SOURCE: Renailt megane 2000: Back door will not open
kind of hard but it can be done but what probly happen is that the child lock is hafe and hafe not ingaged or disangeged so it's stuck
SOURCE: rear passenger door could only open from the
had a renault myself and had same/similar problems. i had to take off door panel and attatch linkage bar again and make work from inside and out again. not too easy to do but worth diy as cost quite a lot in garage? door panel is quite easy to take off. reply to this if you try but struggle.
SOURCE: inner door panel removal, renault megane scenic
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls
SOURCE: can some one tell me how to turn off child lock on
Cant you tell me where to turn on the child locks on a 54 plate Renault scenic please???
