Question about Traxxas Slash
TRXXAS WILL TURN RIGHT BUT NOT LEFT
DONT KNOW WHAT TO TRY
    Problem Solver:
  • 14 Answers
Is the steering servo working ? if so you have to set it back to the center then re attach the steering rod. turn the power off to everything and disconnect everything thats connected to the steering servo. then turn your remote on and set the steering trim on the remote back to center, then turn the power on to your car. the servo will automatically set itself to the center position, and then reattach the steering rods to your servo. make sure your tires are pointing straight forward as well when you screw the stuff back onto the servo. should do it. if the servo isnt working just replace it.
Posted on Jan 04, 2015
I have 2005 f150 trailer lights on left have no power i dont know wich fuse is for tow left
in the passenger compartment fuse block look for fuse number 42. That will be the left trailer stop/turn fuse.
fuse 36 is the right stop/turn fuse.
they are both 10 amp fuses.
Jun 13, 2012 | Ford F-150 Cars & Trucks
How do you get a stearing colum unlock and the
hi if the problem is that the lock has locked and wont free when you try and turn the ignition on then what you should try is turning the steering wheel from left to right as hard as you can whilst you try turning the key, the problem is usually that the lock is under pressure from the tyres trying to turn the steering wheel so with this pressure on the lock the key just wont turn so you need to try and release this pressure so that the key will turn and unlock the lock.
so hold the steering wheel tight and turn it left using a bit of pressure whilst you keep trying to turn the key dont hold the key in the same possition as this wont free the lock keep turning the key on and off so that it resets and this should then allow the lock to free and you should be able to start your car, if turning the steering wheel left dont work then try right and repeat with the key on and off until the lock is off and the steering is free.
now it is going to be tight so you will need some force to turn the steering wheel as the force from the tyres will be quite alot so you will need to use force to work the steering wheel left and right whilst turning the key.
now if this still dont work then this will either mean you have a problem with the key or the actual ignition barrel has got a fault if this is the case then your going to need to get a new igniton barrel, the part the key goes into before the lock will free itself, all you need to do to remove the barrel is to remove the cover from the steering wheel surround and then you will see how the barrel comes out of its surround but dont do this until you have a new lock in case you forget how you got it apart.
the chances are the lock is just stuck and working the steering wheel left then right as far as you can will free it up if it dont then you can also try jacking the 2 front wheels off the floor like put the car on stands then try turning the steering left and right to unlock the ignition doing it this way releases the pressure from the tyres and should make it easier to unlock the steering.
let me know how you get on or if you need further assistance ok
May 23, 2010 | 1996 GMC Jimmy
I have a 2001 trans am and when I turn on my car the left turn signal is on and when I turn the handle to turn left vthe light blinks on and off very slow but the right side work just fine .And also when i...
turn it on,, get out of the car & see if all the turn lights are working,,if u dont know how many,,turn right on first look at them,,then turn left side on,,sounds like u have a bad bulb,, hoped it helped
Apr 18, 2010 | 2001 Pontiac Firebird
When ever i turn my laptop on..it boots properly..then ill be typing and it will shut off..or go on standby not sure then i will push the power button...but it doesnt rootboot ...and starts back up where i...
Try this.
Right click on desktop.
Mouse down to properties, & left click.
Left click on screen saver.
Mouse down to Power In monitor power, & left click.
Check your power settings & hibernation settings.
Also some computers are setup to hibernate if mouse is placed in certain parts of the screen (top right or left, Bottom left or right.
Hope it helps.
Mar 11, 2009 | Dell Inspiron 1525 Notebook
When i turn the turn signal to make a left or right hand turn all lights lite up but dont blink
Check to see if the front or rear bulb illuminate when you set the TS switch to the right or left. If the bulbs light in only the front or rear you have a signal head issue.
Let me know.
Regards,
Feb 25, 2009 | 1994 Chevrolet S-10 Blazer
Need to repressurise my worcester 28si combi boiler
most worcesters have n internal filling loop, depending on which one you have i.e CDi (left hand side, or Greenstar/ junior (high efficiency) right hand side, there ill be a void, the filling loops are black plastic with either a small grey or white knob, position your filling key pointing up, with the little noggins poiting at 3 and 9 o'clock, so it looks like your putting the key in on the wont almost. Push it up, and twist. (older worcester turn it 45 degress), newer worcester turn to the right slightly, you'll know if its in right because you cant turn it any further on the newer ones. turn the small knob anti-clockwise to let water in, unitl the reuired pressure is reached. Normally 1- 1.5bar is adequate. If you key isnt in right water will come out where the key is. So if it does it means the key isnt in right, dont panic, turn the knob off and try again. Once done, twist key back to its original position and pull out, youll probably gets a few drip out, this is normal.
Unforuntely not the most user friendly of devices if you dont know what your doing.
Good luck
Dec 25, 2008 | Combi Centre DX - Mango
Problems with the keyboard
Sticky keys can sometimes be fixed by hitting right shift key 10 times quickly (I'm not lying!!), and or the culprit key (x) the same way. Try that and if it doesn't work, reboot and type. If it continues, please try another keyboard.
Nov 20, 2008 | Computers & Internet
Traxxas Slash Logo
124 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
cwradio73
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
