Question about 2000 Chevy Astro - Passenger van, with factory roof rails - Base Rack System
Engine starts, then shuts off. Where should I look?
Many new parts including fuel injectors, mass air flow sensor, distributor cap and rotor, and many more. It has good fuel pressure. It has spark while engine cranks.
  • Paul Marks Mar 22, 2015
    is ther good spray in the Injectors?or is dripping ?check to see if ther is Hose Off sounds like hose off then it will die How many Km,s Does it have ? check the timing maybe ?does it backfire ?
    Sergeant:
  • 252 Answers
Does it run good for the brief period after it starts? Is the vehicle new to you? Does the security light come on after it starts?
Posted on Dec 02, 2014
  • 2 more comments
  • Harold Clark
    Harold Clark Dec 03, 2014
    It runs smooth for about a second or two , then shuts off. I am the original owner. I don't know about the security light, but the battery had been disconnected for a period of time for servicing the vehicle before reconnecting the battery to attempt to start it.
  • Rocguy Dec 03, 2014
    I suspect your problem is with GM's Passlock II security system. In your case, it may just need a relearn. Here is a link showing that.https://www.youtube.com/watch?v=_njAVpk4... In my brothers 98 Chevy Malibu, I actually had to do a bypass because he kept having problems with this. It involves measuring resistance and soldering in matching resistors. Maybe after watching the video, you can see if your security light is acting the same way.
  • Harold Clark
    Harold Clark Dec 05, 2014
    The security light comes on when starting the van, but it does not flash. When I turn the key all the way to start as in the video procedure, it will start again right away, but it shuts off immediately just as it did the first time and I can continue that as long as the battery holds out. Are there any sensors or controls that cause the computer to shut down the engine if it does not receive the signals it is looking for?
  • Rocguy Dec 06, 2014
    I wouldn't worry about the security light flash thing. I really think the passlock II is messing you up. That is the control that will shut things down if it doesn't see the right resistance. It's pretty easy to bypass and costs almost nothing if you can do it yourself or have a friend. Here is a link to how to do it. Don''t worry about it not being the same vehicle. The procedure should be the same once you locate the correct wires. That is easily done also. They will be coming down from your key, They are not very big around either. Don't hesitate to ask if you have further questions.
97 geo tracker stops runing
If one of the sensors is failing, you should be getting a check engine light and a trouble code.
When you say it has fuel, do you have injector pulse and fuel pressure in the rail ?
Jul 18, 2013 | Cars & Trucks
VERY ROUGH IDLE NO EXCELERATION
Try a few if these ideas...
Priority Action Part Type Cause
1 Inspect Spark Plug Fouled, Damaged, or Broken Spark Plug(s).
2 Inspect Hose (PCV) Clogged or Collapsed PCV Hoses.
3 Inspect Wireset Worn, Damaged or Faulty Spark Plug Wire(s).
4 Inspect Distributor Worn, Damaged or Faulty Distributor.
5 Inspect Catalytic Converter Clogged or Faulty Catalytic Converter.
6 Inspect Fuel Pump Low Fuel Pressure.
7 Inspect TimingSet Slipped TimingChain or Worn TimingGear(s).
8 Inspect Knock Sensor Improperly Connected or Faulty Knock Sensor.
9 Inspect M.A.P. (Manifold Absolute Pressure) Sensor Faulty M.A.P. Sensor.
10 Inspect Throttle Position Sensor Faulty or Incorrectly Connected Throttle Position Sensor.
11 Inspect Mass Air Flow (MAF) Sensor Damaged, Loose, or Faulty Mass Air Flow Sensor or Circuit.
12 Inspect Air Cleaner Temperature Sensor Damaged or Faulty Air Cleaner Tempature Sensor.
13 Inspect Fuel Injector Pressure Regulator Faulty Fuel Injector Pressure Regulator.
14 Inspect Piston Ring Set Worn or Broken Piston Rings.
15 Inspect Timing Specification Incorrect Ignition Timing.
16 Inspect Fuel System Pressure Incorrect Fuel Pressure Being Delivered to Carburetor or Fuel Injection System.
17 Inspect Fuel Filter Clogged or Dirty Fuel Filter.
18 Inspect PCV Valve Plugged or Damaged PCV Valve.
19 Inspect Valve Burned, Worn, or Sticking Exhaust Valves.
20 check idle stop solenoid - if faulty, could cause rough idling
21 inspect distributor cap/rotor - if burnt, could cause loss of acceleration
Apr 18, 2011 | Chevrolet Cavalier Cars & Trucks
Runs for less than a half hour and shuts down. Fuel to the rail but not into injectors.Fuel pump, fuel filter,brain, module, crank sensor, oil pressure sensor have all been changed. Starts again after...
Hello: If this is a 4cylinder engine with the distributor on the back of the engine (toward the passenger compartment) I would rebuild/replace the distributor. Including distributor cap and rotor.
Jan 31, 2011 | 1989 Chevrolet Cavalier
Engine stalls out on occasion like the key was shut off have change air flow sencer mapp sencer new vaccum lines
Check your plugs, wires, distributor cap/rotor, fuel filter, and air filter.
If I had to take a guess, I would try replacing the Distributor Cap & Rotor, as well as the Fuel Filter. Also, try running some Gumout Fuel Injector Cleaner and a tank of good gas through it.
I hope this helps! Best of luck to you :-)
Best Regards,
James
Dec 18, 2010 | 1999 Buick LeSabre
Runs ruff changed mass air flow plug wires plugs
check for vacuum leaks, check distributor cap and rotor button, clean or replace as necessary. Use quality injector cleaner.
Feb 18, 2010 | 1993 Lincoln Mark VIII
1999 Ford Taurus mechanical problem
your problem appears to be the idle control motor located on the air intake manifold it is a small motor that goes bad quite often. Other items that can cause this is a bad /clogged air filter or a tune up (spark plugs and wires), or clogged fuel injectors. to clean the injectors you can buy a container of fuel system cleaner and pour it into the gas tank and as you drive it cleans the system.
Once the fuel system is cleaned via a tankful of cleaner & gas then the idle controller motor would be next on the list to be replaced.
Good Luck !
Rich Lilja
Dec 03, 2008 | 1999 Ford Taurus
Engine power loss
Inspect Wireset Damaged, worn, or deteriorating spark plug or coil wire(s). in this list u will find a answer to ur problem Shaun 2 Inspect Spark Plug Fouled, damaged or broken spark plug(s). 3 Inspect Fuel Filter Clogged or dirty fuel filter 4 Inspect Distributor Worn, loose or incorrectly adjusted distributor. 5 Inspect Distributor Cap Loose or cracked distributor cap 6 Inspect Distributor Cap And Rotor Kit Loose, cracked, or worn distributor cap and ignition rotor. grey_line.gif 7 Inspect PCV Valve Plugged or damaged pcv valve. grey_line.gif 8 Inspect Air Filter Restricted or clogged air filter. grey_line.gif 9 Inspect Catalytic Converter Clogged, damaged, defective or faulty catalytic converter. grey_line.gif 10 Inspect Automatic Transmission Improperly adjusted kickdown cable adjustment or internal transmission problems. grey_line.gif 11 Inspect Fuel Pump Improperly functioning fuel pump or circuits. grey_line.gif 12 Inspect MAP Sensor Improperly connected or faulty m.a.p. sensor. grey_line.gif 13 Inspect Mass Air Flow Sensor Improperly connected or faulty mass air flow sensor. grey_line.gif 14 Inspect Throttle Position Sensor Faulty throttle position sensor or throttle position sensor circuit. grey_line.gif 15 Inspect Timing Specification Incorrectly adjusted engine timing. grey_line.gif 16 Inspect Fuel System Pressure Incorrect fuel pressure being delivered to carburetor or fuel injection system. grey_line.gif
Nov 13, 2008 | 2002 Chevrolet S-10
2000 Chevy Astro - Passenger van, with factory roof rails - Base Rack System Logo
101 people viewed this question
Top Thule Vehicle Parts & Accessories Experts
randymanfive
Serge Joncas
Are you a Thule Vehicle Part and Accessory Expert? Answer questions, earn points and help others
