Question about Epson Workforce 1100 Color Inkjet Wide Format Printer c11ca58201
I can't seem to print a 13" wide paper on my Epson workforce 1100. The printer just sends the paper through. All other sizes work fine. Anything else I can do?
I have printed 11"x17" without a problem, but the 13"x 19" doesn't work. The paper light comes on and the paper is sent through without printing. The paper is thicker photo paper, but a smaller size prints fine. Any suggestions? Epson advertises that this printer will print up to 13". help!
How do I print on 11 x 14 paper? According to the online manual, the Epson WF - 7620 does print 11 x 14. And that is why I bought the printer, but I cannot figure it out!
Load A3 size paper on the lower tray.
Verify you see A3 as an option in paper setuo on the printer screen against tray 2.
Make sure you have selected A3 on the software before you print.
EPSON WORKFORCE A3 WF 7620DTWF
Sep 18, 2016 | Epson WorkForce WF-7620 Wireless Color...
It says paper size does not match the paper source setting, Print on Letter No Yes Remind later
Check paper tray it might have a movable plastic thing that sets the paper size . Check printer properties on settings - printers - Epson Workforce printer properties. Check software you are printing from that it has page setup and printer setup paper size set correctly
Mar 02, 2015 | Epson WorkForce WF-3640 Wireless Color...
Correct setting for Epson Workforce 7520 printing on gloss paper
You need to start with photo glossy paper that's designed for an Epson printer. HP paper may not work well, and some other papers don't work either. Try some Epson paper, and that should work fine.
You can also try other paper settings, such as "transparency" or "matte paper", as the paper setting governs how much ink is laid down. I think getting the right paper is really what you need, though. Ink "puddling" is a common Epson complaint, and it's almost always the paper.
Nov 02, 2014 | Epson WorkForce WF-7520 Wide Format...
My Epson Workforce 1100 suddenly stopped printing black when printing in color. This happens when printing from Microsoft Word, Wordpad, Lightbox (photo manipulation) and Adobe Reader. It prints black...
normally most printers even like mine an epson NX110 will use color then black when using text but with grayscale only your forcing it to use black ink more and no color ink set in normal mode some color ink does get used ironically but it is normal for it to use color some as it reserves the black ink being used
Apr 22, 2017 | Epson WorkForce 1100 Wide-Format Color...
Prints from wrong cassette
Have you tried setting the paper size for each cassette, then setting the printer to Auto instead of selecting the cassette?
May 15, 2013 | Epson WorkForce WF-7520 Wide Format...
Keeps saying paper jamed when I try to print
On the Epson website it is confirmed that the Epson WorkForce 610 will not recognize transparency media. It is just the way the printer works; if it can see through the media, it doesn't think it's there.
However.....you can tape a sheet of white paper to the non-printable side of the transparency, and it prints just fine. I put two strips of scotch tape on either side, top and bottom. Works great. It's kind of a hassle, but better than not being able to print transparencies at all!
Jul 22, 2010 | Epson Workforce 610 All-In-One InkJet...
Epson Workforce 1100 Color Inkjet Wide Format Printer c11ca58201 Logo
83 people viewed this question
Top Epson Computers & Internet Experts
teamtech
teamtech
Are you an Epson Computer and Internet Expert? Answer questions, earn points and help others
