was shut off. Checked clothes...
why didn't you just wait till you got the fuse?you blew the first fuse because something is wrong and overheating it,you might have just needed to clean out the dryer because that's usually the cause of poping them now you might have cooked wires or anything else,not smart,what fuse did you jump out and send complete model number
Nov 07, 2009 | Kenmore 63942 Dryer
Dryer heats sometime but clothes do not dry well....vent pipes seem to be clear of lint up to dryer...blower doesn't come on...no air blowing out of dryer...
thats the reason your clothes aren't dry.Have to have air moving through tub. Check fan motor probably a thermal overheat fuse that has blown or if motor is turning, look at the fan and see if it has a set screw or retaining ring that holds it on the shaft or both fan may not be turning with the shaft. More than likely though the blower motor overheated or just plain worn out.
Sep 06, 2009 | GE Profile Harmony DPGT750EC Electric...
Roper dryer stopped working during cycle REX6634RQO
replace your t-fuse again but also chekc to see if the vent going outside is restricted. if hte vent is smashed or clogged the heat has nowhere to go. i would say that is your issue. clean your vent before you change he t-fuse.
Jul 27, 2009 | Roper REX4634KQ Electric Dryer
After 6 loads of clothes dryer will not start for the 7th load.after waiting for approx. 60 mins. dryer starts up and functions as normal
After 6 loads...yeh, well the dryer is obviosly overheating. It takes awhile to cool down, and then will operate as normal again.
When it overheats, the thermostat activates, and stops the dryer from running until it cools down.
But why does it overheat? Have you been cleaning the lint filter after every load, as recommended? If not, this can cause the problem because of restricted airflow. Have you been overloading the dryer? Again, this can cause overheating.
Something to check; when the dryer has normal load, try carefully rotating the drum by hand, in its normal direction of rotation. If it is very stiff to turn, or scraping, then that can cause this problem also. Maybe a bearing problem can cause the stiffness or scraping. I hope its not the problem.
Let me know how it goes please.
May 06, 2009 | Hotpoint Dryers
Dryers Logo
47 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
