Question about Samsung Microwave Ovens
Samsung smh8165w need # of ic102 please
Looked for schematics and related info.
    Sergeant:
  • 251 Answers
IC chip 102 is a TNY276PN Off-Line Switcher Chip. I believe Power Integrations, Inc makes them. Make sure your power supply Zener diode ZNR101, along with your bridge diodes D101 through D104, (and, for good measure) D105 are all okay just to make sure they didn't short out and blow IC102.
Posted on Dec 01, 2014
My samsung SMH8165W the fan keeps going but nothing else. Can I fix this
If it starts running as soon as its plugged in you may have a bad or out of align door switch. Humming noise could be the mag if its not heating. Replace mag and diode/rectifier
Nov 19, 2014 | Samsung Microwave Ovens
My oven shows SE
Turn off power. take off trim over door ( 2 screws). Remove 1 screw from top of keypad. Lift keypad up and out away from microwave. Use a Q-tip with 1 drop of alcohol to separate and clean between ribbon connectors. It is 1 ribbon that splits to 2 connectors. No need to unplug, Just gently clean between the 2 ribbons. They may seem glued together. When they are separated and clean put electrical tape between them. Reinstall keypad (1 screw). Reinstall top trim (2 screws). If it hasn't damaged the circuit board already it should work like new.
Jul 06, 2014 | Samsung SMH8165W Microwave Oven
Samsung Microwave Mod # SMH9187ST. Starts on its own, "bake potato" on display screen. After shutting down, code SE appears on screen. No response from keypad until unplugged. Reset and problem ret
Contact Samsung, I was having a similar problem with the SE error appearing on my microwave. Apparently its a problem with the control panel and they are going to replace it free of charge under there epidemic warranty
Mar 18, 2013 | Samsung SMH8165W Microwave Oven
Samsung microwave SMH9151W displays code -SE-
"SE" means you have a defective membrane keypad. There are two ways to fix this:
1. Replace the membrane keypad. If you (or someone you know) might want to replace it yourself, there is a handy guide with pictures showing you what's typically involved. It is part number DE34-00304G.
2. Replace the control panel frame assembly (part number DE94-01806J) which comes with a new keypad already installed. Details are below.
There is a a YouTube video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Some connectors have a lock.
Then simply move your circuit board into the new frame.
You should first contact these parts suppliers to see which if either parts are in stock or still actually available:
Sears Parts Direct
Encompass parts (or you can call them toll-free at 866-779-5835)
The Pros here
Again the parts are:
DE34-00304G membrane keypad switch
DE94-01806J control panel assembly
Jan 16, 2013 | Samsung SMH8165W Microwave Oven
Displaying System Error
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean, solder and reset the board. Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
Jan 11, 2013 | Samsung SMH8165W Microwave Oven
How do I open it up to look for a blown fuse to circuit breaker?
When you remove the front control panel you will see the two fuses in the next internal section. Below are instructions for removing control panel:
You can do this without removing unit from wall. First unplug unit. Next remove the two screws on the top of the unit closest to the front. These screws simply keep the up facing vent in place. Next slide the vent to the left (plastic latches on bottom hold in place) to allow vent to be removed. You should now see a single screw above the control panel. Remove it then open the microwave door. Gently slide the control panel up which will disengage the plastic latches on the panel sides. Suggest if you are going to remove the controller and replace take a picture before removing it so you know exactly how to reconnect all the wires.
Dec 16, 2012 | Samsung SMH8165W Microwave Oven
Samsung microwave SMH8165W displaying error code -SE- and continuously beeps.
SE means system error, the keypad has a short in the membrane, or the control board has issues.
Jun 14, 2012 | Samsung SMH8165W Microwave Oven
Schematic diagram
Have you removed the outer case? Sometimes the schematic (and other troubleshooting and calibrating procedure information) is located there. I found such info for a GE microwave (made by Samsung) in an envelope taped to the top of the inside case.
Sep 15, 2009 | Panasonic NN-S960BA Microwave Oven
NEED PART DE41-10330A PCB AND/OR SCHEMATIC
Looks like the new part number is DE91-10368A and it's available for $90.25 from http://www.samsungparts.com
If you'd like the board repaired, we do that for $39.95 in most cases.
We have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Nov 05, 2007 | Samsung MW5580 Microwave Oven
Microwave Ovens Logo
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
