Question about Whirlpool Home
I have a swirl way arianna whirlpool tub, but I can not find where the on switch should go? is it suppose to be a wall mount switch? Also, is this tub discontinued?
3 Suggested Answers
  • 7 Answers
SOURCE: whirlpool corner tub not working
you wiil need to check 2 things.First you will need to check the motor.Their should be a reset switch on the motor.also attached to the power buuton is ablack thin hose if this hose came off the switch or motor than the motor wont come on.Look around for an access door .If thier is acloset in an adjoining room you might find it thier.
Posted on Feb 02, 2009
PartsCenter
  • 125 Answers
SOURCE: power switch for whirlpool tub
the easiest thing (maybe) is to install an air switch kit on the side of your tub. Here is a link to the part. Basically you install an air button on the side of the tub, install the air tubing from the nipple on the underside of the air button to the nipple on the box that plugs into an outlet under the tub. The pump plugs into that same box and the air tubing from the air button pushing onto the nipple on the box. When you push the button on the tub it will turn the pump on/off. Air Switch Kit
Posted on Feb 24, 2009
I have a swirlbath whirlpool tub and the air hose fell off the push button switch on the side of the tub. The tub is 19 years old and the switch is against the wall side of the tub. How do I hook it u
Yo Dennis,
When I had to replace a switch on my unit I had the same problem. Jacuzzi uses double sided tape to hold the switches in place and they are a bear to get off. Try some dental floss or fishing line under the switch body to "saw" through the tape and lift the switch out. Maybe use a hair dryer first to try to soften the adhesive, but at 19 years it may be rock ??.
You may have to pry the switch out (!!) with a screwdriver (rag underneath) and the old plastic may grenade. A new one may be needed.
Be prepared for very little slack in the air line. I had a hard time reconnecting mine and ended up having to add a couple inches of tubing with adapters. No fun. The switches are mounted from below at the factory, so slack is not an issue.
All the best.
Dec 05, 2014 | Whirlpool Home
Just bought a home with a swirl - away tub need to clean out and I am not sure how to remove the jets from the inside of the tub. I need to clean them..
Check with your local plumbing supply shop, there are special self cleaning chemicals to run thru the system, also can be purchased on line.
May 19, 2011 | Whirlpool Home
Purchased new home with a swirl-way avalon jetted tub dont know how to start it please help
is there an air button on the top of the tub? if so that is what you would turn the pump on/off with. give it a push and see. if you do have a button to push like that then make sure the air tubing is hooked up to the bottom of the air button and the other end is hooked to the air switch in the back of the motor.
if there is NO air button to push and just the logo on the top of the tub then you will need to fill the tub with water, get into the tub and then touch the logo. that would turn an older Swirlway tub on/off.
Feb 06, 2011 | Home
I have a Mansfield, Swirl-way tub. Jets won't come on. Lights are working, but no action from the jets.
on mine water got behind the soft touch controll and corroded the connection see if there is green gunck on the phone like plug
Oct 04, 2009 | Whirlpool Home
Jacuzzi whirlpool, air on/off button on tub
If it is a air button that pushes in and comes back up, there is a good chance that the switch (which is mounted on the pump/motor) is bad. If the switch is a touch button on a key pad, the problem is in the control box for the pump/motor.
Sep 05, 2009 | Jacuzzi Signa Whirlpool Tub B540
Whirlpool tub not cutting off.
First I would remove the switch hose from the pump. Pinch the end of the hose over and hold it in place with a piece of tape. Depress the button and hold. If the button has little to no resistance then there is a hole in the air line which is causing enough air to leak that there is not enough force to activate the switch. If that is not the problem then just consider leaving the switch in the hole on the tub surface but adding a regular wall swich to the wall near the tub. This move the switch action from the tub to the wall. This a really cheap solution compared to getting a new switch mechanism which is what is broken for about $200.
May 23, 2009 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
When we press the "on" switch in or Kohler whirlpool tub it trips the wall switch. I changed the wall plug and it still trips when trying to turn it on. It has always worked fine. Any suggestions..
Remove the GFCI WALL OUTLET and try connecting those wires together blk/blk..wht 2 wht...ground to ground and then see if tub will stay on, if not suggest put back together and call qulified whirl pool tech to find short in pump motor.
Please rate. Thank you. jj505
Mar 28, 2009 | Kohler Synchrony K-1192-LH-0 White 5 Feet...
Whirlpool corner tub not working
Jan 23, 2009 | Whirlpool 2 Person Corner Air Tub By...
Home Logo
99 people viewed this question
Top Whirlpool Home Experts
Donni Steen
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
