Question about Coffee Makers & Espresso Machines
B60 won't turn on
Got 120 to unit
  • 4 Answers
In most cases this problem stems from scale buildup causing too much pressure in water lines or it has built up on heating element. You may as well buy another brewer.
Posted on Dec 02, 2014
My unit says prime and no outflow.
"Prime" usually indicates the pump is sucking air. Sometimes the valve in the bottom of the water reservoir gets stiff or gunked up; if you turn off the B60, remove the water container and drip some water into the water intake until it's full, turn the unit back on, replace the water reservoir and that little amount of extra water should be enough to allow the pump to work properly.
Apr 24, 2016 | Keurig B60 Coffee Maker
Keurig B60 coffee maker won't draw or heat and "not ready" stays on
Handel not in positive position to start brew process.
Jan 26, 2013 | Keurig B60 Coffee Maker
My kuerig onecup won't turn on
Internal breaker has fractured and needs replacement.
Aug 26, 2012 | Keurig B60 One Cup Coffee Brewer
My Keurig B60 won't turn on. Tried different plugs. What now?
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Sep 07, 2011 | Keurig B60 Coffee Maker
No power. circuit is fine but unit won't power on
heatman101
Sep 06, 2011 | Keurig B60 Coffee Maker
The machine won't turn on at all. Tried t in several functioning outlets and it won't power up. Only 6 months old. Keurig B60
heatman101
Aug 11, 2011 | Keurig B60 Coffee Maker
MY b60 all of a sudden won't fill a full cup when it brews. I descaled it and it works just fine and fills the cup with water and no kcup in place. When I brew with the kcup it only half fills.what can I...
When I descaled my b60 I also used a paper clip to clean out a possibe clog in the little bottom drainage tube. The help I received suggested I also use the paper clip to check the top tube which I didn't know about. I did this and now it works fine...thanks for your help.
Dec 30, 2009 | Keurig B60 Coffee Maker
Coffee Makers & Espresso Machines Logo
29 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
