I missed the copy of the 27th of Novembers issue of the letters page can I get a copy?
Why won't it print test page?
If the test page placed face down on the glass does not contain text, you will get blank copies.
Jan 08, 2016 | Office Equipment & Supplies
Error code c004
Missing a letter at the end of C-004 A/b/c/d. which one? each one is a different fan on the machine
Sep 15, 2012 | Minolta EP4000/5000 CS/PRO Copier
NTLDR is missing
this is a very common Issue:NTLDR is Missing.
Related errors:
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Causes:
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and/or NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
  10. Failing to enable USB keyboard support in the BIOS.
Windows XP users
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
    copy e:\i386\ntldr c:\
    copy e:\i386\ntdetect.com c:\
  7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
hope that it will be help full
thanks
Oct 27, 2010 | Dell Computers & Internet
Ntldr missing
Hi kojak52143,
There are two possible issues. The assumption is made it is windows xp. The following Microsoft Technet article describes why and how to resolve your issue. This is for Windows XP SP2 and earlier. http://support.microsoft.com/kb/320397
If your running Windows 2000 .. pls execute the Microsoft Technet article described below. http://support.microsoft.com/kb/318728
For Windows XP for the above issue: Insert the Windows XP bootable CD into the computer.
  1. When prompted to press any key to boot from the CD, press any key.
  2. Once in the Windows XP setup menu press the "R" key to repair Windows.
  3. Log into your Windows installation by pressing the "1" key and pressing enter.
  4. You will then be prompted for your administrator password, enter that password.
  5. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
  6. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Hope this helps ... cheers.
Oct 16, 2010 | Computers & Internet
NTLDR is missing error on starting the machine
When a PC system or notebook displays NTLDR is missing you can still recover with out re-installing windows. Follow the instructions on the link provided; http://www.computerhope.com/issues/ch000465.htm
Scroll down to: Corrupt NTLDR and/or NTDETECT.COM file.
The fix is a bit different for Win 2000 &Win XP.
Mike
Oct 17, 2009 | Systemax Neotach 3300 Notebook
My Xerox M20i has a 2inch margin missing from scans on the righthand side of the paper. This is a randomly occuring issue as some pages will copy/scan just fine and others not. Also, when this does occur,...
You may not have enought toner,or the scaner needs to be clean up!Also the laser maybe need cleaning!Other thing maybe a primary charging wire witch is up on the drum!Check this thing if u can !
Sep 01, 2009 | Xerox WorkCentre M20i All-In-One Laser...
NTLDR missing issue
Jul 29, 2009 | ASUS Eee PC 1000H Laptop
NTOSKRNL.EXE missing
NTLDR is missing  Press Ctrl Alt Del to Restart
----Windows XP users Insert the Windows XP bootable CD into the computer. When prompted to press any key to boot from the CD, press any key. Once in the Windows XP setup menu press the "R" key to repair Windows. Log into your Windows installation by pressing the "1" key and pressing enter. You will then be prompted for your administrator password, enter that password. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
copy e:\i386\ntldr c:\ copy e:\i386\ntdetect.com c:\
Oct 19, 2008 | Computers & Internet
ADF will only feed one sheet then stop
no,just try to clean the roller of the ADF at the same time the separator pad.make sure that you are using paper that is 24lb weight coz if you are using paper that is so thin if may cause also an issue that the ADF could not pick-up...if the issue is still occuring return/replaced the printer...
send feedback for further troubleshooting...
Aug 23, 2008 | HP Officejet 6310 All-In-One InkJet...
49 people viewed this question
k24674
