Question about Fostex Mr16hd 16 Track Digital Recorder
Hard disk has been formatted, but still says too many events on disk when i try to bounce to stereo
How do I fix my zoom
Its initialihzin hard disk drive so the hard disk is probably broken put in another one dont know if you need to format it but its your hard disk for shure
Oct 20, 2014 | Zoom R16 Multitrack Recorder
I'm trying to burn a song to a CD-R using a Boss BR 1180 but every time it completes, there's no song on the CD. I record, bounce, record on 9/10, then try to write to CD and it never works.
"it never works"... this is NOT enough information for us. You are not telling us how the CD is tested. If you are testing it in a boombox type player, that is not a test. First thing is to look at the bottom of the CD to see if you can detect written tracks... with right lighting you can tell if it has been burned. REMEMBER that CD's, unlike phonograph records, are written from the middle outward. Many consumer players have trouble playing CD's that are written but not "finalized". If you CAN see written area (compare to unburned CD) then likely the burning is taking place, and the problem is the format is either not complete or incompatible with your player. Try reading the disk in your computer. Also you might want to visit the forums for the Boss/Roland workstations at VSPLANET.com.
Aug 19, 2011 | Boss Micro BR Digital Recorder
Just purchased the mg102c, must I utilize a balanced cable to hook up my JBL powered speakers.
Yes... to get best noise performance use balanced TRS or XLR. ALSO power the speakers and this mixer from the SAME receptacle to avoid ground bounce and possible damage to the units.
Jul 19, 2011 | Yamaha Mg102c Stereo Mixer
The effect light won't stay on so I don't know by looking if effect is activated or not. The light goes on when I step on it but as soon as I release it goes out.
Chances are the switch itself is defective... Either the toggling mechanism in it is bad or it has excessive contact bounce. Replace the switch.
Mar 25, 2011 | MXR Stereo Chorus Pedal Guitar
Maybe stupid question....is it possible to record 8 separate mono tracks on this thing? I cannot seem to select only track 5, 6, 7, or 8. When I try to record onto 5, for example, it is impossible to not...
I believe you have to adjust the levels DURING the bounce operation... I don't think you can do that after.
I would consider using a computer based editing program to handle more than 4 tracks...
Aug 30, 2010 | Fostex Mr 8hd CD 8 Track Recorder with CDr
What are the exact steps to bounce tracks on the Boss Micro BR
It’s necessary to bounce all of your tracks to a stereo pair of tracks before you can export your song to a computer as a WAV or MP3 file for burning onto a CD.
1. In normal mode, push EXIT and UTILITY until you see BOUNCE on the display.
Note: The upper right corner of the display shows the track you’re bouncing to. By default, “12V2”—Tracks 1 and 2, Virtual Track 2—is selected.
2. Press STOP and REWIND together to go back to the beginning of the song.
3. Press RECORD, and then press PLAY.
4.When the song’s finished playing, press STOP.
i read some stuff online and this should help.
Apr 15, 2010 | Boss Micro BR Digital Recorder
When bounce tracks on my micro-br there seems static going on
First of all, it would be better for you to pan the tracks, and bounce into 2 tracks for stereo separation.
Your "static" may stem from three pausible causes.
One, four tracks into mono may make your output a little muddy.
Two, watch the reverb - if you keep applying reverb after each bounce, it starts to sound bad.
Three, if you have drums/rhythm, turn it off while bouncing. Only have drums on when mastering, because they will keep getting re-recorded during bouncing.
Go to bossbr.net - The best place to get answers!!!!
Sep 27, 2009 | Boss Micro BR Digital Recorder
Boss BR 8...I insert the 100 mb disk, then asks to initialize..I enter 'yes' then it asks 'sure?' I enter yes then it says 'medium error' then ejects the disk..what's the problem?
If the disk had data put on with a PC you might try deleting all files and folders using the PC before formatting the disk in the BR8.
It is also possible that the media has gone bad.
A final try would be to degauss the disk and try to format on the BR8.
Sep 09, 2009 | Boss Micro BR Digital Recorder
My zoom multitrack says "check disk"
http://www.zoom.co.jp/archive/English_Manual/E_MRS1044v2.pdf If this is the model you have you have to format the hard disk before using it the first time. You may also have to restore the machine to factory settings using the recovery disk that came with it. The link is to the download for the manual.
Aug 07, 2009 | Music
Fostex Mr16hd 16 Track Digital Recorder Logo
21 people viewed this question
Top Fostex Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Fostex Music Expert? Answer questions, earn points and help others
