Question about Great Plains Industries Gpi& Fuel Pump
How to change a fuel pump on a mazda 98 b4000
Changed the fuel filter and still loosing power
    Sergeant:
  • 149 Answers
Before throwing more and more parts at the problem, first thing to check is fuel pressure, if it's OK, then that isn't the problem. It could be------a plugged catalytic converter, a failing ignition coil, bad plugs, distributor cap, ignition rotor, cracked/defective dist. cap, ignition module. The list can go on and on. Start with the basics. When was the last time a major tune up was performed? Smog check? We can minimize costs by figuring out the real problem first. If you are adamant about the pump, it's in the gas tank and you will need to drop it out of the truck to change it. Good luck
Posted on Dec 04, 2014
My Mazda 1998 B4000 looses power when I drive and than the power comes back. It is intermitted . I was investigating and could be my fuel relay. I already changed the fuel filter and did not correc
Test fuel pressure when key on/ engine off, and when running and compare to specs. Could be bad fuel pump, relay, regulator, gas cap, injector failing.
Dec 02, 2014 | 1998 Mazda Pickup
How to change a fuel pump on a 1998 Mazda B4000 pickup
Wouldn't you want to do some testing, to actually find a problem,
before you continue to install parts for no reason?
Do that--- test things
Nov 30, 2014 | Mazda Cars & Trucks
Mazda b4000 troubleshooting i have a 94 b4000 i have a **** when i put power to it as lone if i keep it above 2000 rpm it will run halfway fin but most the time it jerks i have just change the...
i would clean out tbe fuel tank and fuel lines, check for kinks.
Especially clean and test fuel pump and ensure all filters are clean.
May be an idea to clean throttle body too.
Jan 12, 2018 | Cars & Trucks
Where is the fuel filter on a 1994 Mazda b4000 pickup?
Driver side frame rail right where the door is. It's held in by a large hose clamp. It has 2 white plastic clips . 1 on each hose of the filter. When removing have a container that can hold gas ready because about a pint of gas will come out. Make sure new filter comes with new clips. I don't recommend using old ones. After new one in place turn key on and leave in run position for 20 seconds so filter can gill with fuel before starting and inspect fir leaks.
Mar 15, 2009 | 1994 Mazda B-Series
2007 Mazda B4000 Fuel Pump Noise
sounds like he's trying to wait till the warrenty expires.... be on record as complaining about it during the warrenty period...
the only recall i could find was on the fuel tank itself and my search was in someways imcomplete.
this is about all i can find on your vehicle in regards to recalls
http://www.lemonauto.com/complaints/mazda/mazda_b_series.htm
Nov 19, 2008 | 2007 Mazda B4000
Mazda B4000 Fuel Filter replacement
remove the bracket from around the filter, and remove the clip from the fuel line, and it should pop right off.
Jun 21, 2008 | 2007 Mazda B4000
Great Plains Industries Gpi& Fuel Pump  Logo
65 people viewed this question
Top Great Plains Industries Garden Experts
Steve
RSole
Mai Lor
Are you a Great Plains Industries Garden Expert? Answer questions, earn points and help others
